Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-28-2009, 10:05 AM   #1
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Default 10% ethanol 93 vs no ethanol 93
Hopefully this can stay here since this is where all the dyno tuners post. Now I know if I am mapped with straight 93 and then fill up with 10% ethanol 93 my car will run worse (I've seen it on my knock threshhold map). Question is with a new tune would I be able to get more power out of 10% eth since 10% would need to be richer (like the quenching effect of E85)? It would help me out too because it's easier to find than eth free 93.
rjrutzky is offline   Reply With Quote
Old 01-28-2009, 10:29 AM   #2
OkieSTI
Member#: 185047
2008 STI
Rally blue
All I know on both my Harley motorcycle and my 08 STI, the difference between normal 91 octane gas and 10% ethynol is a big hit on gas mileage (at least 10% or more) so I'm sure your performance will suffer as well.
OkieSTI is offline   Reply With Quote
Old 01-28-2009, 10:58 AM   #3
jays05
Member#: 78165
05 STI 35r + e85
I am interested to know this too... my car was tuned on E10 93oct, and now I found a place that has ethanol free 93oct.
jays05 is offline   Reply With Quote
Old 01-28-2009, 11:01 AM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
is there a difference between cali 91 and az 91?
on my recent trip back to phoenix my knock and egt's were less on az 91 than on cali 91.
Old 01-28-2009, 11:16 AM   #5
JSarv
Member#: 163445
l33t *******
[email protected]
I believe the power increase would be unnoticeable since 93 E10 is what it is, a 93 octane after 10% ethanol, meaning its somewhere around 91 octane but the added ethanol content brings its pump rating up to 93. Yes Alcohol does burn way cooler and has a way higher knock threshold (higher than MBT) but its such a small amount that it wont be noticable.
I run E85 and only had the choice of 93 E10 prior, my fuel trims were always off about 7%, which I believe is the result of 10% ethanol.
I don't think you will see a performance increase, rather a mileage drop if anything. Your IDC will be a bit higher with E10 (if your tuned for it)
just my .02
-Jerod
JSarv is offline   Reply With Quote
Old 01-28-2009, 11:21 AM   #6
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
The mileage should go down a little but you should get a little more power on the 10% ethanol 93 oct. I think this what Buschur uses to push 30 PSI on pump gas, is less prone to knock.
Old 01-28-2009, 11:33 AM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I never found out exactly what the fuel difference was but I will tell you an interesting experience I had. A customer came to me from a rural area of PA and my base map from Wash DC burbs was way too rich. A number of years ago we had a winter blended fuel and a summer fuel but it's been consistent over the last couple years with +10 ethanol. I leaned out the car and finished what I could on the dyno before verifying everything on the road.
Since the gas was too low I had the customer fill up locally and then during the road test it ran about .5-.8 AFR leaner (it's normal to see about a .2-.3 change during real world tuning). This left me scratching my head so I checked for any mechanical issues and I could find nothing. I started leaning things out and the fuel map headed right back to where I had the Element Tuning base map. At this point I knew I was dealing with a gas issue so I sent the customer home with two maps (the dyno tuned map on his fuel, and the road adjusted map for our fuel).
When he got home, filled up on his fuel, and ran a data log for me as we suspected it was .5-.8 richer. He then switched to the map I tuned on his fuel and it was exactly how I tuned it here. The next time he came to see me for tuning he came with extra fuel from his local stations
The bottom line here is don't assume your local gas is indicative of all gas everywhere. This is the reason you never get a perfect base map because we have to add a calculated amount of slop to deal with these variations in fuel.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 01-28-2009, 11:46 AM   #8
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Yeah I always bring my local gas, just wasn't sure if I should bring the local 10%.
I actually came 10 hours to see you, Phil, with 5 gallons of Tennessee gas and 5 of 110. I need to come back again. It was worth the drive.
I'm probably gonna do 10% this time just because of it's availability. Any power increase will just be bonus.
Old 01-28-2009, 12:08 PM   #9
Element Tuning
Member#: 54918
673 WHP Element
That story is probably why I told you to bring gas
Old 01-28-2009, 12:34 PM   #10
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
Thanks,
Phil
hahah i was already planning on doing that for my next tune coming up, getting down there with enough fuel from the shell i always get my gas and then bringing 5gal container with extra just incase...
to answer the op's question, if indeed the fuel is making the car run rich it could possibly rob the motor of some power
blowbyu24 is offline   Reply With Quote
Old 01-28-2009, 02:59 PM   #11
Clark Turner
Member#: 178047
02 WRX STI Spec C
The ethenol fuel has a lighter specific gravity. The tune should be able to handle this kind of change though. If you are tuned on the edge you might need to add a bit more fuel to the map with the lighter fuel.
AZ and Cali Gas are different. My experience is that in the winter our AZ gas is a bit better then California. In the summer, we switch to "Arizona Summer blend" fuel. This fuel is the worst I have tuned.
Clark
Clark Turner is offline   Reply With Quote
anyone try the chevron no-ethanol 92 in Talent, Oregon? valueape North West Impreza Club Forum -- NWIC 14 07-16-2010 08:24 PM
AMR: 2008 STi - PURE 93 Octane, NO METH, NO RACE GAS, 3550lbs = 10.90et!!! AMR Proven Power Bragging 182 09-19-2009 05:03 PM
10% load tuning...knock no matter what SurfWagon UTEC 23 03-11-2009 03:35 PM
No Ethanol is NOT the answer! chowder31 Political Playground 143 05-09-2007 08:29 PM
Stage1 93 vs. Stage1 93 MT ?? MarkRx AccessPort 8 02-08-2007 05:05 PM
