Old 04-04-2002, 06:26 PM   #1
Evegan
Member#: 16578
2000 Outback - 89E30
2003 NCAC DSP Champ
Default Alternator belt
How difficult is it to replace the alternator belt on a MY00RS? I'm the proud new owner of one and the alternator belt is looking a bit frayed and I'm gonna replace it. The local subaru dealer charges $76/hour plus the belt $15, seems a little much. So can someone with limited mechanical ability do this and not worry?
Evan
Evegan is offline   Reply With Quote
Old 04-04-2002, 07:05 PM   #2
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
100 times easier than I thought it would be. I replaced both belts when I first got my car. Since the belts are on the front it is a piece of cake in my opinion. If you want I can try and take some pics of the bolts to loosen up. Or you can check out scoobymods.com and look for the post on replacing the pullies, you have to loose all of the same bolts. Well not the bolts that hold the pullies on but you know what I mean. While you are at it I would replace both at once.
Buster
EvasionOfTruth is offline   Reply With Quote
Old 04-04-2002, 09:06 PM   #3
Evegan
Member#: 16578
2003 NCAC DSP Champ
thanks, that'll be my morning job tomorrow.
Evan
Old 04-05-2002, 01:23 AM   #4
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Just a few tips I found usefull:
Once you get the belts on, tighten them up just snug. Not to tight, start the car let it run for about 5 minutes.
Then retighten the belts so that you can only turn the inside to face(basically 90 degrees) you no further.
After a week or so mine started to loosen up some, so make sure you check them after they have stretched out some.
Buster
Old 04-05-2002, 12:14 PM   #5
Evegan
Member#: 16578
2003 NCAC DSP Champ
thanks, just got done. it was very easy, except the trip to Subaru because Advance gave me the wrong belt.
Thanks again
Evan
Old 04-05-2002, 12:22 PM   #6
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
No problem man. Glad to hear it went ok.
Buster
Need A/C and Alternator belt tension torque specs Shaitiger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-19-2004 11:59 PM
need quick help with alternator belt.. JB1 Southern California Impreza Club Forum -- SCIC 0 12-26-2003 02:34 AM
Alternator belt Evegan Service & Maintenance 3 04-05-2002 12:47 PM
picture of alternator belt tensioner WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-06-2002 03:29 PM
Alternator Belt too tight/loose? JP Money Normally Aspirated Powertrain 15 03-08-2001 07:00 PM
