Old 10-24-2010, 06:57 PM   #151
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
http://flatironsrally.typepad.com/fa...-and-more.html
interesting little writeup on the difference in the gearsets of the 02(03-07)wrx gearsets and the lgt and RA gearsets. for all you wrx owners out there who just want to know. I figured i could add to this thread.
em1bugeye is offline   Reply With Quote
Old 10-25-2010, 11:41 AM   #152
charliew
Member#: 125304
Great info. I only wish the thickness of the gears could have also been added but I guess their are really only two different 2nd gear and third gear sizes so it isn't a big deal. It would be good to have if you come by some take out gear sets cheap.
charliew is offline   Reply With Quote
Old 10-25-2010, 01:18 PM   #153
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
really great info thanks em1bugeye!
blakkboxer is offline   Reply With Quote
Old 10-27-2010, 04:54 PM   #154
firesword777
Member#: 237852
13 WRX
This is a wonderful resource.
If I wanted to try to get an OEM WRX 5th gear from 06 or 07 should I try my local dealer or is it more than likely they won't have it?
firesword777 is offline   Reply With Quote
Old 11-06-2010, 09:31 PM   #155
CSibbs
Member#: 262532
'12 STI
Hey guys, Great thread Fuji.
I was wondering what gearset I should get for my 05 WRX.
Its a daily driver, but at the same time, I'm going to be taking it to the track soon, and when when I do my daily driving Im going 60mph @ 3000 rpms. I dont really like to keep my RPMs over 3k because you burn up gas. So I was wondering what gearset has a nice get up and go, and has a decent top end speed. I'm also on a budget...kinda. Haha.
Im running 20lbs of boost if that helps at all.
Thanks
CSibbs is offline   Reply With Quote
Old 11-07-2010, 12:35 AM   #156
RossLH
Member#: 147839
2003 WRX
SRP
20psi on which turbo?
RossLH is offline   Reply With Quote
Old 11-07-2010, 03:53 PM   #157
CSibbs
Member#: 262532
'12 STI
HTA68
Old 11-07-2010, 04:06 PM   #158
RossLH
Member#: 147839
2003 WRX
SRP
When you say you're at 3000RPM going 60mph.....why dont you shift into 5th?
As far as gears go, "budget" builds really wont offer any extra strength. The cheapest, most reliable way I could think to go is to find a used PPG gearbox in the classified section. When it comes to the 5-speeds, you really need to do it right the first time.
Old 11-07-2010, 05:28 PM   #159
CSibbs
Member#: 262532
'12 STI
...that is 5th.
Old 11-07-2010, 06:09 PM   #160
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
i think he meant 6th gear
jk
Old 11-07-2010, 06:18 PM   #161
RossLH
Member#: 147839
2003 WRX
SRP
Originally Posted by CSibbs View Post
...that is 5th.
Even if you're running the stock 205/55/16's on a stock transmission (0.738 5th gear) and rear end (3.545 rear + 1:1.1 center = 3.90), 60mph should leave you just over 2200RPM. Either somethings wrong, or you have some upgraded gears in there already. With that kind of cruising speed, it almost sounds like you'd have the MFactory 1-5 gear set--that'd leave you right at 60mph at 3000RPM.
Old 11-07-2010, 06:23 PM   #162
CSibbs
Member#: 262532
'12 STI
Erm...to be honest I dont know what kind of gears are in it...
Old 11-07-2010, 06:27 PM   #163
RossLH
Member#: 147839
2003 WRX
SRP
:facepalm:
Thats a little sketchy. Did you buy it from a dealership?
This might seem like a bit of a pain in the ass, but (assuming all is mechanically well) if you can post up the speed at....say....3000RPM in every gear, I might be able to help you figure out what you've got. Maybe you wont need an upgrade after all.
Old 11-07-2010, 06:29 PM   #164
CSibbs
Member#: 262532
'12 STI
:facepunch: !
nah, i bought it from a guy off craigslist. He had all his upgrades done at precision tuning in lakewood and had the receipts for everything.
Old 11-07-2010, 06:33 PM   #165
RossLH
Member#: 147839
2003 WRX
SRP
Might be easier to just ask him what he did to it, in that case. It'd be beneficial in the long run to know that car inside and out, so if something goes wrong you have some idea of where to start.
Old 11-07-2010, 06:53 PM   #166
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
But sounds like he already has his gears and possibly the diffs done for his benefit........ I guess he doesn't have to worry about anything for the transmission at the moment.....
trxdam is offline   Reply With Quote
Old 11-07-2010, 08:21 PM   #167
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Thanks
With that said and the above..... maybe swap tranny with someone with PPG?? The '07 STi 6spd or say a rebuilt 6spd with the "high speed/Legacy Spec B" ratios is a good tranny for what you seek. It drops the RPMs a tiny bit from what a normal WRX has.
Another option is PPG's with a '06/07 WRX, which runs a 3.700FD. This drops the rpms a bit, which will also give you the lower RPM in 5th on the hiway. The stock gearing can break so that's why I included PPG gears. Remember to swap the rear diff. Down side is that the longer ratios make driving with a 2.0L a bit of a dog.... not as preppy.
FuJi K is offline   Reply With Quote
Old 11-27-2010, 07:36 PM   #168
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
thought I'd add this.... my personal car. Not really going all out.
3.636 / 2.375 / 1.761 / 1.346 / 1.061 / 0.842 - 3.900FD
'04 JDM DCCD 6spd shifting at about 7000rpm
Old 11-27-2010, 08:01 PM   #169
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
^hahahaha sup with that gay laugh
Old 11-27-2010, 08:34 PM   #170
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i had fun!!!! hahah sorry... it's just a character I have... the locals would know.
that was the last day I had the 20G on. Converted back to pump gas from E85 and TD04L turbo. Next year will have the BorgWarner TS setup.
Old 12-13-2010, 12:07 PM   #171
shooting
Member#: 82720
1993 any 93 + subaru
dirty or snowy
Default six speed variables
hey fuji great info.
wondering about 6 spds and the changes they've made.
so 04-06 sti usdm had a cooler right?
07 sti is new gear ratio and no cooler?
wondering the difference from 07usdm to jdm v7 and v8? Seeing alot of jdm trannies for sale, any problems with these as far as maintanence? can we get the gears and parts or are they similar to usdm? SInce you are using one maybe you could give us insight for jdm 6spd parts. Didnt see v8 jdm on your list.
whats different?
jdm v8 spec c vs regular jdm v8sti?
jdm v7 vs jdm v8?
using a 93 cable driven dash what works with that?
thanks for the help, the trannies the last part on my build, time to actually hook some of this power, 2 by legacy tranny against boost is extremely useless. and @ only 250 whp and trq. HAHA thanks for the help!
shooting is offline   Reply With Quote
Old 12-24-2010, 12:56 AM   #172
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I guess this webpage shows a little bit when you look at the NOTEs
http://spda-online.ca/modules/tinyco...ite/tc_28.html
The first 6spds had the internal oil pump. '07 was when they took it off.
http://forums.nasioc.org/forums/show....php?t=1574301
The gears can be swaped since they are the same casing. Difference really from USDM to JDM is just the gear ratios like what you see listed on the first page of this thread. I could USE the newer style syncro cones etc in my Ver8 6spd. Also I could use better shift forks too.
JDM 6spds vary in DCCD or non DCCD. This is model specific. Models with STi badging usually always have DCCD as it is an STi feature. WRX RA Spec C will NOT have DCCD.. WRX RA STi Spec C will have DCCD. Impreza WRX STi has DCCD. Impreza WRX Spec C will not have DCCD. All the gearing is the same for Japan since the start of the 6spd.
With your cable driven cluster, you can take off the speedsensor on the tranny and swap your cable wire onto it. Remember the washer!
Old 01-07-2011, 03:42 PM   #173
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
So it looks like a Trans upgrade is in my future for my 2002 WRX and now comes the fun part of picking which company to go with.
This will be for a weekend toy, so I would like something that is still comfortable running errands for the wife in, but can take 350-400 HP when I want to play.
So far I am looking at about $4K for a set-up from Andrewtech.
On Rallispec's website I saw they have RA/STi Gear sets for a much cheaper price. So will a gear set form Rallispec hold up to the power levels I have?
I realize that I will have to have the Rallispec set installed and that the Andrewtech box comes fully built. A friend of mine is a Subaru Mechanic so the install will be no problem.
So I guess what I am asking is will the Rallispec Set be enough or do I need to just go ahead and get an Andrewtech Box.
Thanks.
RALLYT-WRX is offline   Reply With Quote
Old 01-30-2011, 11:11 PM   #174
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
well..... give it a shot. If it doesn't hold well... then maybe I lied? Drive well and it should hold fine.
Vid added
3.636 / 2.375 / 1.761 / 1.346 / 0.971 / 0.756 / 3.900FD
'04-'06 USDM STi 6spd shifting at about 3000rpms
Old 02-07-2011, 05:28 PM   #175
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This why you learn to do your own vehicle maintenance. BacDoc Off-Topic 156 02-22-2008 09:58 PM
Sources for learning to Tune your Car? plus plus plus Newbies & FAQs 7 06-19-2007 03:56 AM
How to choose your own spring rates (and get the spring frequencies correct) stretchsje Brakes, Steering & Suspension 2 05-16-2007 01:55 PM
Learn To Open Your Doors Dooley Mid Atlantic Impreza Club -- MAIC 25 10-04-2006 04:15 PM
For crying out loud people, learn to title your threads well! Brady Off-Topic 12 05-15-2005 08:57 PM
