Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-02-2009, 02:12 AM   #1
qwkwrx
Member#: 56096
2005 WRX
psm
Default reflash to stock?
if a car was tuned on open source but a utec is going to be installed and tuned, does the car have to be flashed back to stock through open source before hooking up and tuning the utec?
also, what is the purpose of the plug that goes to a 9v battery?
qwkwrx is offline   Reply With Quote
Old 02-02-2009, 10:24 PM   #2
pjm
Member#: 73755
05 STI
That 9v battery plug is so you can play with the utec outside of the car.
Can't say about the open source tune. If it was mine, I'd go back to stock ecu before tuning the utec.
pjm is offline   Reply With Quote
Old 02-02-2009, 10:50 PM   #3
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
9 volt in is so you can hook the UTEC to your desktop computer out of the car and flash firmware or load maps.
The open source tune depends on what you want to do, and what has been "tuned" in the opensource tune. The two tuning systems are quite compatible. The OS tuning allows you to tune maps that the UTEC cannot access, and the UTEC allows switching maps on the fly.
bcblues is offline   Reply With Quote
Old 02-03-2009, 02:37 PM   #4
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
You do not need to go back to stock flash if you car was tuned with open source. You just have to remember to properly set up your utec if you decide to use OPEN LOOP FUELING.
What ever you program into the utec is what the utec will do, it doesn't care about the stock ecu. The only place I see over lap is if you base your utec fuel map off your stock ecu map (not using OPEN LOOP FUELING). The other over lap is anywhere you have ecu (use stock ecu value/signal) programmed into your utec map.
NITROS is offline   Reply With Quote
Old 02-03-2009, 08:53 PM   #5
pjm
Member#: 73755
05 STI
Bcblues and Nitros are right. The UTEC will work with an open source flash. I've read many people having great success with it. I just haven't messed with it myself. I guess I should have said, I would prefer to know what was done with the open source tune.
Reflash to stock...does it need to 'relearn'? 09rexwagon AccessPort 5 12-30-2009 05:58 PM
need to be reflashed back to stock!!! please help rebel1988us Mid Atlantic Impreza Club -- MAIC 4 02-09-2009 11:15 PM
AP2 Reflashing To Stock Help Needed vf15hammer Texas Impreza Club Forum -- TXIC 13 11-03-2008 11:59 AM
I Need Someone To Reflash Ecu To Stock fluxcapacitor Southern California Impreza Club Forum -- SCIC 10 02-01-2008 04:52 PM
removing utec do i need to get the stock ecu reflashed to stock phobos sti UTEC 12 09-07-2007 12:02 AM
