Old 01-30-2009, 09:45 PM   #1
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Default 99 JDM V6 STi not starting...any insight is appreciated.
First, can you get scan the OBD port of a 99 JDM V6 ECU with a regular OBD2 scanner?
I tried numerous times with a AP and a regular scanner. I'm getting a link error? I'm guessing the USDM scanner can't read it. But i have read in other area that the V7/V8 you can use any scanner?
Either way when the car was running it had a constant cel flashing. The car was purchased a few days ago from a state not anywhere close to mine. The owner bought it as is and didn't know crap about the car. (he's no help)
Ran fine for a while; now it is cranking but not starting.
Funny thing is we were able to push start it once. Ran perfect for 20 miles. The next morning didn't start again.
The starter is strong and doing it's job...it is cranking just not turning over.
I think it's fuel related. But, pump is priming (fuel filter replaced and sock on pump is clean), there is spark (watched #3 with a nice arc).........almost everything has been checked.
Out of ideas?
I am thinking the ECU is acting up maybe. I know the USDM service manual says the final step to cure a constant 3hz CEL is to replace the ECM.
Any insight or suggestions would be appreciated.
Wrx_Fan_0717 is offline   Reply With Quote
Old 01-31-2009, 12:55 AM   #2
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
This should help you figure out how to read your codes:
http://legacycentral.org/library/literature/codes.htm
Btw, congrats on the new car. Do you have to pass smog to register the car in your area?
scrappydoo is offline   Reply With Quote
Old 01-31-2009, 01:52 AM   #3
Wrx_Fan_0717
Member#: 152080
Well it's not mine its a friend on mine......a girl at that.
She already has it registered and tagged...no emissions in FLA.
After 6-10 hours of working on i think we got it running. Not sure for how long. I think the ECU is on it's way out. Or a pin was loose?
Thanks man.
Old 01-31-2009, 03:15 AM   #4
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
YaY! my cars running. still hope it doesnt do this again. Im going to buy another ecu to be on the safe side anyways!
MonikAWD is offline   Reply With Quote
Old 01-31-2009, 03:18 AM   #5
Wrx_Fan_0717
Member#: 152080
Yea it's hers ^^^
Old 01-31-2009, 03:30 AM   #6
scrappydoo
Member#: 23630
97 v4 STi RA
Congrats. Btw, there's only a handful of us with imported gc's.
Old 01-31-2009, 04:26 AM   #7
ckcadavona
Member#: 135730
93 L
Ecutek Deltadash is the only thing that I've heard works on the V5/6 ej207 short of a full standalone. You can get them used for aprox 250.
ckcadavona is offline   Reply With Quote
Old 01-31-2009, 06:48 AM   #8
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
and there is always power FC, vipec, autotronic, and haltech.
RA Limited is offline   Reply With Quote
Old 01-31-2009, 06:57 AM   #9
ckcadavona
Member#: 135730
93 L
I was reffering to pulling codes, trouble shooting, etc. Hence "short of a full standalone." But yeah, I agree there's a lot of options for standalone em.
Old 01-31-2009, 07:00 AM   #10
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
Yeah I was reading about this tonight, I really am interested in getting it.
I want to check out the other ones just to make sure its what I want, but I'm pretty sure I want DeltaDash
Old 01-31-2009, 08:43 PM   #11
Wrx_Fan_0717
Member#: 152080
yay for answers..............
Old 02-01-2009, 11:03 AM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
welll
ecutek is not the only way
other would be a genuin ssm ver 1
or there was a guy on the rsliberty board that was making a serial interface for the ssm1 protocol which would read live data ,be it slowly, like the ssm2+ stuff
Old 02-01-2009, 05:09 PM   #13
ckcadavona
Member#: 135730
93 L
Originally Posted by Jaxx View Post
welll
This is good to know especially if the mentioned interfaces are cheaper. I don't mind if it's slow as long as I can pull ecu codes.
Old 02-01-2009, 07:30 PM   #14
scrappydoo
Member#: 23630
97 v4 STi RA
Were you able to figure out what the problem was?
Old 02-01-2009, 09:54 PM   #15
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
Um, not real sure. We tried a few things, and think it was ecu related. We unplugged the ecu and plugged it in and now the problem is gone.
Old 02-02-2009, 12:20 AM   #16
scrappydoo
Member#: 23630
97 v4 STi RA
That's strange because I had an unexplained problem with my car and it was ecu related. When I would be cruising at about 4k rpm with almost no load, the power would just disappear. It's like the car just lost it's tps signal because increasing throttle did nothing. I had to completely let off the throttle and it would go away.
I would never have guessed it was ecu related. But when I switched to the Hydra it completely disappeared.
Old 02-03-2009, 08:38 PM   #17
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
So the car died again, the same thing happened. This time the ECU reset didn't work. Pretty sure the ECU died.
Old 02-03-2009, 09:08 PM   #18
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
man, had the ****ty mechanic that "rebuilt" my STi not stolen the ECU from me as "collateral" for me not paying him, i could have sold it to you.
Old 02-03-2009, 10:38 PM   #19
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
whatttt! Go negotiate? Yeah i pretty much have to have my resource in japan find me one..this feels like its going to take forever..
Old 02-04-2009, 02:54 AM   #20
cegpcola
Member#: 97987
The Wagon shaped
paper weight
I have DeltaDash if you two need to use it. I still have 2 ECU licsense available on it.
cegpcola is offline   Reply With Quote
Old 02-04-2009, 02:57 AM   #21
cegpcola
Member#: 97987
The Wagon shaped
paper weight
If you search on here long enough, you will find the ECU you need. I have run across a ton of JDM ECUs including the V7 Spec-C one in my car.
Old 02-04-2009, 02:58 AM   #22
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
i hate to say it, but these are the kinds of problems you should expect when driving a car like this in the states. It can be a pain finding replacement parts for them, IN JAPAN....
Old 02-04-2009, 02:18 PM   #23
MonikAWD
Member#: 201488
99 JDM V5 RA
STM
it cool, i found the exact one for my car for 225. :P
cegpcola, i would love it if you connected to my car (if it works) i know the japanese obd hookup is different. PM me or wrx_fan_0717, im not doing anything today.
Old 02-04-2009, 09:55 PM   #24
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
check wires and pins. sometimes the pins get seperated/loosened and they dont make good contact. if you move the ecu around while its running or hit the ECU it will die and not want to start until you wiggle it back into its sweetspot. ive had this before with a badly done wiring job (bought it like that.. .long story)
elislider is offline   Reply With Quote
Car Will Not Start. Any Help Appreciated. TougeSyndicate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-29-2010 07:47 PM
JDM V6 STi Q's. Not a conv., but who better to ask! Wrx_Fan_0717 Subaru Conversions 2 12-15-2008 02:06 PM
Any feedback is appreciated.... PSH'N PSI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 11-01-2007 11:59 AM
P0102, any help is appreciated. Toahk Service & Maintenance 4 07-26-2006 04:57 AM
stripped oil drain plug, parts dept closed.. any help is appreciated iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-01-2003 08:50 PM
