Old 05-26-2010, 09:03 PM   #576
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
you have a log?
wrxwhat is offline   Reply With Quote
Old 05-26-2010, 09:32 PM   #577
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
She has a log.
Old 05-27-2010, 01:53 AM   #578
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
nicely done FAT
Marlons101 is offline   Reply With Quote
Old 06-02-2010, 11:41 PM   #579
FATCanuck
Member#: 142534
man now that its actually running , its some quiet in here ! its sad to say but i think people like bashing more than anything ! thanks to everyone that stayed tuned in to this thread and made suggestions or otherwise . see yall on the streets !
FATCanuck is offline   Reply With Quote
Old 06-03-2010, 12:57 AM   #580
Swine
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
Absolutely awesome results. Maybe not the most amazing peak #'s, but basically 20g performance down low and of course the 40 picking up the slack from 5500 on.
Swine is offline   Reply With Quote
Old 06-09-2010, 09:58 PM   #581
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
99OBSTi 91NSX 06 9-2xAero
News 109 & 91 octane numbers
^109 octane ^
^109 octane ^
-DBB
JapCarRealGood is offline   Reply With Quote
Old 06-09-2010, 10:11 PM   #582
MartinSTi05
Member#: 145145
2006 wrx STi
So, what I should glean from this is that a properly set up twin scroll car is still a better idea?
Why did you start the graph at such a high RPM?
http://forums.nasioc.com/forums/show....php?t=1971337
MartinSTi05 is offline   Reply With Quote
Old 06-10-2010, 02:10 AM   #583
LittleBlueGT
Member#: 96204
2013 STI GR
I don't know about compound charging, but a SC will make the same low end power in any gear, a turbo will not.
See how good your TS 35R spools in 1st or 2nd gear, then compare to this.
I am not at all advocating this mod route, but you have to see the facts for what they are, and many here look at a dyno done in 4th gear and figure that is the whp/wtq curve of X turbo/mod combo, and it is not the same on lower gears.
LittleBlueGT is offline   Reply With Quote
Old 06-10-2010, 10:15 AM   #584
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
THIS IS A 2.7 LITER, hardly a good comparison. However I did show the borg warner results that have similar power at similar RPM. Like someone else said though I am guessing it should be quicker in other gears with the super charger on there. The real test will be 1/4 mile times, if it doesn't show real gain there then it isn't very functional even though it is a very nicely done setup.
Ben
Old 06-10-2010, 10:21 AM   #585
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I think for those who are looking to be different, the compound setup has its merits. Sorry to say, but rotated kits all look the same these days.. Single scroll, twin scroll, triplet scroll, whatever... Unless the turbo is getting mounted down low in the fog lamp location or under the engine, they all look very similar.
Yes, the 2.7L setup makes similar numbers, but again, it looks (from the outside) no different from any other rotated setup out there.
This actually looks different...
Thankfully, it seems to put up respectable numbers. Combine that with the rarity of this particular setup, and I think it definitely has its place out there.
jigga is offline   Reply With Quote
Old 06-10-2010, 01:00 PM   #586
xsnapshot
Member#: 170973
2004 WRX 4EAT
He's making decent torque below 4000 RPM, and holding 575ish whp all the way out past 8000 RPM. (looks like 8200 or so?) Not as much midrange torque with this car, but to me that appears to at least in part due to getting the kinks worked out between the supercharger and turbocharger transition.
The powerband of this car would be great for the track though, especially coming into tight turns.
xsnapshot is offline   Reply With Quote
Old 06-10-2010, 01:45 PM   #587
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I wonder what the EGT's are at 24psi and 12:1 AFR on 91 octane.....
Old 06-10-2010, 05:23 PM   #588
LittleBlueGT
Member#: 96204
2013 STI GR
IDK, but the reduced back pressure of his system might make it lower then you think.
Old 06-11-2010, 11:16 PM   #589
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
This kind of setup, while doing well at the 1/4 mile, is PERFECT for autocross.....
Old 06-14-2010, 06:53 AM   #590
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
I was expecting more...of course the real test will be track results...so go get some!
domestic_abuser is offline   Reply With Quote
Old 06-14-2010, 04:45 PM   #591
sabreofsd
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
Congrats Dude, glad to see this has finally come together for ya!
sabreofsd is offline   Reply With Quote
Old 06-15-2010, 01:47 PM   #592
Fuj1wara
Member#: 249207
2010 STi SE
Grats on the completed setup. Props to having the balls to stick that kind of money into the build. It's good to see people trying new things.
Fuj1wara is offline   Reply With Quote
Old 07-01-2010, 03:18 AM   #593
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
Old 07-01-2010, 03:20 AM   #594
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
Old 07-01-2010, 10:14 AM   #595
Phatron
Member#: 36033
CEO PhatBottiTuning
Give us your car for 2 years and this setup could be yours!!!!!
for days at "Pinky Tang"
Cover says 604whp......graph shows ~580whp
Does the article mention that with the fantastic ECUtek software that all OBD2 readers will not work....romraider logger will not work....no other loggers/scanners will be able to read anything from the car......and that if you want to recoupe any of the $900 spent on the ecutek software that you must remove the ecu and sell it? just curious.
Old 07-01-2010, 10:26 AM   #596
Badler
Member#: 133597
People don't actually buy magazines like that anymore do they? Sheesh.
Badler is online now   Reply With Quote
Old 07-01-2010, 12:55 PM   #597
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
"Supercharger torque, turbo power, Daily-driven"
Come on now.... I'm all for new stuff, and the point of this kit. I'll even vouch for the quality of the kit. But to call it daily driven?! When was the last time the owner drove the car?
KP is offline   Reply With Quote
Old 07-01-2010, 02:10 PM   #598
BigRigger
Member#: 129969
2005 Sti
Silver/Black
WOW, talk about haters being jealous!!
BigRigger is offline   Reply With Quote
Old 07-01-2010, 02:33 PM   #599
Phatron
Member#: 36033
CEO PhatBottiTuning
jealous?
i already plotted my stock location dom4xtr up against his car.....and my turbo spooled faster and made more topend.....not so much jealous.....
Old 07-01-2010, 02:58 PM   #600
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
I'm a little jealous...
FS/FT : NY: Fully Built 2000 Si Turbo Electron Blue. 21k Miles!! boostaholic84 Private Vehicle 'For Sale' Classifieds 164 09-08-2010 02:59 PM
FS: Compound Charged 2004 STi AaronB Private Vehicle 'For Sale' Classifieds 22 01-06-2007 04:04 AM
Compound charging stock STI? Bc Rich Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 08-03-2006 02:33 AM
Fully Built JDM 2.0 STI High Revving Engine - Built to Order Gruppe-S Services 15 06-01-2006 04:51 PM
Compound Charge Sti 548 Hp MDJWRX Proven Power Bragging 321 06-08-2005 11:53 PM
