Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 01-29-2009, 09:47 PM   #1
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
Default Oil leak - crank seal
Well, I'm pretty sure I've got a crank seal leak, with oil all over the front underside of the car, and some smoking off the exhaust. I've done the timing belt before, but never the crank seal, and I don't recall seeing any "seals" while I was in there. I'm guessing it's behind the crankshaft sprocket...
Can anyone provide guidance as to where this seal exists? Thanks!
aldebaraan is offline   Reply With Quote
Old 01-29-2009, 11:28 PM   #2
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
You are correct. Its behind the crank pulley/gears. It can be a pain to remove, but it goes back in real easy.
Seeing how you have done the belts before, you know the trick to getting the bolt off I assume?
TurboneX is offline   Reply With Quote
Old 01-30-2009, 12:54 PM   #3
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
Well, I've heard the trick but I've got a stick, so I just put it in 5th, and it won't budge while I get the bolt off.
As a follow up, though, it's just a seal that goes around the crankshaft? Any suggestions on how to get it out, if as you say it's a pain? Thx!
Old 01-30-2009, 02:41 PM   #4
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
besides the crank seal u may want to replace the 2 oil pump o-rings/seals...one kinda looks like mickey mouse...good luck!
SQUAD_907 is offline   Reply With Quote
Old 01-30-2009, 04:39 PM   #5
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
I put on the e-brake, disconnect the coil lead, get a 2ft long breaker bar, set the wrench/bar against the battery area and then give the ign a bump.
It will spin it off lickety split.
A tool with a hook on the end of it will get the old seal out.
I've had to drill a small hole in one and then tap a screw into it to pull on before
Old 02-05-2009, 09:08 AM   #6
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
Okay, I'm going to tackle it...been putting it off for days. But I want to make sure I've got everything ready to get it back together okay. I'd go with a dealer part if they were closer, but they're not, so I'm looking at NAPA parts.
Which of these three is it? They all "sound" like what I'm replacing:
- http://www.napaonline.com/MasterPage...r+Seal+-+Front
- http://www.napaonline.com/MasterPage...ing+Cover+Seal
- http://www.napaonline.com/MasterPage...Front+Seal+Set
Old 02-05-2009, 05:23 PM   #7
mrbigshot
Member#: 191474
Default question
gotta do this too:
Sorry for the noobiness but just for clarification you give the "ignition a bump"? and what coil lead do you disconnect?
thanks
mrbigshot is offline   Reply With Quote
Old 02-05-2009, 06:33 PM   #8
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Looks like the 2nd part is the one you need.
Originally Posted by mrbigshot View Post
gotta do this too:
thanks
The coil to distributor lead.
Then turn the ign quickly and it will spin the bolt loose.
And to clarify, put the breaker bar on the drivers side fender.
Use a block of wood if you need to cushion it.
Old 02-07-2009, 05:40 PM   #9
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
Thanks, that was it, and for only $9, I'm back in business. Much easier than I was anticipating!
Front crank seal leak RickV Service & Maintenance 4 04-29-2006 11:45 PM
leaking cam or crank seal! how much $?!!?! ooberdoob Legacy Forum 2 12-31-2005 09:39 AM
'05 STi leaking crank seal austinpike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 11-28-2005 05:46 PM
Timing belt change and crank seal with oil leak fdupny Service & Maintenance 1 11-10-2004 05:18 PM
Axl Shaft & Crank Seal Leaking BLuExTaCiE Mid West Subaru Owners Club Forum -- MWSOC 9 10-03-2004 10:52 PM
