Old 05-05-2011, 10:52 PM   #201
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
ski racks help especially if you have the deflector on the front of they it helps channel the air up and away
emsbuff124 is offline   Reply With Quote
Old 05-05-2011, 11:01 PM   #202
RossLH
Member#: 147839
2003 WRX
SRP
You couldn't be any more backwards. Ski racks add a fair chunk to the frontal area. More frontal area = more drag. Generally speaking, someone with a ski rack mounted on their rails will get up to 4mpg LESS than those who dont.
RossLH is offline   Reply With Quote
Old 05-05-2011, 11:06 PM   #203
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
they you probable dont have it set up correct. I know this cause ive seen the wind tunnel tests if you have the install done right it allows for better are flow over the top of the vechicle much like a big rig wind deflector. now if you ski rack has room for the air to get around it then yes your getting yes mpg because your creating more drag
Old 05-05-2011, 11:13 PM   #204
RossLH
Member#: 147839
2003 WRX
SRP
Dude....just dont.
And for the record, big rigs use air deflectors over the cabin in order to smooth out the sudden transition from the roof of the cabin to the taller roof of the trailer. They do not add any frontal area. Key term here: frontal area. Please dont make me go all engineering nerd here. I'm asking nicely.
Old 05-08-2011, 02:50 PM   #205
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Go bigger turbo. This way the turbo doesn't spool up so quick. Running my TD04L on my JDM 6spd sucks on the hiway because the moment you give it some throttle the turbo rolls into boost.
FuJi K is offline   Reply With Quote
Old 05-08-2011, 05:45 PM   #206
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
i have a vf43 on the car now, i may go 20g latter on i figure i be ok cause the vf43 is an STI turbo
Old 05-08-2011, 06:10 PM   #207
RossLH
Member#: 147839
2003 WRX
SRP
The VF43 wont be terrible, but you may find yourself boosting undesirably high when going uphill.
Old 05-08-2011, 08:24 PM   #208
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
What's a good turbo up grade from the vf43 I don't want to go to crazy 350 whp max
Old 05-08-2011, 08:27 PM   #209
RossLH
Member#: 147839
2003 WRX
SRP
20G or FP Green should do the trick.
Old 07-30-2011, 07:30 PM   #210
kurlyfries
Member#: 282131
2006 tacoma
black
so according to the info given... i should probably go with ppg straight cut 1/2 since im running 350whp on an 02 stock 5spd and want to be able to dump the clutch at about 5k and what not, right?
kurlyfries is offline   Reply With Quote
Old 08-06-2011, 05:35 PM   #211
limeylight
Member#: 5428
97 Legacy Outback
This is a very interesting thread but I only read the first page.
I just lost second gear in my EG33 swapped 97 Legacy Outback with 140,000 on the original tranny and 1000 on the new engine so it destroyed it pretty quick. Engine puts out about 230 ft.lbs I think.
So I have to do something about this, probably get it rebuilt rather than throwing in another high mileage box. Ratios seem fine to me except if 5th was way bigger that would help getting to events. It seems to have the 4.111 LSD in it. stock center viscous and open front. I do have a brand new KAAZ diff sat on the shelf. Should I throw that in? Car is used for autocross, rallycross and track days. If I'm going to rebuild it what should I change while I'm in there and can I get a much bigger 5th gear out of this job?
Not looking to spend a fortune either.
limeylight is offline   Reply With Quote
Old 08-07-2011, 11:22 PM   #212
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
so Im i need a little advice, I finally got my WRX back on the road after an 04 STI 6speed swap. I love how the car just wants to get up and go threw the lower gears but up top when im in over drive (6th gear) @ 80mph the drone from the exhaust reminds me of my old 5speed when i was cruising in 4th gear before hitting 5th.
I was wondering could I do a hybrid set up where i keep my 1-4 gears stock and have my 5th and 6th gears a little longer? or should i look for a 07 and up sti gear set?
Old 08-07-2011, 11:42 PM   #213
limeylight
Member#: 5428
97 Legacy Outback
Sounds like wat I want in a 5 speed.
Old 08-08-2011, 09:36 AM   #214
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
the 6speed is great do not get me wrong I love it i just wish i could make my 5 gear longer and my over drive 6th gear a little longer too dk how to go about it
Old 08-10-2011, 09:58 PM   #215
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
change it out to the spec b gears.
Old 08-11-2011, 12:54 AM   #216
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
thats what i have been told to do, any idea on cost for them and which ones that would work?
Old 08-11-2011, 02:11 AM   #217
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
give rallispec a call.
Old 08-11-2011, 08:23 AM   #218
limeylight
Member#: 5428
97 Legacy Outback
Shipped it off to Thompson Racing Fabrication for a tranny rebuild and KAAZ lsd after breaking 2nd gear.
Still would like a taller fifth when all is done. Easy to swap in or do you need a whole gearset? How tall a fifth can one get?
Old 08-12-2011, 02:17 PM   #219
WagonMafioso
Member#: 222641
Is the JDM STi 6 Speed the same a USDM STI in the way that is compatible with USDM engines upgrading to a 6 Speed? or do I need something different using JDM 6 Speed? Can I use USDM diff, linkage, crossmember etc..?
WagonMafioso is offline   Reply With Quote
Old 08-13-2011, 08:25 PM   #220
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
as long as you have the matching final drive everything bolts up the same.
Old 08-13-2011, 10:50 PM   #221
WagonMafioso
Member#: 222641
Uff nice, thanks for the info .
Old 08-14-2011, 12:05 AM   #222
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
hmmm i got to take a look at that
Old 09-02-2011, 12:22 PM   #223
H2OSB
Member#: 71310
'06 LGT Sedan
Ok, at present this is hypothetical, so please don't be cruel in responding.
I want to build a second gen LegacyGT for autocrossing. This is a project car for fun because like to tinker with cars, however, I'm no cone carving guru, so I'm not planning something that will get me to solo nationals. I've been autocrossing for many years, off an on, so I know the general idea, but I've never run a can with a swapped engine, so I'm kinda starting from scratch.
What I'd LIKE to install in the car is one of the following: EJ22(t) hybrid (EJ205 heads), EJ205, or a EJ255/57. Of those, I think the closed deck block with WRX heads is the most interesting, followed by the 55/57. It's not that I want to build something that will take 30psi of boost, but I don't want to worry about block strength ever, should I decide to get crazy someday. I'm a Cali guy, so it would be nice to have a smog legal car, however, if that's even remotely difficult, I"ll trailer the car's to events.
That said, the REAL point of my post is about gearboxes. I want to install I decently close ratio gear box with a 3.90 or 4.11 FD. 5 Speed is perfectly ok, as I rarely get passed 3rd gear with my '06 LGT when autoXing. My concern is about gearbox strength.
I know the USDM '02-'05 MY gearboxes had some design flaws the manifested themselves if the power levels got above stock levels. Is there a particular JDM box that would be ideal for what I'd like to do? I would really like to avoid things like DCCD. In other words, what OE gearbox has the best case strength that might also have ratios that would be helpful to me?
I know the search feature is my friend, and I used it quite a bit before I decided to post, but I never zero'd in on what I would like to know.
Thanks in advance
H2OSB
H2OSB is offline   Reply With Quote
Old 09-02-2011, 01:55 PM   #224
RossLH
Member#: 147839
2003 WRX
SRP
Sounds to me like you want a JDM STi 6-speed. Short ratios, all the beastly strength of the 6-speed, and available with a non-DCCD center diff.
Old 09-04-2011, 11:40 AM   #225
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Thanks in advance
H2OSB
that is the best answer
This why you learn to do your own vehicle maintenance. BacDoc Off-Topic 156 02-22-2008 09:58 PM
Sources for learning to Tune your Car? plus plus plus Newbies & FAQs 7 06-19-2007 03:56 AM
How to choose your own spring rates (and get the spring frequencies correct) stretchsje Brakes, Steering & Suspension 2 05-16-2007 01:55 PM
Learn To Open Your Doors Dooley Mid Atlantic Impreza Club -- MAIC 25 10-04-2006 04:15 PM
For crying out loud people, learn to title your threads well! Brady Off-Topic 12 05-15-2005 08:57 PM
