Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 04-05-2002, 09:06 AM   #1
Bigred14
Member#: 2392
2005 Leg 2.5GT Lim
Atlantic Blue
Default CMOS Checksum Error - Defaults Loaded
I get this message at POST and then can't do anything else but turn off the computer and try again. F1 and Del don't work.
I have a brand new Abit KR7A Raid Board and I just installed it and am getting this error.
So far my research has pointed me to replace the battery on the motherboard.
It also said worse case I could have a shorted out motherboard.
Anything else it could be.
Bigred14 is offline   Reply With Quote
Old 04-05-2002, 09:54 AM   #2
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Replace battery is a good start. Also check to make sure the CMOS recovery jumper is in the normal operating position.
If that doesn't work, take all the cards out of the system except video, disconnect all the drives, and see if you can boot with just the board/CPU/video. If it boots, add cards one at a time, you might have to play around with what card goes in what slot. If it doesn't boot you can try re-flashing the board BIOS. Check to see if there is a newer version on the web.
If that doesn't work, chances are it's not user-fixable and you should RMA the sucker.
Xio is offline   Reply With Quote
Old 04-05-2002, 10:09 AM   #3
Bigred14
Member#: 2392
2005 Leg 2.5GT Lim
Atlantic Blue
Yeah I had to dumb the CMOS before starting so I had moved the jumper then replaced it in the right spot plus checked like 10 time when this problem came up.
I don't think I can flash the BIOS since I can't actually get past the POST. It freezes when that error message comes up and nothing gets it to budge.
I have already tried the Card thing and got the same response.
Great suggestions though got anymore things I can try.
Hopefully its the battery if not I think think this will be getting shipped back. They better not say anything about a freaking restocking fee.
Old 04-05-2002, 10:27 AM   #4
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
One other thing I just thought of:
See if your CMOS has a "recovery" mode in the documentation. Some boards have this feature which allows the board to automatically reflash the BIOS from a floppy image (This is a different file than the normal BIOS flash). Typically you have to do some procedure such as:
a. put jumper in "recovery" position
b. put recovery BIOS image in floppy, power on computer
c. you won't see anything, wait for 2 beeps.
d. take out floppy, reboot
Old 04-05-2002, 10:30 AM   #5
pylorns
Member#: 12753
02 06' VW Passat
try flashing your bios with another newer version.
pylorns is offline   Reply With Quote
Old 04-05-2002, 11:04 AM   #6
WRXfiend
Member#: 16383
Platinum Silver Metallic
In addition to what everyone else is saying:
Be sure your memory is good. If you are using two sticks. try one at a time. If you only have one, try and borrow another for testing.
WRXfiend is offline   Reply With Quote
HOW TO: UTEC map upload checksum error fix cdvma Engine Management & Tuning 11 11-27-2008 09:08 PM
UTIME Checksum Error bcblues UTEC 3 05-29-2006 11:31 AM
error when loading tune N1mxer UTEC 6 04-12-2006 05:19 PM
Need Stg3 Utec map, with no checksum error coyote73176 Engine Management & Tuning 8 03-04-2005 12:02 PM
UTEC Checksum errors! GMTarkin Engine Management & Tuning 29 12-31-2004 09:07 PM
