Old 01-31-2009, 08:08 PM   #1
operating engineer
Member#: 62893
2008 STi
Default FSB question for my fellow "A Stockers"
Any of you guys run a 32mm Front Bar for daily driving? Don't feel like switching back after every event. Any negative side effect besides over powering your street tire?
operating engineer is offline   Reply With Quote
Old 01-31-2009, 08:53 PM   #2
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
While i'm not an A-Stocker... i am a STX guy.
i drove my WRX for 3 winters with a 27mm whiteline.. you won't have any problems.
shane86 is offline   Reply With Quote
Old 01-31-2009, 10:00 PM   #3
KC
Member#: 442
16 SS
00 S2000
It only helps in extreme cornering. Other than that... it's just a bar that connects the two sides of the lower suspension.
You're not gonna have a problem.
KC is offline   Reply With Quote
Old 01-31-2009, 11:24 PM   #4
Chiketkd
Member#: 71634
In hibernation...
+1 I drove my former D-stock '06 WRX for two years with the 27/29mm whiteline FSB. No issues whatsoever and it made the daily commute a little more fun in the turns!
Chiketkd is offline   Reply With Quote
Old 01-31-2009, 11:48 PM   #5
BrianGT
Member#: 75339
We ran a 32mm bar on our '05 AS STi for 2 years. Just watch your control arm swaybar mounting tabs. I am not sure how different they on an '08, but they tend to fatigue on the '05 and make the control arms a wear item.
BrianGT is offline   Reply With Quote
Old 02-01-2009, 12:38 AM   #6
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
bigger bars also make endlinks a wear item. if you have sphereical bearings in them watch out for the bumps! they will egg out soon. Im switching to poly on my 29mm fsb.
Dubstar112 is offline   Reply With Quote
Old 02-01-2009, 06:35 PM   #7
operating engineer
Member#: 62893
2008 STi
I have the perrin endlinks right now, I think they are spherical. What make is the poly endlinks. Would you recommend them for a 32mm bar over the spherical?
Old 02-01-2009, 06:50 PM   #8
kts262
Member#: 45464
91 E30 325i
95 E36 325is
yes perrin endlinks are spherical.
kartboy and group-a are poly endlinks (among a few others.)
kts262 is offline   Reply With Quote
Old 02-01-2009, 07:42 PM   #9
Niles
Member#: 138449
The '08+ STi has a significantly beefier front swaybar mount than the 04-07 GD did. The GD chassis swaybar mount was thin enough that it just fatigued away with the big bars if you did a lot of events. I still have a spare driver side arm from all the testing/breaking those tabs that I did. (in the FS section if anyone needs one ) The GR has held up much better to lots of abuse because the tab is about the full height of the control arm.
Niles is offline   Reply With Quote
Old 02-01-2009, 08:30 PM   #10
Draken
Member#: 16
1968 Saab
Sonett II V4
Originally Posted by Niles View Post
The GD chassis swaybar mount was thin enough that it just fatigued away with the horribly designed endlinks of the Strano/addco 31.75mm hollow bar if you did a lot of events, yet has no issues when running the 27/29 Whiteline.
fixed that for you.
Chris H.
Draken is offline   Reply With Quote
Old 02-01-2009, 08:50 PM   #11
Niles
Member#: 138449
I LOL'd
You mean using the same endlinks from my 1984 3/4 ton van on an STi swaybar was a bad idea!? :P LOL
Question for my fellow nerds. chompleh Texas Impreza Club Forum -- TXIC 9 04-13-2007 08:23 AM
Question to my Fellow Suby Drivers renzo Texas Impreza Club Forum -- TXIC 3 04-26-2006 03:39 PM
Intercooler question for my fellow desert dwellers Wrekaro South West Impreza Club Forum -- SWIC 3 04-28-2005 10:23 PM
Question for my fellow southsubarians panteras South East Region Forum 13 01-27-2005 06:41 PM
Question for my fellow Californians: "CARB" approved header for 2.5 RS? Tokay Bay Area Impreza Club Forum -- BAIC 2 06-12-2001 04:14 PM
