Old 02-02-2009, 08:08 AM   #1
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
Default Stromung Midpipe Help! Need Help FAST!
Im ordering a stromung 2.25" midpipe for my 2.5rs but i have the current(stock) midpipe rotated so it fits with the jdm sti genome that i have on there right now..
i am sure if i order a 2.5rs midpipe through stromung.. it wont bolt upto my axleback.. is the 2.5i angle any different in ways of possibly helping me out.. what do i do?
help please!
CoBB_tHiS! is offline   Reply With Quote
Old 02-02-2009, 08:28 AM   #2
piker28
Member#: 22664
Well I prefer to look at it this way. Why pay all that money for that piece if you are going to have to slice the end off of it and make it worth alot less than it was.
If I was you custom is the way to go.
Now the 2.5i midpipe would have the proper axleback flange but I believe its longer. But to get the true proper answer you can just pm them at boxerracing and they should be able to tell you
piker28 is offline   Reply With Quote
Old 02-02-2009, 09:39 AM   #3
Syph3r_
Member#: 150804
2015 STi
CWP
I would PM boxer for sure but I do know that the STi Genome will bolt up to the stock (06/07) 2.5i midpipe as the axelback portions on the exhaust are the same as the WRX/STI on the 2.5i
So with that logic, if you already cut/extended fit your mid pipe to fit the Genome, then why are you just ordering the Stromung midpipe? I could see if you went with a full stromung setup but....
Syph3r_ is offline   Reply With Quote
Old 02-02-2009, 04:09 PM   #4
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
shop quoted me around a 100 bucks to build together a midpipe using my stock flanges out of 2.25" piping...
worth the spending?
Old 02-02-2009, 05:47 PM   #5
piker28
Member#: 22664
i mean that is not bad at all if you are ok with not having your stock midpipe anymore. But also make sure the piece is stainless steel, and find out how they make it.. mandrel bend or crush bent etc
Old 02-02-2009, 06:02 PM   #6
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
well i have the 2.25" piping... i have recieved it from a buddy of mine who works at a piping shop.. it is steel not stainless.. a bit lighter and it is also coated in a serious amount of high temp paint haha
Need Help, Need Help nicholas112481 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-10-2010 01:24 PM
Help! Need very fast enlargements of digital pics... mexicanpizza Off-Topic 17 11-27-2007 03:04 PM
Need help fast! subywrxtuner6969 General Community 2 03-13-2007 09:55 PM
HELP HELP HELP Need help diagnosing a clutch problem.... redoktober_99 Tri-State Area Forum 9 02-06-2007 10:28 PM
Midpipe Diameter...need help fast before i install right now silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-14-2006 02:17 PM
