Old 02-01-2009, 01:46 AM   #1
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
Unhappy 05 STi Aux wiring help needed.
Ok, so I've got a set of Hella 500 driving lights that I'm trying to wire up, and I'm running into a problem getting a 12v signal from the high beams (I want the 500's to come on when the High beams are turned on).
From what I can find out it's due to the high beams running off a switched ground, so both wires going to the light are hot at all times so I can't use them as a signal. And it seems my only two options are to run another relay which I don't want to do, or tap into the signal coming from the stalk on the steering column which is what I want to do, but cant seem to find out what color wire the high beam signal is.
Can anyone with a 05 Sti wiring diagram help me out?
Thanks in advance.
WhiteKnightSTi is online now   Reply With Quote
Old 02-01-2009, 03:26 AM   #2
Horkus
Member#: 112667
2002 WRX wagon
red on right
white black on left.
(-) controlled signals for high beams.
steering column one is red color.
Pls test before connection.
Do this at your own risk
Horkus is offline   Reply With Quote
Old 10-19-2009, 12:15 AM   #3
Turk84
Member#: 90696
2005 WRX Wagon
Anybody have more insight into doing this?
I'm trying to wire in some PIAA 520's on my wife's WRX and want her to be able to turn the AUX lights on and off with the high beams. I thought I could tap into the high beam itself but ran into the same problem the OP had.
Thanks,
~Turk
Turk84 is offline   Reply With Quote
Old 10-19-2009, 12:41 AM   #4
jutes85
Member#: 127232
Do You
Even Subaru
Thanks,
~Turk
You really have to look at a wiring diagram for your year to see which is the hotwire for the high beams.
jutes85 is offline   Reply With Quote
Aux wiring help needed Turk84 Alaskan Impreza Club Forum -- AKIC 9 10-19-2009 06:39 PM
Hella AUX. Wiring help (I have done a search) theicewall Electrical & Lighting 17 12-30-2004 09:41 PM
STI stereo wiring help needed WRC-STI Car Audio, Video & Security 2 11-29-2003 02:56 AM
Tach wiring help needed Rovah New England Impreza Club Forum -- NESIC 2 08-07-2002 01:35 PM
Wiring help needed Fred Zaplitny Car Audio, Video & Security 0 01-09-2002 09:22 AM
Message Board Statistics All times are GMT -4. The time now is 04:07 PM.
