Old 01-31-2009, 07:42 PM   #1
JSarv
Member#: 163445
l33t *******
[email protected]
So its not really bragging, nothing to fancy about it. Stock internals and stock 5spd with 101k miles.
Brotuned by me bro. Sorry thought it'd be funny.
Ran on E85 with low timing and quite a bit on the rich side.
Afr's were around 11-1. Timing was around 14* at 4k to 18* at 6500. So yea low timing and rich for e85. IDC's were around 88%- since the local E85 dist. does not comply to typical winter blends, it is actually 84-85% ethanol (tested 2 times in the past 2 weeks)
Anyway:
02 wrx
Greddy/Me TD05-18g with a TD06 3" compressor. Internally gated.
APS 3" inlet
TGV half deletes (yea I got lazy)
Invidia V2 Catless DP
Perrin UP (Perrin should seriously consider a remake of the downpipe its almost 8mm shorter than the factory pipe- measured today)
Witch Hunter 820cc injectors (within .5%)
AEM CAI
STI Top Mount
Perrin 3" V1 Single tip
Perrin Fuel rails (way easier to deal with than the stockers)
Blown apart Y pipe (blew apart on the 2nd pull)
Atm. Pressure is generally about 14.3-5 here (500ft above sea level)
It was 35*F ambient during the pull.
Pull was done on a very slight uphill onramp in 3rd gear.
I don't have a dyno real close to me, so the road dyno thing is what I'm going off of.
Boost was set to 15psi but creeped to 18.5psi by redline, hence the constant torque..
My car did 185 whp and 196 wtq on this same program bone stock (Well Up-pipe)
NO SAE correction! Not even smoothed.
Comment if you want, don't hate because I don't care. Not really braggin' just showing what kind of power it made on a "very basic, low timing" flash.
I will have updates when I get my blown apart silicon elbow replaced and some tuning done on it to make boost come on a bit sooner.
And there have been absolutely NO alterations to the log/run or the dyno map seen above-- it is what it is.
Thanks for looking.
Jerod
JSarv is offline   Reply With Quote
Old 01-31-2009, 08:58 PM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
E85 ftw Romraider ftw also Nice work. I think the ramp up in power is sweet!
TDagen is offline   Reply With Quote
Old 01-31-2009, 09:10 PM   #3
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
Wow damn good
WREX88 is offline   Reply With Quote
Old 01-31-2009, 09:47 PM   #4
JSarv
Member#: 163445
l33t *******
[email protected]
I have some hardcore boost onset issues. Like no boost until 5k in 2nd and 4500 in 3rd.
Its preload on the internal gate, but I won't have time to mess with it till tom.
I'd love 18psi by 4k in 2-5th. Maybe I'm dreaming, I know the larger compressor housing is not helping me out any in that department.
-Jerod
Old 01-31-2009, 11:54 PM   #5
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Needs moAr injector/boost/timing.
cucamelsmd15 is offline   Reply With Quote
Old 02-01-2009, 12:31 AM   #6
PolarisSnT
Member#: 85905
2004 WRX
Looks good but the graph is definately being skewed by the ends of the datalog. This happens to me a lot when I use this program if I cut the data too short it makes the ends of the graph curl up.
Its a realistic program, just have to have a proper log for it to work correctly.
PolarisSnT is offline   Reply With Quote
Old 02-01-2009, 12:40 AM   #7
JSarv
Member#: 163445
l33t *******
[email protected]
I'm sure it is a bit skewed up top, not to worried though.
I have the wgdc set for 0% everywhere and a 15psi actuator - creeping to 18.5ish after 5000 rpms...
Basically I'm stuck with at least 18.5psi+ after 5k no matter what I do, which is fine. I left a ton of bottom end boost on the table, a large amount of wgdc in the bottom end should really help with spool.
I'm going to work with it tom and see what I can come up with, hell I'd be exited for 300/300.
I worked on a timing map tonight so hopefully it will work out better than 18* at redline. I have injector left, I feel comfortable up to 95% idc and remember 88% is running 11-1 afr, I plan on leaning it out toward 11.8-12.0-1 when its said and done. On the stock turbo it seemed to make the most power between those to majical spots. We shall see though.
I do know that the 3" inlet sounds like a semi during spool though and I'm lovin' it!
-Jerod
Old 02-01-2009, 02:13 PM   #8
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
What kind of program is that? I'd like to try it!
Nice power curve, looks like NA.
Psipwrd is offline   Reply With Quote
Old 02-01-2009, 02:57 PM   #9
JSarv
Member#: 163445
l33t *******
[email protected]
Datalog lab.
There is a thread about it at Romraider.com from testes.
Its an ok program, probably not "exact" numbers but from pull to pull with a good tune, numbers will be the same. Its a very useful tool to use for road tunes were if it has a good tune, and honestly I don't care a whole lot about what my numbers are, but its a reference point type of thing.
I'd like to see 110+ trap in the 1/4 but doubt that happens. I trapped 85 mph in the 1/8th on the stock td04 and stock 5 speed.
-jerod
Old 02-01-2009, 03:40 PM   #10
PolarisSnT
Member#: 85905
2004 WRX
110 should not be a problem.
Can you send me the datalog and weight of the car? I love using this dyno as a tool to show gains on my own car but I want to see how it stacks up to my graph. I want to creat a little database for myself and this would be perfect.
Old 02-01-2009, 03:52 PM   #11
JSarv
Member#: 163445
l33t *******
[email protected]
Yea I'm going to go on a joy ride in a bit with some timing and major fueling changes.
Made some adjustments in the boost department as well. Hoping to see 18psi by 4k but we shall see.
Have the log up later
-Jerod
Old 02-01-2009, 06:51 PM   #12
jason miller
Member#: 158313
2003 WRX
I dig it.
jason miller is offline   Reply With Quote
Old 02-02-2009, 08:08 AM   #13
wrxhard
Member#: 108091
Great stuff. More info on the 3" compressor cover please. Where'd you get it?
wrxhard is offline   Reply With Quote
Old 02-02-2009, 02:17 PM   #14
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
Great Power!!!
mongoosaroo is offline   Reply With Quote
Old 02-02-2009, 05:10 PM   #15
JSarv
Member#: 163445
l33t *******
[email protected]
Its a Greddy 18g from an H22a Prelude turbo kit.
We bought the kit for dirt cheap (cheaper than a used wrx 18g) decided it sucked balls on the H (which would see a full 9psi by 2400 and fall on its face by 5500. So I decided to run it on the scooby and run a 60trim .72 A/R on the H22.
Its basically just the standard Greddy 18g with a T25 flange (can find them cheap sometimes on Honda-tech) I picked up a (well was supposed to be) td05 7cm2 housing. Which ended up being a TD05 housing bored for a td06 wheel. So it was of no use to me (good paper weight).
So some super guy here on nasioc hooked me up with a brand new TD05 housing bored for the 18g turbine wheel. I picked up a brand new 15psi actuator here on nasioc for $30 and had my fav. machine shop cut down the inlet and do my hole drillin.
So far, I technically have $150 into this turbo, I see 18psi by 3500 and gets the super creep to 19 by 7k. At 7100 I'm at 19.1psi with 2% wgdc, which basically means the solenoid is fully open allowing the actuator to see a full flow of boost. Meaning I'm creeping badly. BUT this can be tuned around, and that is why I have it set the way I do, 19 is where I wanted to be, so I set my wgdc low were it creeps and live with it.
I'm still working on timing and afr's, I had a leak which just got fixed so hopefully things start getting a bit smoother and I can start making the power it should make on E85. But for now, my last log, made 310 whp and 288 wtq, which is damn good for 19psi (I think).
I should be able to lean it out almost a whole point and make 5-10whp throughout the powerband. I'd like to see 325/300 consistently at 19psi.
-Jerod
Final product prior to the inlet cut and the drill/tap for the boost reference.
Thats the whistler...
-Jerod
Old 02-02-2009, 11:07 PM   #16
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
nice bro tune!!!
lawn boy is offline   Reply With Quote
Old 02-02-2009, 11:17 PM   #17
JSarv
Member#: 163445
l33t *******
[email protected]
I like to think that brotunes are the only way to go, I'm bored maybe I'll inflate the numbers a bit and see what I can come up wtih.
Old 02-03-2009, 12:51 PM   #18
JSarv
Member#: 163445
l33t *******
[email protected]
Well.. I all but maxed out my maf today.. Stupid 16bit ecu's. No running more than 21psi for me...
Here is the dyno - 15*F slightly uphill and had a sidewind of about 25mph, made for an interesting ride. I weight 175, I had my 25lb book bag, 50lb tool bag and a damn 50lb saw all in the trunk (I wasn't in the trunk).
So total weight would be around 3350llbs. (Tip the scales at 3225 will a full tank of gas and myself)
No correciton and graph was only smoothed until it wasn't choppy.
Boost still needs just a bit of work, was shooting for 19psi, didn't technically see 19psi till 5k, seen 17 at 3750, but it basically creeped from there till redline (21psi at redline)
As a reference 50-80mph took 3.01 seconds. Which is plenty for me.
I need to get a video of how incredibly loud this turbo just really is, it must be the 3" inlet but its loud, like semi loud during spool.
To be truthfull I think the transmission is fairing much better than with the td04. Its so much more smooth everywhere, its just incredible.
-Jerod
Log: http://www.romraider.com/forum/downl...le.php?id=7256
Well what you see is what you get, I'm out of MAF and Injectors (98% idc at the top of 2nd gear).... I don't think leaning it out half a point is going to gain a whole lot of ground on the injectors...Now I can't wait to hit up a chassis dyno and see if road dyno is close..
Also wanted to add my boost plot, I see 18.5psi by 3207 rpms.... and then it super creeps to 21 psi lol...
Old 02-03-2009, 01:35 PM   #19
Pink sOck12
Member#: 175988
07 STi
CGM
18g ftw!
Pink sOck12 is offline   Reply With Quote
Old 02-04-2009, 05:10 PM   #20
wrxhard
Member#: 108091
Wow. Great stuff!!! That turbo setup is kickin ass all over the place!!! Congrats!
Old 02-05-2009, 08:25 AM   #21
PolarisSnT
Member#: 85905
2004 WRX
Looks good.
Your MAF isnt maxed, you have until 5v but if you are out of injector then thats all you can do right now.
That log was in 3rd gear? You said in your post you are at 98% IDC in 2nd, its only going to get worse in the higher gears, you need new injectors soon.
Old 02-05-2009, 11:43 AM   #22
JSarv
Member#: 163445
l33t *******
[email protected]
I was under the impression that 16bit ecu's maf's only read up to 4.74v.
I know if it will read up to 5v, I'm going to have to do the 300+ g/s hack because I see 300g/s quite a bit and it just plains off...
My IDC's are down a bit, I leaned it out to almost 12-1 which brought my IDC down in the top of third to 93% (which I'm comfortable with).
-Jerod
Old 02-05-2009, 01:11 PM   #23
Bullwinkle1983
Member#: 172332
2006 WRX
-Jerod
You're comfortable with 12:1 AFRs are redline, huh? What are your EGTs?
EDIT: OOps, re-read that you're running E85. Is your WB02 calibrated for straight pump gas?
Bullwinkle1983 is offline   Reply With Quote
Old 02-05-2009, 01:27 PM   #24
JSarv
Member#: 163445
l33t *******
[email protected]
Yes its calibrated for pump gas, so basically I just tune as if I was running race fuel (little richer though)
My egt's around 1450 in a long 4th gear pull In fifth from 60-120 (closed course.. of course) I see around 1470*F
I have run them leaner, with no power result and no EGT increase, so I figured .3 richer at peak torque isn't going to hurt or help anything so I left it.
-Jerod
Step colder plugs really made a difference in egts... Lost about 10wtq but its worth it to drop egt's about 100*F
Old 02-09-2009, 03:30 PM   #25
JSarv
Member#: 163445
l33t *******
[email protected]
A little update. Had a corrupt rom (that is why boost looked the way it did, not because of creep.
Sold the AEM CAI to go with a big maf intake (probably P&L)
This is a run today with the stock airbox, boost peaked at 21psi at 3400 and held 20psi till 5k and tapered to 18...
I've got a little work to do yet with the boost, but my timing and afr's are were I want them. I still have about 15% IDC left now since I've leaned it out.
I lost 200 rpms of spool to peak boost, but lost about an average of 2psi from 2k-3.4k of boost per rpm with the stock airbox..
Stock airbox FTMFL!!! It felt so nutless below 3k with the stock airbox, where with the aem cai it pulled strong down low (Would almost imagine this would be related to reduced pre-turbine restriction with the intake)
This is an rpm log only with NO correction on a decently flat road.
Ambient was 72*F
ATM was 14.3psi
75% humidity and about a 20mph wind (partial headwind)
More to come when I get my intake and a few other little things tweaked, pm me for the log if you want it..
302 wtq at 4100rpms and 294hp at 6100
02 WRX TD05 Upgrades zcivic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 01-31-2015 08:55 AM
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
$7500 02 WRX Wagon TD05-18G suspension $$ in extras ( MT ) Montana part trades? eekenterprises Private Vehicle 'For Sale' Classifieds 1 04-14-2010 08:19 AM
02 WRX Wagon Stock 2.0L Blouch TD05 7cm^2 20g Tuned By AMS Krang Proven Power Bragging 34 01-10-2010 09:44 PM
stock 02 wrx and TD05 16G question dap7298 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 08-26-2008 11:18 PM
