Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 01-28-2009, 09:37 AM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Default Rally Gods.... need advice on a fitment issue 05 STi
What calipers and rotors will bolt up to an 05 STi that will be running 15in compromotive wheels with 5x114.3 bolt pattern???? Is there anything in the Subaru inverntory that will work with this combo...esp the brake rotors???? thinking maybe SVX???
Bill
Old 01-28-2009, 10:24 AM   #2
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Tons of people run the stock 'subaru' 4pot caliper setup with some kind of upgraded rotor or stock rotor.. they do very well and dont cost a lot to run either. Subaru pads or some modified nissan pads will do wonders.
Try it man.
Ralliart4 is offline   Reply With Quote
Old 01-28-2009, 10:43 AM   #3
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
The 4 pot/2 pot brakes fit.
In the rear you need the gravel rotor - but you have to drill it for 5 x 114 unless it has been released in 5 x 114.
The front si tough to get a rotor for. The 4 pot rotor doesn't fit over the hub. A guy on Dirty Impreza out in CA made a 2 piece rotor that works.
SVX stuff is somewhat completely different - although I did make a bracket to run 300ZX 4 pots on the SVX rotor - it's 303mm diameter though - so I dunno if it would fit the wheels.
KNS Brakes is offline   Reply With Quote
Old 01-28-2009, 10:45 AM   #4
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Thanks again to WRXBrakes the adapter setup is AWESOME!!
Old 01-28-2009, 10:50 AM   #5
KNS Brakes
Member#: 125739
2015 WRB WRX
Are you the one who got that pair of brackets? SVX rotors and 300ZX 4 pots?
Got some pics? How is it working?
-ken
Old 01-28-2009, 11:58 AM   #6
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
4pots/2pots, and supposedly there's some Group N 5x114.3 brake rotors meant for just this sort of thing, hidden in the catalog somewhere.
Edit: after looking around, rallispec sells this setup as a kit, and will sell individual rotors too
Edit 2: Also, part #'s from the GroupN tech site for the gravel rotors:
FR: 263004S080 FL: 263004S090
RR: 267004S030 RL: 267004S040
ArcticWolf is offline   Reply With Quote
Old 01-28-2009, 12:08 PM   #7
KNS Brakes
Member#: 125739
2015 WRB WRX
http://www.dirtyimpreza.com/forums/s...ece+rotors+sti
2 piece front rotor to fit the 5 x 114
In the rear Subaru has Gp N 'gravel' rotors in both 5 x 100 and 114 i think - and DBA makes the 5 x 100 version that can be re-drilled
Old 01-28-2009, 07:21 PM   #8
mykrrrr
Member#: 733
'13 Focus ST
I had a 4pot/2pot set up on my '05 STi so I could run 15" wheels for winter. I got the entire set up from Fourstar Motorsports in Ontario Canuckistan.
Everything was straight bolt on. The only thing was the brake bias was very rearward...so biased that my rears wore out much much faster than the fronts. I got replacements from Rallispec. If I kept the set up, I was going to either put a proportioning valve or the proper master cylinder on there.
mykrrrr is offline   Reply With Quote
Old 01-28-2009, 07:24 PM   #9
Lminette
Member#: 138923
2000 2.5RS Coupe
Satin Green Metallic
Hit up Jackson Rally (JacksonRally@Gmail.com)!! He can help you out for sure!!
http://www.dirtyimpreza.com/forums/s...ead.php?t=4118
Tell him Louie sent ya!
Lminette is offline   Reply With Quote
Old 01-28-2009, 07:26 PM   #10
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Good info..guys..appreciate it..
I knew about the 4 pots....thanks..
More concerned about the rotors being 5x114.3 that will fit the 4 pots...can a machine shop redrill the rotors. with accuracy ??? and fitment???
Bill
Old 01-28-2009, 07:30 PM   #11
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I was gonna say - I bet Rallispec would know
Old 01-28-2009, 10:29 PM   #12
jamal
Member#: 71875
98 2.5GT
my wheels fit
no need to redrill anything since subaru makes 5x114.3 rotors for those brakes. You need to get those rotors to clear the hub and rear parking brake anyway.
http://forums.nasioc.com/forums/show....php?t=1615238
jamal is offline   Reply With Quote
Old 01-29-2009, 02:37 AM   #13
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
+1
they have the 5x114.5 GrN rotors, as for the rest - everything bolts on
Hyper is offline   Reply With Quote
Old 02-03-2009, 07:56 PM   #14
Mojambo
Member#: 102581
2006 STI-USDM
SGM
I tried to redrill a 5x100 front rotor, and the inside diameter is too small to fit over the hub. Options are GroupN front and rear rotors. Jackson rally 2pc front rotor, possibly some other 2pc front rotors(DBA) redrilled to 5x114.3.
I'm using a WRX 2 pot sliding caliper up front, but needed to do a little grinding to the knuckle to fit them and also a little grinding of the bracket to clear the larger outter hub/hat dimensions on the front GroupN rotor. Running GroupN rear rotor and Nissan 2 pot rear caliper.
Works gret as a winter setup. Running team Dynamics Pro Race 1.2 15x7
Mojambo is offline   Reply With Quote
Need advice on aggressive wheel/tire fitment Donzo Tire & Wheel 5 05-28-2010 01:35 PM
fitment issues 2009 STi bbs on 2005 STi? 05BlackSTiCarbon Tire & Wheel 20 05-14-2010 04:30 PM
need help on edfc mounting for 05 sti koker3 Brakes, Steering & Suspension 1 04-29-2006 01:47 AM
Need advice on front suspension issue subarules Brakes, Steering & Suspension 2 05-21-2005 11:29 AM
Help: I need advice on fitment of amsoil air filter for MY00 RS Robmat Normally Aspirated Powertrain 7 05-13-2001 03:53 PM
