Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 01-29-2009, 01:18 PM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Perplexed with Turbo Choice
So i've been looking around @ different turbo options, somewhat understanding what the different porting/compressor upgrades do, but not sure whats right for me.
The turbo would be going onto the following engine
EJ20G V2
816cc injectors
3" Turboback
Apexi Intake
FMIC
Walbro
Tuned on Microtech EFI
with a goal in the 370 crankish plus area (290-300 whp)
I currently have the TD05-16G that came stock, and am considering a bunch of options, Keep it stock and just raise boost to reach my goals? Port and Polish? 18g compressor? 20g compressor? Combination?
What do you think would work best, this is a DD / AutoX so slighly faster spool would be nice, but not totally necessary. Preferably would like to retain my current turbo and just have work done to it if needed, but what do you guys suggest.
I have the small td05-16g with the 90 degree inlet.
JDMFLCL is offline   Reply With Quote
Old 01-29-2009, 01:24 PM   #2
DSM_Outback
Member#: 56345
93 Swapped L
Green
Keep the 16G but have someone like FP, Blouch or Deadbolt work it over.
DSM_Outback is offline   Reply With Quote
Old 01-29-2009, 02:14 PM   #3
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Your 16g is not very small.... I wonder how anyone can classify it as the small 16g when they dont even sell it separetely anywhere. The small 16g sold everywhere is not your turbo.... it may or may not have the same compressor as the commercial small 16g, someone would need to measure inducer and exducer between the two... but there are other important differences between the two that affect flow and spool time such as comp and turbine housing design. That being said.....
Keep the 16g and dont do anything to it if you plan on auto x.
You want the absolute best feedback and spool up with this type of competition. Going bigger is only going to increase lag...
Your 16g is a very capable turbo...Your car is light, I would still look for ways to lighten the car, and with your listed mods you will be able to get around 350hp or so on pump and upper 3's on race gas or meth.
Again... this is being said after reading that you want to auto x the car.
..... now if you had said drag race...... ehhhh
blkgm8 is offline   Reply With Quote
Old 01-29-2009, 04:55 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Don't change your turbo. Do everything else you have listed as upgrades and puch the Td05 as far as it will go. If you aren't happy at that point, reconsider turbo options.
Old 01-29-2009, 04:57 PM   #5
JDMFLCL
Member#: 180513
Baby Baby C'mon!
ofc, and in regards to the other "thing" i'll get on it later today
Old 01-29-2009, 05:40 PM   #6
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Microtech uses MAP instead of MAF?
rob is offline   Reply With Quote
Old 01-29-2009, 06:45 PM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
idk, the guy im buying it from had it on a v2 ej20g.
Old 01-30-2009, 02:55 AM   #8
GShinji
Member#: 30720
just curious, what injector duty cycles are you getting on your 816's. I have a set but i think they would be too far below the efficiency range on a 16g. or any reasonable turbo upgrade.
GShinji is offline   Reply With Quote
Old 01-30-2009, 12:27 PM   #9
JDMFLCL
Member#: 180513
Baby Baby C'mon!
havent bought them yet, looking at a few different pairs of them. So you dont think they would work?
Old 01-30-2009, 01:28 PM   #10
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
If it runs the MAF, which I doubt, you will need to add a larger MAF to your list.
-Rob
Old 01-30-2009, 02:16 PM   #11
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
They will probably work but that's a lot of injector for your setup and goals. I've got 650a in mine with the same turbo and a FXT TMIC and I don't expect to come close to 90% IDC. Just for refrence I ran JEC 720s on my STI with a 35r meth and 114 oct and saw ~85% IDC @ 27PSI.
beaviscih is offline   Reply With Quote
Old 01-30-2009, 06:23 PM   #12
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
???????????? What kind of question is this?
Seriously... they are a little on the big side for his turbo, but any decent engine management will have them at the target af ratio. He will definitely not run out of fuel with that turbo on these.
Injectors dont have an efficiency range... they have a duty cycle... and when it is too high....... time for an upgrade.
The other issue with injectors is dead time... but again if he has a good engine management, then he can adjust and be all set.
Old 01-30-2009, 08:33 PM   #13
Freedz
Member#: 201597
If you trying for about 370 crank hp it isnt gonna happen with the small 16g. Its rated for 505cfm which is only gonna get you around 340 at the crank which isnt too bad. You could go to the big 16 and get 550cfm which will put you at about 370 crank hp, but the cost of a new turbo to gain around 30hp isnt real good bang for buck. In my opinion go to the 20G to get 650cfm so crank horse will be about 500 ponies max. With the more effecient 20 you wont be at such a high boost level as you would be with a 16 to make your target power, therefore your intake temps wont be as high and it will be less likely to knock and other associated nasties that come with high intake temps. Plus if you wanted to bump up the power after your comfortable with 370 ponies all you gotta do is give it a couple more psi. Your injectors will definately be ample for a 20G, as long as your not running your factory fuel pump.
Freedz is offline   Reply With Quote
Old 01-30-2009, 11:05 PM   #14
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Did you not see that he is building an auto x car....
also... he is not going to max at 340 at the crank with the 16g
Lastly... that is not the commercial "small" 16g sold everywhere .... and... Keep in mind that power output is not determined by comp wheel cfm alone!
He will have no problem meeting his hp goals with that turbo... much easier than any vf series... There are plenty of ej20g with over 300whp on the tdo5 16g. Plus his spool up time will be very important for the type of competition he is planning. His turbo will spool yesterday.
....... ha ha he said 20g for auto x
Old 01-31-2009, 02:36 AM   #15
GShinji
Member#: 30720
i just assumed that with the injectors possibly being at at extremely low duty cycles that it would be inefficient. Talked to someone at deutschwerks at he mentioned something about that, but then again i don't know much about this kind of stuff, learning as i go along. I guess I'll strap them on and i'll let you guys know what kind of idc's i get on the "small" 16g.
Old 01-31-2009, 03:10 AM   #16
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Ahhhhh.... I get where you are coming from now... Yes they are borderline too big for that turbo and will need alot of trimming to get them at target.... but a proper engine management will get them in line. There are better choices for the 16g though..... 650's are a great set that come to mind.
Old 01-31-2009, 10:29 AM   #17
Freedz
Member#: 201597
If thats the case then we should be recommending a ball bearing center section, not a journal bearing turbo.
Old 01-31-2009, 11:38 AM   #18
JDMFLCL
Member#: 180513
Baby Baby C'mon!
im considering hte port and polish, from reading the charts, it seems this turbo is only capable of around 350-370 crank horsepower then just goes sonic, how much would PnP help, or am i reading it wrong since it seems some people are making 300 whp on this turbo?
can i have some clarification?
Old 01-31-2009, 06:14 PM   #19
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
oh..... he wont need ball bearing with that turbo... Trust someone who has the exact same turbo on the exact same engine. He will spin it up nicely
As for the max output of the turbo... you are going to meet your stated goals at the beginning of the thread no problem. I would just run it like it is with large catless exhaust... and if you feel that you need more power at max.... then look into an upgrade.
... with your power to weight ratio, at over 300whp.. it will be hard for any street car to catch you..... and it will be an auto x monster
Help with turbo choice and supporting mods. Looking for 325+ WHP on EJ205. wtfh4xx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 08-29-2009 04:50 AM
turbo choices montyj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 08-11-2003 03:50 PM
Turbo Choice help? mr2guru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-19-2002 10:43 PM
I need some opinions on turbo choice... Gaspipe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-31-2002 04:37 PM
Turbo Choices k_thaosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-18-2002 05:01 PM
