Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 03-24-2012, 10:39 PM   #1
jesseber
Member#: 293509
2004 WRX STI
Have a Nice Day? 05 STI td05 20g 290whp/285wtq. Why am I spooling so late?
2005 STi
Tuner: Alberto @ Corr Performance
Dyno Info: Dyno Dynamics
Gear: 4th
Baseline hp/tq for a stock on same dyno: 210whp/wtq~
Target Boost: 21psi
Fuel: 93 octane.
81F, 55% 30.03 Baro
Elevation 25ft
Engine/Power mods:
Cobb Accessport V2
Forced Performance td05 20G 7cm
CP 99.5mm (8.2:1) forged pistons
Brian Crower valve springs
Agency Power 3" turboback exhaust
Grimmspeed Uppipe
Tial MV-R 44mm EWG
APS cold air intake
Samco 2.4" turbo inlet
DeatschWerks 740cc Injectors
Walboro 255lph fuel pump
Grimmspeed lightweight crank pulley
Hallman MBC
GFB Deceptor BOV
NGK iridium one step colder spark plugs
Grimmspeed turbo heat shield
Anyone have any thoughts on why I'm not hitting full boost until 5k?
jesseber is offline   Reply With Quote
Old 03-24-2012, 10:47 PM   #2
raggedoutsti
Member#: 255714
2005 STi
psm
Post turbo boost leak?
raggedoutsti is offline   Reply With Quote
Old 03-24-2012, 11:19 PM   #3
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Missing wastegate seal. Damaged turbo
Old 03-24-2012, 11:25 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'm gonna go with missing EWG valve seat.
-- Ed
Old 03-25-2012, 05:39 AM   #5
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Remove the boost controller and see if it does it?
Dat8687 is offline   Reply With Quote
Old 03-25-2012, 01:23 PM   #6
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
Never mind the fact that your making less than a stage 2 sti on a 20g lol.
missing valve seat would be obvious with a dump to atmosphere ewg.
does it have any exhaust leaks? pre turbo.
NW2TONE is offline   Reply With Quote
Old 03-25-2012, 02:16 PM   #7
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
How much timing?
banshee04 is offline   Reply With Quote
Old 03-25-2012, 03:29 PM   #8
jesseber
Member#: 293509
2004 WRX STI
An EVO 9 w FP Red only put down 350 on the same dyno. Stock STIs put down 210. My stage 2 setup put down 245. Okay I'll have to look into that. No exhaust leaks.
Originally Posted by banshee04 View Post
How much timing?
Not sure, would have to ask.
Old 03-25-2012, 08:21 PM   #9
jesseber
Member#: 293509
2004 WRX STI
Can you guys elaborate more on what exactly you mean by a missing valve seal?
Old 03-25-2012, 08:27 PM   #10
NW2TONE
Member#: 212509
your **** go faster
The ewg has a valve seat that sits between the ewg and the uppipe flange for the wg. if that seat is not there it will not seal. causing a massive pre turbo exhaust leak.
Old 03-25-2012, 09:49 PM   #11
jesseber
Member#: 293509
2004 WRX STI
The seal is there and everything is all tight. I'm 99% positive that I have no exhaust leaks.
Old 03-25-2012, 09:53 PM   #12
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Do you have a boost gauge? Do you feel your car spooling at 5k on the streets?
What does your tuner think?
What have you done to check for exhaust leaks?
If your ewg is routed back into the exhaust it would never sound like a leak
Old 03-25-2012, 10:15 PM   #13
jesseber
Member#: 293509
2004 WRX STI
Yes. Yes full boost comes on roughly at 5k. He isn't sure. Though I know I'm not perfect, I've checked everything hands on.
Old 03-26-2012, 12:12 PM   #14
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
Eww... lol.
JdMS13 is offline   Reply With Quote
Old 03-26-2012, 01:15 PM   #15
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr jdm 6-spd JJtuned
Perhaps your hotside is a bit small for this build. This could explain the reduced tq - 2.5's should generate more tq. than hp. unless they are getting choked off. I'd consider it -- believe me, as the owner of an hta68 I've done tons of reading on 7cm hotsides.
Old 03-26-2012, 02:02 PM   #16
Gfunk720
Member#: 42549
E92 M3 M\\\
2017 Outback Limited
^^ He'd probably reach the limit of the APS intake before maxing the turbo. If anything, a smaller hotside is going to create better spool and less top end.
Either this is a ULTRA low reading dyno, or there is something going on. Even that big dip at 5600rpms is odd.
What's a Stage 2 STI usually put down?
Gfunk720 is offline   Reply With Quote
Old 03-26-2012, 02:08 PM   #17
Dave D.
Member#: 130990
06 Red Ltd.Wagon
He said about 245hp. I agree that is a noticeable dip, both hp. and tq. Be nice to see a boost plot.
Old 03-26-2012, 02:30 PM   #18
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Compression numbers on motor?
Brother EddieJ. is offline   Reply With Quote
Old 03-26-2012, 02:42 PM   #19
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
this is what i was going to say... do this^
A Fatal Ode is offline   Reply With Quote
Old 03-26-2012, 02:55 PM   #20
jesseber
Member#: 293509
2004 WRX STI
Here's PSI and TQ
Old 03-26-2012, 02:58 PM   #21
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Eeek.
Old 03-26-2012, 03:15 PM   #22
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
wow. Something is MAJORLY wrong. That spool is disgusting for a 20g.
Old 03-26-2012, 03:17 PM   #23
spintheground
Member#: 239638
2007 WRX TR UGM
Looks good to me!
For a 40R.
spintheground is offline   Reply With Quote
Old 03-26-2012, 03:25 PM   #24
jesseber
Member#: 293509
2004 WRX STI
So with this new plot, can we begin to guess at it a little more accurately? :/
Old 03-26-2012, 03:34 PM   #25
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Looks like a serious boost leak.
02rex62 is offline   Reply With Quote
okay why am i suddenly so tired in the morning? alacrity024 Off-Topic 8 06-24-2005 04:25 PM
Why are you up so late dgaseven Off-Topic 12 05-23-2004 06:54 AM
Why am I running so rich? Dorkfish Normally Aspirated Powertrain 4 05-23-2004 12:19 AM
Why am I running so rich?? karl_hungus Normally Aspirated Powertrain 11 03-24-2003 10:00 AM
Why am I seeing so many TXS Unichips For Sale? AllenWilson Newbies & FAQs 5 08-10-2002 12:55 AM
