Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 01-29-2009, 11:18 AM   #1
ten80
Member Sales Rating: (124)
Member#: 53625
00 16' FXT
out of town till March 23rd with NO internet access. Please wait to PM me till I return, thanks!
Finally organized all the parts I have from swaps, installs, and trades. All prices are OBO and include shipping in the lower 48 states. If you are in WA, OR, or ID, I can take a little extra off the price because shipping will cost me less. I can also reduce cost if multiple items are purchased or items are picked up in the Seattle area.
Whiteline Bushings and goodies
• A. 05+ WRX & STI Steering rack bushings. Brand new. $45 SOLD
• B. Whiteline Motorsport ALK kit KCA319M. Brand new, in bag. Fits 93-01 Impreza, 99-00 Forester, 1990-2004 Legacy & Outback. $170
04 STI Struts (V8 USDM). Will fit 02-07 Impreza sedan and wagons (wagons lose a little negative camber but there are no issues). All struts have been cleaned, disassembled, re-greased with suspension grease, and carefully re-assembled. I check pistons, seals, and bushings for wear. In addition, I test the dampers for leaks and proper operation. One nub has been cut off the rear bumpstops and two off the front to increase suspension travel. I guarantee that NONE WILL CLUNK after installed.
proof of bumpstop shortening:
• 1. 04 STI struts, ~40k miles. 8.5/10 condition with very little corrosion. SOLD
• 1a. One Right rear 05-07 (v8-v9) STI strut. 7k miles, like new. $85 shipped
• 1b. One front left 02-03 (V7) STI strut. NEW. $75
• 1c. 04 STI rear struts, pair. 30-40k miles and in good condition. New grease and shortened bumpstops. $150 shipped
misc STI strut inserts Will fit 02-07 STI (V7-V9) struts.
• 2. 04-07 REAR V8-9 inserts. ~90k miles and in great shape considering the mileage. Very little surface wear and no leaks with a good gas charge. $15 each, $28 pair
Springs
• 3. 04-07 V8/V9 STI springs. Full set, good condition 3k miles, LIKE NEW. SOLD
• 4. 04-07 WRX sedan rear springs. Good condition, 60k miles. $25
• 4.a 04-07 WRX Sedan (AT) front and rear springs, $45
• 4b. 02-03 WRX sedan front and rear springs, $45
Top hats (aka strut tops)
• 6. 04-07 OEM STI front tophats 2 pair. Will fit 93-07 impreza, legacy, forester, etc. Slightly firmer than those found on 05-07 non-turbo impreza, 02-08 forester. $35 pair
• 7. 04-07 OEM STI rear. Will fit 02-07 impreza, 02-08 forester. SOLD TO TWRC & d.sweet86
• 8. 02-03 Impreza/99-01 Forester rear. 1 pair. Will fit 02-03 impreza springs. $30 pair (First pair sold to Trainable)
• 8b. 97-99 outback/legacy rear tophats. 1 pair, $30
Spring seats and cushions
• 9. 93-07 impreza front metal spring seats. Fits on top of front springs below tophats. $6 each
• 10. 93-07 front spring cushions. Fits between spring top and metal spring perches. $7 each
• 11. 02-07 rear spring cushions. Fit on rear struts under springs. $5 each
Misc nuts and bolts
•12. strut top nuts, tophat nuts, lower strut bolts/nuts, conical spacers, spring perches, and rubber spring isolators/cushions. PM me, I have a big pile.
•13. Stock 02-07 WRX rear control arm bushings. 50k miles. $15
lateral links
•14. 93-07 impreza GC/wagon lateral links SOLD
• 15. 02-07 Forester lateral links $40
Axles
•16. GC/wagon rear axles. 183k miles but boots & CVs are in good shape. $35 each or $60 pair
Diffs
•17. 4.11 rear open differential. 183k miles, no leaks and functions normally. I can pull the guts out if you just want the shell. Will sell for just the cost of shipping, PM me with ZIP code for an accurate price.
Pictures
I can provide pictures of parts not pictured upon request.
B.
1a.
1b.
6-11.
13.
14 & 16.
15.
ten80 is offline   Reply With Quote
Old 01-30-2009, 04:24 PM   #2
CoolRex
Member Sales Rating: (11)
Member#: 85813
2002 E46 M3
2006 RC51
Why are the fronts cheaper than the rears? I'd think the fronts are pricier than the rears.
CoolRex is offline   Reply With Quote
Old 01-30-2009, 04:58 PM   #3
ten80
Member#: 53625
00 16' FXT
I assume that you are referring to the 04+ tophats I have listed? If so, then my pricing is justified by the higher demand and rarity of 04-07 impreza rear tophats, whereas the fronts have the same design used between 93-07 (with minor variances in rubber durometer) and are very easy to track down. I also seem to be perpetually collecting front tophats.
17.
Old 01-30-2009, 05:00 PM   #4
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Gotcha....I need a set of the 04 rears. I will contact you once I order my new suspension if my buddy doesn't give me his.
Old 01-30-2009, 05:53 PM   #5
mdungelman
Member Sales Rating: (25)
Member#: 97251
'13 Impreza 2.0i
PM sent.
mdungelman is offline   Reply With Quote
Old 01-30-2009, 06:58 PM   #6
tangmonkey
Member Sales Rating: (10)
Member#: 114234
I've got some Eibach Prokit springs for an 04 STi on my 06 WRX, will I need tophats if I get the 04 STi struts?
tangmonkey is offline   Reply With Quote
Old 01-30-2009, 06:59 PM   #7
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
No your stock ones will work.
Old 01-30-2009, 10:44 PM   #8
BeBop86
Member Sales Rating: (51)
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
You don't have 04+ rear sway bar mounts do you?
BeBop86 is offline   Reply With Quote
Old 01-31-2009, 01:27 AM   #9
ten80
Member#: 53625
00 16' FXT
Exactly!
no, but subarugenuineparts.com has them for pretty cheap if I remember correctly.
Old 02-04-2009, 12:59 AM   #10
black&whiteday&night
Member Sales Rating: (3)
Member#: 202006
Subaru Stars
I pm'ed you but i dont think it went through so:
dibbs on your last set of 04-07 OEM STI rear top hats
& your STI springs... you didnt put a price for these but i will give you 50$ that seems to be the going rate.
ALSO you only have one Whiteline Anti lift kit listed but you have 2 pictured the one in the photo numbere
black&whiteday&night is offline   Reply With Quote
Old 02-04-2009, 10:20 AM   #11
ten80
Member#: 53625
00 16' FXT
I just replied to your PM!
that's exactly what I'm looking to get
Only one ALK kit listed. The top picture is of the steering rack bushings:
B.
Old 02-04-2009, 11:35 AM   #12
eh1525
Member Sales Rating: (1)
Member#: 116619
2005 Impreza RS
Crystal Grey
how much would it be for two fronts and two rears fully assembled? its for an 05 RS
eh1525 is offline   Reply With Quote
Old 02-05-2009, 04:27 PM   #13
MyRedScooby
Member#: 73166
2006 Acura TL 6-SP
Anthricite
Bump and PM
MyRedScooby is offline   Reply With Quote
Old 02-06-2009, 12:31 AM   #14
cazwrx187
Member#: 176592
2002 WRX-Sold
1998/04 Unicorn RSTi
you have pm
cazwrx187 is offline   Reply With Quote
Old 02-09-2009, 04:23 AM   #15
ten80
Member#: 53625
00 16' FXT
Bump, still have a BIG pile of parts!
Old 02-11-2009, 09:18 PM   #16
ten80
Member#: 53625
00 16' FXT
Bump, still have many, many, many parts, including a set of MINT condition 05 STI struts
Old 02-16-2009, 11:52 AM   #17
ten80
Member#: 53625
00 16' FXT
Bump for a new week. Don't be afraid to make reasonable offers on these parts!
Old 02-18-2009, 06:51 PM   #18
roninsoldier83
Member Sales Rating: (16)
Member#: 61966
2016 Golf R & 13 WRX
Sold: 06 STI & 15 WRX
Sent you a PM over on IWSTI
roninsoldier83 is offline   Reply With Quote
Old 02-20-2009, 12:06 PM   #19
wild willey
Member#: 177194
you need to clear your pm's
wild willey is offline   Reply With Quote
Old 02-21-2009, 12:51 AM   #20
ten80
Member#: 53625
00 16' FXT
sorry about that, you can shoot me a PM now
Old 02-23-2009, 09:15 PM   #21
cazwrx187
Member#: 176592
2002 WRX-Sold
Pm about to be sent regarding 04-07 V8-9 inserts. I will take them both asap!
Old 02-24-2009, 01:10 AM   #22
1999impeza2.5rs
Member#: 112892
1999 Impreza 2.5RSt
Any more sti springs?
1999impeza2.5rs is offline   Reply With Quote
Old 02-24-2009, 01:48 AM   #23
ten80
Member#: 53625
00 16' FXT
Nope, not for a while. PM's replied to!
Old 02-28-2009, 11:15 AM   #24
SocalRChu
Member Sales Rating: (2)
Member#: 80951
Got the parts, they were in excellent condition. Thanks a bunch!
SocalRChu is offline   Reply With Quote
Old 02-28-2009, 12:46 PM   #25
ten80
Member#: 53625
00 16' FXT
Very welcome!
04 STi Struts, Tophats, and Springs bulletproof4130 Suspension/Brakes/Handling 12 01-26-2011 05:53 PM
FS: 04 STi struts and LCA bushings mhspyder97 Suspension/Brakes/Handling 5 06-16-2009 01:39 PM
FS: 04 STi struts F/R, Prodrive Blue springs, Group-N front tophats - PICS phlegmon Suspension/Brakes/Handling 13 04-08-2008 12:26 PM
FS: 04 STi struts & tophats for cheap wrxmyers Tri-State Area Forum 9 05-12-2005 01:05 AM
FS: 04 STi struts & tophats/ whiteline sr bshngs for cheap wrxmyers Tri-State Area Forum 5 04-28-2005 09:29 PM
