Old 01-29-2009, 11:25 AM   #1
DrewDeezy
Member#: 160279
2004 STi
Crawford Performance
Default My First and *Last* Experience with Subaru's New Oil Filter
First off, this is only my experience. Ive heard both positive and negative things from this filter
So the time comes to change my oil. I currently have 67k miles on my 2005 Subaru WRX. Ive changed my oil myself for nearly the entire length of my car ownership which adds up to about 43k miles. I think there has only been one time where I havent changed my oil due to time constraints.
Anyways, I have a friend of mine, also a member on the forums, go to the Subaru Dealership locally and pick up 2 oil filters and crush rings. Nothing out of the norm. He comes over and hands them to me. They are blue. NOW I've already heard bad things about these filters, but ignoring that because I figured hey they had a problem, I doubt it will happen to me.
Doing my normal routine of removing the drain plug and letting the oil drain out, I then remove the oil filter (the old black one) *The seal is still on this filter for those of you who are wondering*. After waiting about 5 minutes for all the oil to drain out, I re-attach the drain plug with the new crush ring, and then unwrap the new oil filter. I prime the filter by putting a small amount of oil in it as well as a ring around the seal.
I go ahead and screw the filter on *being careful not to cross thread*and use a pipe wrench to tighten it to where I cant move it with my hand.
Now time to fill the car back up with royal purple. After filling the car with oil, i start it up and check the oil level. Looks a little low, so I add some more. OK car is good. Turn off the car and remove rear tire stops.
I then proceed to pull my car back out into the street so we can do my other buddies WRX next. Park the car and get out and look behind me...
I pulled the car 3/4 way out of the driveway and then there is a huge splatter of oil. I mean ALOT
Check under the car... yep there is oil EVERYWHERE under my car. WTF??!!?
So... Realizing that its possible if i had my car on for 5-10 more seconds i probably would not have an engine, im a little pissed... There is $60 bucks of oil all over the ground. All over my driveway, and a nice trail to where my car is currently sitting.
So obviously there is no way I'm turning on my car. With the help of my buddy , we push my car back into the driveway, slipping on the oil trying to push my car back up into the driveway. I dont bother jacking the car up because i dont need to, to reach the oil filter. Obviously its the culprit because there is oil dripping all down the side. I grab the pipe wrench to unscrew it, and low-and-behold, the seal failed causing me to nearly loose my engine due to oil starvation.
So, Subaru this is me Please fix your oil filters, or go back to selling the black ones, for they have worked great for me in the past. I also am aware that these have a smaller filter inside of them.
DrewDeezy is offline   Reply With Quote
Old 01-29-2009, 11:59 AM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Please post pictures of the "failed seal"
The new filter bottoms out quicker than the old filter and you dont need a pipe wrench to tighten them. HAND Tight
Old 01-29-2009, 12:02 PM   #3
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
i'm with you.
Bishop is offline   Reply With Quote
Old 01-29-2009, 12:05 PM   #4
method
Member#: 57849
2008 WRX
You should snug the filter then do a quarter to third turn more by hand. Only use a wrench (if you have to) to remove the filter, don't use it to put it on!
method is offline   Reply With Quote
Old 01-29-2009, 12:14 PM   #5
zomg
Member#: 183407
'04
WRB STi/goldies/wingless
And what exactly do you expect a rubber seal to do when its been torqued, not by hand, but by a so called "pipe wrench" if this was indeed the culprit?
zomg is offline   Reply With Quote
Old 01-29-2009, 12:21 PM   #6
DrewDeezy
Member#: 160279
2004 STi
I'll try and get pictures. I gave the oil filter back to friend to return to subaru.
I do hand tighten it, then give it a snug tight with pipe wrench
I snug by hand and then give it a snug tight with pipe wrench
Never had a problem before doing this method. snug tight with hand and then quarter of a turn with pipe wrench
Old 01-29-2009, 12:23 PM   #7
zomg
Member#: 183407
'04
so did the seal split or break or was it obviously defective?
Old 01-29-2009, 12:28 PM   #8
DrewDeezy
Member#: 160279
2004 STi
seal was split. I'll have pictures up by Monday as I'm heading out of town here in about 2 hours and Don't have time to go and get the filter and take pictures
Old 01-29-2009, 12:31 PM   #9
JDM 3SGTE
Member#: 35479
keep your eye on autozone ads. couple times a year they sell 5 gal of german castrol and a mobil 1 filter for $35.
JDM 3SGTE is offline   Reply With Quote
Old 01-29-2009, 12:44 PM   #10
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I have never done anything more than put the filter on hand tight. It won't fall off....
medamullet is offline   Reply With Quote
Old 01-29-2009, 12:58 PM   #11
supermarkus
Member#: 6971
2008 WRX STi
SSM
This is definitely operator error. It sucks that the new filter bottoms out earlier, but they've never needed any more than snug + 3/4 turn on any of my imprezas.
the last time I changed my oil, actually went hand tight to first contact with the o-ring, then 3/4 turn. I've never needed a wrench to get it any tighter.
supermarkus is offline   Reply With Quote
Old 01-29-2009, 01:20 PM   #12
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Has anyone mentioned that you overtightened the filter? I'll bet dollars to donuts you distorted and/or tore the gasket.
Mike Wevrick is offline   Reply With Quote
Old 01-29-2009, 01:26 PM   #13
640k
Member#: 160315
2008 STI
you're lucky you didn't crimp the filter with that wrench...
640k is offline   Reply With Quote
Old 01-29-2009, 01:26 PM   #14
Feign
Member#: 68604
06 STi
But yet you had the time to post the thread? Without a picture even. Half of the time complainers like yourself never come back with empirical evidence anyway.
But anyway, +1 hojillion on user error.
Feign is offline   Reply With Quote
Old 01-29-2009, 01:39 PM   #15
DrewDeezy
Member#: 160279
2004 STi
yeah granted i may have over tightened it. I can believe that. All I have in my defense is that ive done this same routine many times, and this is the first time this has happened...
And I hate using the Fram filters
Old 01-29-2009, 02:45 PM   #16
DCales
Member#: 131509
2006 Impreza WRX
Pipe wrench = Bad idea
3/4 to 1 turn past snug by hand is more than enough to seal the filter. And you cant point the finger at Fram. Many MILLIONS of people have used their filters for years without any problems including myself. Worst case take pictures and see if Subaru will help you out.
DCales is offline   Reply With Quote
Old 01-29-2009, 03:23 PM   #17
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
As everyone else already said, THIS is your problem!
This is another problem, we'll deal with this at a later time.
RonJitsu is offline   Reply With Quote
Old 01-29-2009, 04:38 PM   #18
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
^^^This. With a Fumoto valve, you can do an oil change on a WRX without any tools (other than something to catch the used oil), although I wish I'd taken my aluminum skidplate off before the last change.
Good golly, a pipe wrench?
Coati is offline   Reply With Quote
Old 01-29-2009, 04:42 PM   #19
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Thats right. A pipe wrench!
Old 01-29-2009, 07:29 PM   #20
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
obviously user error.
LO and behold....
and it's lose, not loose. You don't seem that bright, given "that's the way I've always done it." Well, you've always done it wrong.
Old 01-29-2009, 07:43 PM   #21
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
What I think is interesting about this thread is this:
- He has been doing it this way on his car for QUITE A WHILE. Now, he uses the same procedure, and the filter fails. I am sure he is not wrenching down on it more than 20-25 ft/lbs, so the mean margin to failure is quite low.
I am waiting for pictures of this failure as well.
- dow
dowroa is offline   Reply With Quote
Old 01-30-2009, 01:14 AM   #22
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
- dow
If he's been doing it for "quite a while" - then this is has been a disaster just waiting to happen.
only 20-25 ft lbs with a pipe wrench? I'd bed it was alot more than that.
+1 for pics...
Old 01-30-2009, 01:26 AM   #23
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
hand tighten only!!!!
djerickd is offline   Reply With Quote
Old 01-30-2009, 01:48 AM   #24
HiTechOilCo
Member#: 156731
DrewDeezy;25375937]
...So the time comes to change my oil. I currently have 67k miles on my 2005 Subaru WRX...
...Now time to fill the car back up with royal purple.
If you look on the back of that oil bottle, you will see that the API recommends SL rated oils, (like RP 5W-20, 5W-30 and 10W-30 with their SL rating ), for 2004 and previous vehicles. The API rating that superceded the API SL rating, is API SM. So the API SL rating is an old rating from almost 5 years ago. If you go to an auto parts store and look at all the oils offered there, you will find that virtually all of them and even the low priced house brand oils, have the modern and up to date API SM ratings. I personally think you would do well to use the more modern API SM rated oils.
Sorry to hear about your disaster, but looking on the bright side, at least the oil filter gasket didn't fail when you were driving down the highway at 65 mph and had an engine blow because of it.
HiTechOilCo is offline   Reply With Quote
Old 01-30-2009, 03:11 AM   #25
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Good point.
There is a recent thread around here (or BITOG) that has response letters from RP about why they do not have the most current approval. Basically they said that they'd have to downgrade their oil to meet the new energy/catalyst conserving specs...
Doesnt matter to me though, I wouldnt run it either way...
My first and last "new" car. livnlegacy Texas Impreza Club Forum -- TXIC 48 04-29-2007 09:40 PM
Trouble with new oil filter 15208AA09A - DETAILS INSIDE SubaruGenuineParts Warranty Issues & SOA Problems 468 04-22-2007 03:41 AM
My first and last winter shoot playboy Member's Car Gallery 7 02-22-2007 12:00 AM
My 05 STi leaked oil with the new oil filters SinisterMinister Warranty Issues & SOA Problems 3 12-29-2005 05:57 AM
My first and last experience with World One and TurboXS (RE: Melted Bumper) MontrealSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 10-12-2003 04:30 PM
