Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-29-2009, 11:19 AM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default Turbo water pump
My application requires me to have the water pump inlet come out the front like a WRX. Will the WRX Water Pump work on a RS25 block?
Odyknuck is offline   Reply With Quote
Old 01-29-2009, 02:01 PM   #2
master c
Member#: 168226
yes it fits perfectly - just built my block with the turbo water pump.
master c is offline   Reply With Quote
Old 01-29-2009, 09:41 PM   #3
Odyknuck
Member#: 192866
2006 Impreza
Thanks Much. They looked Idenical however befor I bought one I needed to be sure.
Old 01-29-2009, 10:14 PM   #4
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
are you talking about your header setup ? will you be replacing your xmember, or notching it ?
IllNastyImpreza is offline   Reply With Quote
Old 01-30-2009, 08:49 AM   #5
Odyknuck
Member#: 192866
2006 Impreza
This is on my Offroad project Im working on right now. However it is still a frame clearence Issue. I am sure I will have the same issue when I Turbo my 06 Imprezza however that may go an STI swap.
Turbo water pump on EJ18 ?'s EJ18S Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-15-2008 11:56 PM
Return to turbo water pump? mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 0 04-12-2007 12:14 PM
Ej20G Oil Cooler / legacy turbo water pump / oil pump supermoose Private 'For Sale' Classifieds 2 09-29-2005 12:06 PM
Legacy Turbo Water Pump/housing White 2.5rs Private 'Wanted' Classifieds 1 10-22-2003 01:19 PM
EJ Turbo VS EJ non Turbo water pump DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-29-2002 03:36 PM
