Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 01-28-2009, 07:19 PM   #1
moorebl
Member Sales Rating: (77)
Member#: 59238
Default Hallman Rx In Car Boost Controller Kit $135 new
this kit is bran new i tried to install it in my sti but i didnt want to drill through my firewall. someone might find a possible way to mount it but iam not gonna try. comes with everything from hallman. i paid 175 shipped. i will do 135 shipped.
located in suffolk virginia
The Hallman EVOLUTION RX Kit uses the same valve as the Pro RX Kit, and has the same features (INCLUDING A CERAMIC BALL), but ALSO is integrated into a self-contained cockpit controller cable system. It also includes a mounting bracket, 3 feet of hose, a hardware kit, and specific installation instructions. The cable is 72 inches in length. Available in Red or Black. The self contained cable system allows you to adjust boost from inside your car! This new system makes it very easy to set initial desired boost level... there is no need to stop the car, pop the hood, adjust the valve, then drive to see what boost level it is set at (and possibly repeating this process several times). Sitting at a red light and want to turn up the boost? Its just an arm's reach away. This unique cable system uses a sheathed cable that does not twist or bind. There is no "lateral torque". This means that you achieve consistent results when you turn your inside-the-cockpit adjustment knob. Just as precise as if you were turning a knob on the controller itself, as with the Hallman Pro or Hallman Pro RX kits. Achieve the convenience of an electronic system (without the expense or complexity of electronics), with the reliability and precision of a ceramic ball manual boost control system!
moorebl is offline   Reply With Quote
Old 02-27-2009, 07:19 PM   #2
moorebl
Member#: 59238
bump today
Old 03-27-2009, 02:06 PM   #3
moorebl
Member#: 59238
bump someone must need one of the best controllers on the planet
f/s hallman pro ex in cabin boost controller tbag050 Engine/Power/Exhaust 0 04-10-2009 09:26 PM
Hallman Rx In Car Boost Controller Kit $150 new moorebl Engine/Power/Exhaust 2 03-27-2009 02:05 PM
F/S Hallman pro in cabin boost controller tbag050 Engine/Power/Exhaust 2 03-27-2009 12:52 PM
Hallman Rx In Car Boost Controller Kit moorebl Engine/Power/Exhaust 0 12-06-2008 05:22 PM
MD FS: BNIB Hallman Pro Series Manual Boost Controller LeeC MAIC Private Classifieds 6 07-28-2008 08:02 AM
