Old 01-31-2009, 08:37 PM   #1
eagle claw
Member#: 141384
2004 WRX,10sec Talon
Default Tell me why my car is doing this video inside
eagle claw is offline   Reply With Quote
Old 01-31-2009, 08:55 PM   #2
eagle claw
Member#: 141384
Old 01-31-2009, 09:57 PM   #3
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
Looks like the pill isn't in the boost line connected to the compressor. Without the pill it'll boost around 7psi when it should boost ~13psi.
This picture is in regards to having an aftermarket boost controller but you probably are using stock boost control so you need the pill. Where that arrow is pointing there should be a little pill inside the hose to bleed air through:
I don't know how or where to obtain that pill but you could probably order one from a dealer or online. Search around for the part number.
djoye is offline   Reply With Quote
Old 01-31-2009, 11:38 PM   #4
eagle claw
Member#: 141384
There is a pill in the line, the little lump in the hose correct?
Old 02-01-2009, 03:36 AM   #5
pyh
Member#: 188790
2008 EVO X
Yes, it is
I had the same problem)
pyh is offline   Reply With Quote
Old 02-01-2009, 11:32 AM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
just like someone who commented on the video, do you feel the car doing what the gauge is saying? could be a bad gauge.
Old 02-01-2009, 12:08 PM   #7
WeldingHank
Member#: 98645
2002 WRX Wagon
what are your mods?
edit: read the other post.
for whatever reason the engine seems to be overboosting and the ecu is correcting it. find out why its overboosting.
WeldingHank is offline   Reply With Quote
Old 02-01-2009, 12:51 PM   #8
Joe
Member#: 34694
rum love Joe
My car is doing the same thing. I am running Cobb stg 2, bosal downpipe, sti uppipe, sri, stock bpv. I did a vacuum leak test and everything was tight. Recently, the car will randomly only make ~7 lbs of boost in any gear, but other times it boosts to ~17psi. Do we have any parts in common? I have ~123k miles on the car.
Joe is offline   Reply With Quote
Old 02-01-2009, 01:24 PM   #9
tabrad
Member#: 157229
02 WRX
Thought that stretch of freeway looked familiar. My car used to do the same thing, some mechanics figured it was most likely a problem with the ecu itself, but fixed it easy just by putting a manual boost controller on
tabrad is offline   Reply With Quote
Old 02-01-2009, 01:28 PM   #10
eagle claw
Member#: 141384
Yeah I can feel the power coming on and off just as the gauge goes up and down.
BugI, My car is all stock.
Old 02-01-2009, 01:37 PM   #11
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
im getting the same problem here, but i dont know what it is
SUBYS R US is offline   Reply With Quote
Old 02-01-2009, 01:38 PM   #12
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i have had the problem and fixed it, there are three causes, 1 if Turbo dynamics, 2 is wastegate duty cycle is to high, 3 is you are hitting the surge line of the turbo, all of which are really bad for the turbo, and can cause major problems if its not corrected, if you have another map try loading that, or messing with yours, i believe there is an article about it on the romraider forums, i dont have time to find the link to it at the moment, i got work. if when i get off tonight yall havent found the problem, i can link to the explanations of each
seanathanq83 is offline   Reply With Quote
Old 02-01-2009, 02:02 PM   #13
eagle claw
Member#: 141384
Any info would be great.
Old 02-01-2009, 02:46 PM   #14
xevets
Member#: 177481
2003 WRX
Default Tell you why
Hello,
looks like your overboosting and its opening the wastegate to comepensate.
First off fiqure what your max boost under max load should be for your givin mods, i.e. 13.8 psi @ 4500 rpm in say fourth gear, if you are going above the max boost your ecu will tell the boost controller to open and close the wastegate. This happens pretty quickly, the boost will drop then rise again, drop, rise again and so on. Looks like you need to loosen up the wastegate arm a couple of turns so you do not overboost. I had this same issue using cobbs OTS maps stage2 and thats what helped me. When I remapped using open source I had to once again dial my wastegate to compensate overboost, works perfectly and rock steady. Stage 2 tdo4 18 PSI @4000~5500 RPM tapering off to redline. Good luck
Check this link for info>> http://www.xpttuning.com/osecuroms/v...php?f=34&t=325
xevets is offline   Reply With Quote
Old 02-01-2009, 03:22 PM   #15
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Just looking at the pic, curious...what's going on with your inlet hose? Is there no clamp on that and is the re-circ hose "glued" in...?
darkstarmoto is offline   Reply With Quote
Old 02-01-2009, 03:31 PM   #16
Joe
Member#: 34694
rum love Joe
I have been stg 2 for 2 years now and this problem is now just happening.
Old 02-01-2009, 04:06 PM   #17
eagle claw
Member#: 141384
That pic is not of my car?
Old 02-01-2009, 04:07 PM   #18
eagle claw
Member#: 141384
I just adjusted the wastegate 1 full turn and it seems better, as soon as it cools off I'm going to do another half turn.
Old 02-01-2009, 04:53 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
try some injector cleaner
Old 02-01-2009, 06:22 PM   #20
ogboot
Member#: 170906
psm
I think most would recommend resetting your ECU after doing this.
ogboot is offline   Reply With Quote
Old 02-02-2009, 12:42 AM   #21
spinx2005
Member#: 166276
1991 panda gsx
monster
Had same problem. People telling me i had hoses loose. I check re check and again. bought a 120 turbo inlet, nope not it. bought another pill and the vac. hoses to the turbo, nope not it. I would go to 21psi down to 15 back and forth on my tdo4.
And all along it was the factory boost solinoid. I put a homemade mbc on it and problems went away. you sould look into that. just saying .
spinx2005 is offline   Reply With Quote
Old 02-02-2009, 12:45 AM   #22
Joe
Member#: 34694
rum love Joe
And all along it was the factory boost solinoid. I put a homemade mbc on it and problems went away. you sould look into that. I mean with that many miles it held up as long as it could. just saying .
Thanks for the reply, this is what I originally thought as well and changed this a month ago with no change. If the OP wants to PM me, I have a stock BCS I can send for him to swap to see if it fixes his problem.
Can anyone tell me why my stylesheets on my website aren't working? Capt Crunch Off-Topic 9 02-01-2010 12:10 AM
Can someone tell me why my steering is not center after alignment? XyKo Brakes, Steering & Suspension 5 07-07-2007 12:48 PM
Help me figure out why my car is bucking/bogging at certain RPMS! vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-30-2006 08:29 PM
can someone tell me why my XP PC is too stupid... crowbar Off-Topic 6 03-07-2005 10:38 AM
Help me find out why my car is so slow MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-17-2003 12:16 PM
