Old 01-30-2009, 08:57 AM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default RS SOHC and WRX Intake manifold differences
What are the differences between the top feed Intake manifolds in regards to Injector spacing, diameters etc. Specifically will the After Market WRX fuel rails fit the RS Manifold using WRX Injectors
Odyknuck is offline   Reply With Quote
Old 01-30-2009, 01:42 PM   #2
master c
Member#: 168226
+1 for info on this - interested to see if other rails can be modifed to work with the sohc phase 2 intake manifold
master c is offline   Reply With Quote
Old 02-01-2009, 07:21 PM   #3
Odyknuck
Member#: 192866
2006 Impreza
Ok, Can some one with a WRX measure the Center to center distance of the Injectors.
Old 02-02-2009, 01:19 AM   #4
master c
Member#: 168226
might have better luck in one of the other sub forums....i doubt anyone in here has a wrx manifold haha
Old 02-02-2009, 01:54 AM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
Can do tommorow morning
sorrowfulkiller is offline   Reply With Quote
Old 02-02-2009, 10:48 AM   #6
Odyknuck
Member#: 192866
2006 Impreza
Valid point
Old 02-02-2009, 10:49 AM   #7
Odyknuck
Member#: 192866
2006 Impreza
Thanks
Old 02-02-2009, 02:52 PM   #8
sorrowfulkiller
Member#: 170439
I <3 Lamp
Looks like approximately 5 inches from center of back injector on pass side to center of front injector on same side. I'm guessing it would be the same for the driver side
Old 02-02-2009, 04:53 PM   #9
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
the injectors on the WRX TGVs measure 4.449" apart. That's 113mm.
quadtard is offline   Reply With Quote
Old 02-02-2009, 09:05 PM   #10
master c
Member#: 168226
ody - what measurements did you get for the stock RS setup?
Old 02-03-2009, 01:04 AM   #11
Brydon
Member#: 107569
1998 Forester S
SRP
They are the same size center to center. The manifolds bolt up the same The ports are located at the same spot and the injectors sit in the center. There will be no difference. however the rest of the manifold and sensors are very different.
Brydon is offline   Reply With Quote
Old 02-03-2009, 05:25 AM   #12
sorrowfulkiller
Member#: 170439
I <3 Lamp
Thanks for posting a more exact number. It was hard enough getting a decent ruler under there, lol
STI and WRX intake manifold difference? Ferraz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 47 10-26-2010 12:21 AM
2.5I and WRX intake manifolds fateo66 Engine/Power/Exhaust 57 04-23-2010 11:31 AM
FS: 08 Sohc heads & INtake Manifold & 05 Exhaust Manifold bmxpunk Engine/Power/Exhaust 14 03-09-2010 11:32 AM
V8 Heads and WRX Intake Manifold ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-06-2006 04:22 PM
JDM SOHC 2.5 intake manifold n2xlr8n Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 09-05-2005 09:46 PM
