Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 01-28-2009, 11:35 PM   #1
traskw
Member Sales Rating: (7)
Member#: 9604
2005 LGT '94SS MR2
AtlanticBlue, Red, Silver
Default For Sale: Wilwood 4 Pot Brake kit - 2 Piece Rotors - 2 sets Pads - Stainless lines
SOLD!
traskw is offline
Old 01-29-2009, 07:22 AM   #2
keithdsny
Member#: 83757
2002 02 wagon hybrid
WR blue pearl
is it 5x100 or 5x114?
keithdsny is offline
Old 01-29-2009, 01:04 PM   #3
traskw
Member#: 9604
2005 LGT '94SS MR2
5x100
There's at least 85-90% pad life on the track pads, which were never used on the track and about 95%+ on the ceramic pads. Just the front set. I'm switching in order to compete in Solo Stock which does not allow two piece rotors.
traskw is offline
Old 01-29-2009, 03:48 PM   #4
blkgm8
Member Sales Rating: (4)
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
What size are the rotors? Thanks
blkgm8 is offline
Old 01-29-2009, 04:06 PM   #5
traskw
Member#: 9604
2005 LGT '94SS MR2
12.2" rotors, will allow for most 16" and up wheels.
traskw is offline
Old 01-29-2009, 11:03 PM   #6
traskw
Member#: 9604
2005 LGT '94SS MR2
Just had the rotors "scuffed" at Pheonix Performance (The same that has SCCA GT Series Cars)
traskw is offline
Old 01-30-2009, 10:19 PM   #7
traskw
Member#: 9604
2005 LGT '94SS MR2
Bump.
traskw is offline
Old 01-31-2009, 10:39 AM   #8
traskw
Member#: 9604
2005 LGT '94SS MR2
Headed to the Philly Auto Show for the day.
traskw is offline
Old 01-31-2009, 08:16 PM   #9
traskw
Member#: 9604
2005 LGT '94SS MR2
Back now.
traskw is offline
Old 02-06-2009, 12:09 AM   #10
penderperson
Member Sales Rating: (15)
Member#: 172370
2006 STI
what diameter are stock wrx rotors?
penderperson is offline
Old 02-06-2009, 12:20 AM   #11
traskw
Member#: 9604
2005 LGT '94SS MR2
11.4 '02-'05 2-POT
11.5 '06-'07 4-POT
11.6 '08-'09 2-POT
traskw is offline
Old 02-06-2009, 03:22 AM   #12
rafacz2002
Member Sales Rating: (6)
Member#: 169957
2002 impreza wrx
black
i wish i had the money
free bump
rafacz2002 is offline
Old 02-10-2009, 10:09 AM   #13
rendog24
Member Sales Rating: (53)
Member#: 125463
what are the replacement ring rotors costing for this app? and how much of a lip is there on the rotor/measurement of thickness? thanks.
rendog24 is offline
Old 02-10-2009, 01:30 PM   #14
traskw
Member#: 9604
2005 LGT '94SS MR2
They can be turned at least three times, replacement rotor rings are $125 to $165 for a pair depending on where you get them.
traskw is offline
Old 02-10-2009, 03:49 PM   #15
penderperson
Member#: 172370
2006 STI
can you weigh the rotors and calipers please? curious how they compare to stock.
also are they a custom pad shape? will most brake companies be able to make a pad for them?
Old 02-10-2009, 06:27 PM   #16
traskw
Member#: 9604
2005 LGT '94SS MR2
The aluminum hats and calipers make them quite a bit lighter than stock. Wilwood makes about a dozen different pad compounds so I don't know why you'd want to have custom ones made.
traskw is offline
Old 02-10-2009, 07:08 PM   #17
penderperson
Member#: 172370
2006 STI
Racing brake has rotors that are 12.3 lbs each and i was wondering if these would save more or less unsprung weight.
As far as compounds go...they'd go on my daily driver, so they have to go down to subfreezing without any warm up or noises and they are for a very competitive STX autocross car, so they need to stop well, but won't have to deal with as much heat as a track pad. I'm using carbotech bobcats right now and they work amazingly, so i'd prefer to continue with them rather than guess on another company's compounds.
Old 02-10-2009, 08:49 PM   #18
traskw
Member#: 9604
2005 LGT '94SS MR2
The Q compound sounds like the right choice for you, which are included along with the BP-10's, you'd don't have to guess, wilwood has all the data:
traskw is offline
Old 02-12-2009, 06:53 PM   #19
traskw
Member#: 9604
2005 LGT '94SS MR2
For those wondering why these are not drilled, these are the more expensive GT series directional vaned rotors which features asymmetrical slotting. If you want drilled and slotted, the SRP rotors are available for about $100 a pair, however, like the stock rotors they are straight vaned. The GT directional will handle more heat than the drilled and slotted SRP, which is listed as a street rotor.
traskw is offline
Old 02-12-2009, 06:56 PM   #20
traskw
Member#: 9604
2005 LGT '94SS MR2
VS.
traskw is offline
Old 02-14-2009, 12:59 PM   #21
traskw
Member#: 9604
2005 LGT '94SS MR2
Lots of interest but no takers yet.
traskw is offline
Old 02-14-2009, 06:58 PM   #22
Todd TCE
Member Sales Rating: (1)
Member#: 90575
This is a conventional Wilwood LBK. The rotors can be had in Plain, GT, or SRP drilled fashion as well as both 12.0 (for 15" wheels) and 12.2" (for 16" wheels) diameters.
The calipers are radial mount DyanPro parts with (as mentioned) a host of pad options, although not all compounds are produced for this caliper. It could be converted to an alternate stud pattern but the mounts are not known to fit the later steering spindles.
Depending upon the model the rotor rings will weigh about 11lbs ea plus hats and hardware. Combined perhaps 12lbs each.
bump
Todd TCE is offline
Old 02-16-2009, 11:39 PM   #23
traskw
Member#: 9604
2005 LGT '94SS MR2
The 4-pot fully dust booted billet calipers, two piece GT rotors, the stainless lines, 2 sets of pads, brackets- PM me with BO
traskw is offline
Old 02-17-2009, 02:52 AM   #24
traskw
Member#: 9604
2005 LGT '94SS MR2
FYI, The black on the left top piston is from the BP-10 pads, nothing that won't brush off.
traskw is offline
Old 02-17-2009, 03:05 AM   #25
traskw
Member#: 9604
2005 LGT '94SS MR2
Other than some dust these are in perfect shape.
traskw is offline
Closed Thread
FS: Wilwood 4 Pot Big Brake kit - 2 Piece Rotors - 2 sets Pads - Stainless lines traskw Suspension/Brakes/Handling 17 03-10-2009 08:08 PM
For Sale: JDM 4 Pot Calipers, Hawk HPS Pads, SS Lines, RS 6 spoke wheels! wirolla MWSOC Private Classifieds 31 06-18-2007 03:23 PM
FS: Perrin/Wilwood 4 pot brake kit!!! MK19_ Private 'For Sale' Classifieds 6 07-29-2005 09:38 AM
Need help: Replacement rotor for Wilwood 6/4 pot brake kit bwco Brakes, Steering & Suspension 4 10-03-2004 12:08 AM
Which 4 pot brake kit has 14" rotors front and at least 12" rear AWDBOY Brakes, Steering & Suspension 5 04-25-2003 11:38 PM
