Old 02-13-2010, 06:56 AM   #126
Scracho
Member#: 220449
2004 WRB WRSTi Stg2
Cobb, Invidia, Fujitsubo
Great thread!
Scracho is offline   Reply With Quote
Old 02-16-2010, 01:22 PM   #127
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
FuJi K is offline   Reply With Quote
Old 02-17-2010, 07:58 PM   #128
2slofouru
Member#: 90539
95 340whp impreza
05 Raven R6, 07 2.5i
Is that a little clacking sound at the beginning of acceleration or just camera noise? (at 3 to 4 seconds)
2slofouru is offline   Reply With Quote
Old 02-17-2010, 08:10 PM   #129
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I dunno... probably. Not my video. But it's a nice to see RPMs!!!
Old 02-17-2010, 08:11 PM   #130
2slofouru
Member#: 90539
95 340whp impreza
Just saying because it sounds like my mystery clack... just before load. Revving to the sky for sure!
Old 03-22-2010, 01:07 PM   #131
DuckStu
Member#: 124060
2004 WRX STI
Factory Gear Ratios for Reference
All-Wheel-Drive 6-speed Transmissions
3.636 / 2.375 / 1.761 / 1.346 / 1.061 / 0.842 / 3.900FD
- JDM Impreza WRX Spec C/STi/STi Spec C RA/V-Limted/S202/S203/S204/Spec C RA-R
- AUS Impreza WRX STi
3.636 / 2.235 / 1.521 / 1.137 / 0.971 / 0.756 / 3.900FD
- USDM 2007-current Impreza WRX STi
3.636 / 2.375 / 1.761 / 1.346 / 0.971 / 0.756 / 3.900FD
- USDM 2004-2006 Impreza WRX STi
- UK/Europe/NZ Impreza WRX STi
- JDM Legacy 3.0R Spec B
3.636 / 2.235 / 1.521 / 1.137 / 0.891 / 0.707 / 3.900FD
- USDM 2007-current Legacy 2.5GT Spec B
- JDM Forester STi
Something is wrong in here. The '07 USDM STI does not have the same FD ratio as the earlier years,...and I think the 5th and 6th gears are the same.
DuckStu is offline   Reply With Quote
Old 03-25-2010, 11:20 PM   #132
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The tranny runs a 3.900FD. The rear diff of the '06+ STI's run 3.545 with the 1.1:1 step-up transfer gear in the transfer case.
Old 03-26-2010, 02:11 PM   #133
03SEDAGON
Member#: 218744
2003 WRX Wagon
Platinum Silver Metallic
Hey guys had a question I was hoping to get some help with. My 03 wrx wagon's rear diff is gone. I was looking at Fuji K's list of gear ratios and trying to figure out if I can use a diff from another subaru with the same 3.900FD or do I have to use a 02-03 wrx rear diff? Also, when I bought the car the transmission's gears had been rebuilt with 06 wrx gears. Any help would be greatly appreciated, thanks
03SEDAGON is offline   Reply With Quote
Old 03-26-2010, 08:40 PM   #134
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If the gears are just the ones that got replaced, then your final drive should still be 3.900 in the tranny, meaning the rear diff stayed the same. You need to find a rear diff from an 02-05 WRX.
Old 03-28-2010, 02:45 AM   #135
huey1133
Member#: 206126
2003 wrx
black
Default jdm ratios?
are the factory gear ratios the same im both the jdm and usdm 5 spds?
huey1133 is offline   Reply With Quote
Old 03-28-2010, 10:00 AM   #136
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
it depends which years.
i.e. Now, '08+ the USDM turbo 5spds are running what the '97-'00 JDM STi/WRX used to run.
Old 03-29-2010, 06:40 PM   #137
paulh
Member#: 208854
Just wondering if '05+ LGT gears are the same width as the older '97-'00 JDM STi/WRX gears? Or are they the same as the narrower gears that we have in the older USDM transmissions?
paulh is offline   Reply With Quote
Old 04-01-2010, 01:46 AM   #138
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Anybody kn ow the FD of the 02 wrx wagon A/T trans?
dirtslayer is offline   Reply With Quote
Old 04-03-2010, 04:12 AM   #139
Jaships
Member#: 56924
2004 Impreza WRX
World Rally Blue
so did I read right.....LGT gears Are Stronger then 04 wrx gears and are a good upgrade??....or just spend 400 more for ra gears?
Jaships is offline   Reply With Quote
Old 04-06-2010, 10:47 AM   #140
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I can't say. I would question it though since Subaru said they widened the '03+ tranny gears on the WRX, wonder if they did the same for the '05+ LGT. Don't hear too much broken tranny stories on the LGT's.
Originally Posted by dirtslayer View Post
Anybody know the FD of the 02 wrx wagon A/T trans?
4.111FD
I hope you know that the LGT gear ratios and the STi RA ratios are a bit different. The LGT ratios are geared with a bit less gap between shifts. The gearing helps save themselves. I just wished the case was made to have ribs like the 6spd.
Old 05-10-2010, 11:43 PM   #141
newclutch
Member#: 222415
03 WRX
W R BLUE
I road course so I put in 1-4 M-Factory close ratio gearset and left the stock 5th because it is a DD.
With hindsight I think I should have used M-Factory 1,3,4,5 and then the stock 5th for highway crusing. On a track I do not need 2nd gear for any corner. It is only good for autocrossing. The jump from M-Factory 4th to stock 5th is Huge and I runout of rpms (in 4th)at all the tracks I go to. I drop it into 5th and the RRs are to low.
newclutch is offline   Reply With Quote
Old 05-11-2010, 11:52 AM   #142
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here's a vid of my JDM 6spd. I'll have to make another one.
Old 06-07-2010, 12:25 PM   #143
04stinugget
Member#: 236332
200 wrx sti swap
sonic yellow
how about doing a write up on tranny drive ratios in cooperation with rear diff ratio so that us noobs know that when were putting in lsd's and changing gearing/trannys we know what works and what doesn't? I know it would help me.
04stinugget is offline   Reply With Quote
Old 08-16-2010, 08:38 PM   #144
GusGus91
Member#: 201312
Im putting an 06 sti 6spd into my 06 wrx tr... What Rear diff do I need to get to put the tranny in.. I'm having a bit of trouble figuring this out.. I wanna make sure Im right the first time..
GusGus91 is offline   Reply With Quote
Old 08-18-2010, 10:07 AM   #145
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If you're looking for a 3.900FD R160
NOTE: REAR DIFF Final drives are tranny specific
'98-01 5spd Impreza L/Sport wagon 5spd, or 5spd 95-99 Legacy 2.2L models 3.900 Open diff
02-07 5spd Impreza TS/RS wagon/outback sport 3.900 Open diff
06-07 Auto WRX 3.900 VLSD
Part#
27011AA650 3.900
27011AA660 4.111
27011AA670 4.444
Old 09-14-2010, 09:49 PM   #146
RossLH
Member#: 147839
2003 WRX
SRP
A bit of a late response, but it was just my camera. It was professionally rigged to the steering column cover with duct tape. That was back when I was running an EJ205 and VF34....new videos will come soon with my EJ205/257 hybrid, FP Green, and JDM '02 STi 6-speed.
RossLH is offline   Reply With Quote
Old 09-21-2010, 01:31 PM   #147
smokey07
Member#: 151683
both myself and my buddy, who has an 03 wrx making around 390whp, were wondering what gear ratios he has. It has an andrewtech 1-4 ppg set.
running on 225-45-17's, he ran it out to 7500 in 2nd gear, looked like we were right at 75mph. i believe the gears were put into his 03 trans case because when he bought the gears originally, the case was cracked.
any ideas what ratios they may be? thanks for the help!
smokey07 is offline   Reply With Quote
Old 09-21-2010, 02:43 PM   #148
RossLH
Member#: 147839
2003 WRX
SRP
Are they straight cut? If not, your friend has the standard PPG helical synchro box. The ratios are as follows:
3.18 / 1.87 / 1.32 / 0.95 / OEM (.738)
The 1.87 2nd gear will take you to a theoretical 76mph with 225/45/17's. If it is a straight cut synchro box, it'll have the slightly taller 3.08 1st gear.
Old 10-03-2010, 01:14 AM   #149
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
According to my various FSM I've amassed over the years, the 2002-2005 WRX 4EAT had 4.111FD; 2006-2007 had a 3.9FD. Skimming over it, I don't see anything about having a 1.1:1 center diff anywhere in the FSM for the automatics. Would it be possible to use the '06-'07 4EAT rear diff when swapping in an '04-'05 STI 6MT without the R180/hubs/etc?
The car is paid off and mine until the floorboards rust through, so lets not get into the "shoulda bought a manual"/"go buy a manual" discussion please.
OrbitalEllipses is online now   Reply With Quote
Old 10-06-2010, 11:04 PM   #150
Dori Ninja
Member#: 73974
04 RSTi
so...saw this..but it doesnt correspond to the charts on p.1 who is right about the FD on this??
http://cgi.ebay.com/ebaymotors/JDM-V...item5adc81a0be
it says 4.44
Dori Ninja is offline   Reply With Quote
This why you learn to do your own vehicle maintenance. BacDoc Off-Topic 156 02-22-2008 09:58 PM
Sources for learning to Tune your Car? plus plus plus Newbies & FAQs 7 06-19-2007 03:56 AM
How to choose your own spring rates (and get the spring frequencies correct) stretchsje Brakes, Steering & Suspension 2 05-16-2007 01:55 PM
Learn To Open Your Doors Dooley Mid Atlantic Impreza Club -- MAIC 25 10-04-2006 04:15 PM
For crying out loud people, learn to title your threads well! Brady Off-Topic 12 05-15-2005 08:57 PM
