Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 01-28-2009, 04:08 PM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default The official "I drove through some snow, and now my car shakes" thread
I guess I'll jump on the official bandwagon.
If you just drove through a bunch of snow, didn't hit anything, and now your car shakes going down the road it's most likely the 10lbs of snow you have packed into each wheel.
That is all.
-Clint
ps. Buttdyno should add all these to the suspension sticky so nobody will read them.
Old 01-28-2009, 04:24 PM   #2
SubieTheThird
Member#: 191196
2006 WRX Wagon
Hot tip for removing said snow (because the shaking can get downright violent above 50 MPH or so): drag the brakes for a few minutes, stop the car and then poke it out of the wheels with your wee little fingers, being mindful NOT to touch the rotors while you're in there. Not that I speak from experience or anything...
SubieTheThird is offline   Reply With Quote
Old 01-28-2009, 04:41 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Wait wait wait wait, now just hold on....
Are you actually advocating that someone REMOVE the snow that's causing the vibration?
BRILLIANT!!!!
Old 01-28-2009, 06:14 PM   #4
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Sad but true
john
Old 01-28-2009, 08:06 PM   #5
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
Us in cali do not have the joys of snow. but still enjoy the posts and threads like these.
This thread is hillariousnneses ! !
AbACUZ is offline   Reply With Quote
Old 01-28-2009, 11:27 PM   #6
cprincipe
Member#: 201222
2007 Impreza 2.5i
Grey
This can particularly happen when you drive through snow/slush and then park the car outside where it's below freezing. Everything runs to the lowest part of the rim and re-freezes and the balance is all thrown off. First time it happened to me I about crapped myself.
cprincipe is offline   Reply With Quote
Old 01-29-2009, 12:52 PM   #7
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
man were gettin pounded here in upstate ny with snow. this happens to me every day. whats even worse is all the snow and slush that gets frozen between your tire and fender liners.. you essentially lose suspension. lol
Dubstar112 is offline   Reply With Quote
Old 01-29-2009, 01:21 PM   #8
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
And when you make a sharp turn it sounds like a table saw
And we finally got snow here in Raleigh, 6.5" where I'm at. Hasn't snowed this much in 4 years!!
Superorb is offline   Reply With Quote
Old 01-29-2009, 01:29 PM   #9
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
Subaru Stars
That is all.
-Clint
LOL I wish everything else was this simple
Drive 270 miles northwest to a little town called Mammoth Lakes, then tell me *we* in Cali do not have the joys of snow. *For added fun* - hit up one of the mountain parkinglots about 30-45 mins after the mountain closes within a few days of a storm. Make sure to engage your emergency lights
howfast? is offline   Reply With Quote
Old 01-29-2009, 01:54 PM   #10
Scooby921
Merci Buckets
Member#: 88606
2015 GMC Sierra
'13 JCW
Yes, snow pack ruins fun.
Go inside for dinner. Come out and see 3" of fresh snow in parking lot. Proceed to do stupid things slideways for 10 minutes. Drive home at 45mph on the freeway because I forgot to clean the snow out of the wheels
The effect is less with a smaller diameter wheel. If you run 18's in the winter you're more screwed than the guy running 15's. Rotational inertia has a radius term that is squared. All the more reason to run 15's and used rally tires in the winter!
Oh, and the day after you have all that fun....when your exhaust sounds like its broken because its rumbling under your feet instead of out the muffler, its just the inane amount of snow packed around the trans mount and x-member that has turned to ice and effectively solid mounted the tranny. moar
Scooby921 is offline   Reply With Quote
Old 01-29-2009, 02:47 PM   #11
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
Wouldn't suggest that bolded part, the tires are the same (or harder) as a summer tire. Hockey pucks.
15's and snows? Sure!
ArcticWolf is offline   Reply With Quote
Old 01-29-2009, 04:34 PM   #12
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
I remember the first time this happened. I pulled over and thought that I had a flat. Then it got to the point of I was doing about 50 MPH till the exit ramp and then I used my common sense while debating what it was in a parking lot right off the ramp. knocked the snow out and Fixed! Haha, live and learn!
gr8r rex is offline   Reply With Quote
Old 01-29-2009, 04:36 PM   #13
Butt Dyno
Member#: 17301
is the "dark side"
It happened to me after my first batch of scoobnuts back in January 2003 as well. Further proof that we were all n00bs once
Old 01-29-2009, 05:15 PM   #14
highway_patrol
Member#: 154296
Slow as balls
Ford Ranger
you mean something like my friend watson 29
or me?
highway_patrol is offline   Reply With Quote
Old 01-29-2009, 05:56 PM   #15
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Old 01-29-2009, 06:50 PM   #16
wrxracer519
Member#: 149890
02 WRX
Love this thread. First time it happened to me, wasn't sure what was going on. Got out and pushed all snow ou/off the car and fixed it. Now i keep a bar with a rubber sleeve on it to push the snow/ice out.
I love seeing this \/ and not feeling it shake.
wrxracer519 is offline   Reply With Quote
Old 01-29-2009, 08:07 PM   #17
mdungelman
Member#: 97251
'13 Impreza 2.0i
Can TiC design a tool specific for cleaning snow out of my steelies? Pretty please!
mdungelman is offline   Reply With Quote
Old 01-29-2009, 09:04 PM   #18
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
wow, i thought i was alone in this matter. i felt like an idiot when i realized what the vibration was from.
ravenlunatic is offline   Reply With Quote
Old 01-30-2009, 04:02 AM   #19
DoucheAlmighty
Member#: 161492
2004 dubyarex 220whp
at 6000ft WRB!!!
hahahaha yes! every winter day for two years this has happened to me in CO and im not so much alone anymore. Most of my buddies drive fwd cars thinking an e-brake 180 is the same as drifting so you can imagine my reaction when we start going on about my car being the only one with snow caked in its rims after a drift session ill have a rally video up soon to demonstrate this phenomenon...
DoucheAlmighty is offline   Reply With Quote
Old 02-09-2009, 08:08 PM   #20
nix-hex
Member#: 67809
1999 2.5 RS coupe
get out the old water hose. best re-balancing tool ever for snow packed rims
nix-hex is offline   Reply With Quote
Old 02-10-2009, 01:38 AM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I've got one I'll sell you!
Williaty Official Poking Stick
1" square, 2' long long-grain, old growth oak
Oiled to a light golden color for that JDM look
Lacquered to prevent weight gain from water absorption
NOW ONLY $29.95 OR THREE EASY PAYMENTS OF $19.95!
Old 02-10-2009, 02:44 AM   #22
BugeyedMonster
Member#: 137689
2002 WRX Sedan
MBP
^^^^ ZOMG I'LL TAKE THREE!!
Also, payment plan so i can save money pls.
BugeyedMonster is offline   Reply With Quote
Old 02-10-2009, 09:50 AM   #23
Butt Dyno
Member#: 17301
is the "dark side"
How does Billy Mays feel about it?
Old 02-10-2009, 10:45 AM   #24
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Hahahaha
OR that guy that does the slap chop, gawd I can't stand him.
Old 02-10-2009, 08:43 PM   #25
don's scoob
Member#: 165010
02 WRX
psm
Draging the brakes only ever got the fronts for me. I usually just take the handle of my snow scrapper to get the rears.
don's scoob is offline   Reply With Quote
Drove from MD to VT, now my car smells like gas sg_halvorsen Built Motor Discussion 13 01-05-2010 04:18 PM
I'm trendy, so here are some snow pictures of my car too Louros Member's Car Gallery 11 01-26-2005 02:21 PM
Stupid me. Forgot to put parking tag on and now my car is gone. Snoopy Off-Topic 16 01-05-2005 03:08 PM
thread of the dude who drove through a house and two fences! slorex General Community 6 11-29-2004 07:20 PM
The Official "Is Jiffy to good for NASIOC now that he has a girlfriend" Thread DILLIGAF Racing Mid Atlantic Impreza Club -- MAIC 42 05-31-2004 05:39 PM
