Old 02-02-2009, 01:45 PM   #1
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Default Power cutting out at autox?
So today was my first autox with my new rotated turbo setup. Everything was going great except at certain points of the course the power would suddently cut out. It was like I hit a brick wall and the car just said no more. It was always in the upper rpms 6k+ in 2nd gear. It was quite bumpy where the power would cut out. Would that have anything to do with it? I know when it's bumpy and the car gets light the abs dies and the brakes don't work. I wouldn't think it would be a fueling issue as I had a half tank of gas. The weird thing is i shifted to 3rd in one of the bumpy sections and the power didn't cut out. And on the way home I checked the car and it ran perfect up to my 7500 rpm rev limit in 2nd gear. Anyone ever experience anything like this?
pignoseSTI is offline   Reply With Quote
Old 02-02-2009, 02:07 PM   #2
digitalseance
Member#: 104400
169k mile race car
Mine cuts real bad all through the RPM range on my first run. After that, it never does it again for the entire day. I'm thinking spiders and goblins for me, or maybe the leaded fuel is truely causing deposits that get cleared after the first run...I dunno.
digitalseance is offline   Reply With Quote
Old 02-02-2009, 02:27 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I've been in STI's at the track that have fuel cut from starvation with 1/2 tank of gas, so it's definitely possible that's what happened.
Old 02-02-2009, 02:39 PM   #4
wagonman
Member#: 971
If it was mainly doing it in a sharp, sustained right hand corner, it sounds like fuel starving.
My RS wants over 1/2 tank to keep from starving.
wagonman is online now   Reply With Quote
Old 02-02-2009, 02:45 PM   #5
dunk
Member#: 15359
It's probably fuel starvation.
-Duncan
dunk is offline   Reply With Quote
Old 02-02-2009, 02:57 PM   #6
mla163
Member#: 104922
2013 BRZ
yep, I've had fuel cut at 3/8 tank
mla163 is offline   Reply With Quote
Old 02-02-2009, 03:21 PM   #7
theBrick714
Member#: 121967
06 STi
I agree with them, sounds like fuel startvation. I freaked me out the first time it happened to me. By the way, what rotated kit did you go with, I have p&l's gt3071 on order, it was a tough decision between that and the 3076, but p&l says they developed th 3071 for autoX. I can't wait for spring
theBrick714 is offline   Reply With Quote
Old 02-02-2009, 03:55 PM   #8
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
i don't think it's fuel starvation as it was in straights when it happened. I've run it numerous times with a half to a quarter tank with no issues before.
Old 02-02-2009, 03:56 PM   #9
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
I have a pieced together (basically a modified Perrin) kit with a gt3076 .63 hotside turbo. Was great when it was working hahah
Old 02-02-2009, 03:59 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
If it's not fuel starvation....it's something worse. Try to log what's happening when it drops power. Look for high knock counts, misfires or anything odd.....
My money is on fuel starvation.....it's nothing new.
Jay
Old 02-02-2009, 03:59 PM   #11
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
When a friend of mine started actually pushing his '06 WRX harder, and with stickier tires, suddenly, he found out that the 1/4 tank that used to be "no problem" would suddenly begin cutting out on him. I've had fuel starve at 1/2 tank in an '06 WRX, when the car was "straight," but I'd just come out of a turn. If the course was as bumpy as you say, it could exacerbate any fuel slosh.
Otherwise, maybe there's a loose wiring connection somewhere? :dunno:
CamaroFS34 is offline   Reply With Quote
Old 02-02-2009, 04:30 PM   #12
mav1c
Hoodbridge!
Member#: 560
It's pretty common to happen coming out of a corner. Both times I saw it at VIR was just as we got onto the main straight, which is right after a long sustained corner.
Old 02-02-2009, 04:42 PM   #13
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
i'll post up some video shortly. You can kinda just hear the motor backing off, no rev limiter pop pop pop or anything and you can kinda see how bumpy it is. i really don't think it's fuel starvation as i have run on these particular tires for 7 events and was pushing the car less than usual (1st event of the season and i'm a bit rusty). Max lat g yesterday was 1.33, whereas i've hit 1.55 max before and sustained 1.21 (295/35/17 hoosier a6's)
Old 02-02-2009, 05:33 PM   #14
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
http://www.youtube.com/watch?v=_saDtTEJUDY . In this one you can hear it cut out at the end of the slalom at the beginning of the run, then after the right after the slalom during the "straight".
http://www.youtube.com/watch?v=ldrMcQN4L5g . This one during that "straight" I shifted to 3rd, and didn't have the power cut out.
Turn the sound all the way up, my camera microphone sucks
And no after the slalom I didn't let off the gas (it kinda sounds like it) I wanted to keep going a bit longer
Old 02-02-2009, 07:15 PM   #15
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Throttle lag from the fly by wire?
PKer is offline   Reply With Quote
Old 02-02-2009, 07:23 PM   #16
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Hmm I don't think so as I was accelerating and then a sudden loss of power. It's almost like i'm overboosting and hitting fuel cut but according to my defi gauge i'm hitting target boost. No cel and flashing cruise or anything like that
Old 02-02-2009, 07:37 PM   #17
Bimmubishi
Member#: 48713
1888 Bellipotent
Wooden
I know what it is with 99% certainty.
If you can log throttle pedal position do it.
If you can't then make sure that the stopper is under the throttle pedal, or if you removed your carpet that you install a new stopper. Your TPS is going "beyond" 100% and cutting as a safety measure.
Bimmubishi is offline   Reply With Quote
Old 02-02-2009, 07:39 PM   #18
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
What tune is on the car????? that might be the issue here...
Old 02-02-2009, 07:46 PM   #19
Bimmubishi
Member#: 48713
1888 Bellipotent
Wooden
Just go out on the street and floor it (really to the floor) in 2nd gear and see what happens. Watch the boost gauge. If it overboosts and hits cut, that's one thing but my guess is that it just hits target and cuts ignition leading to my post #17
Old 02-02-2009, 07:54 PM   #20
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Unfortunately I can't log as I have an accessport v1. Tune on it is from GST Motorsports(been going to Mike for years) Everything runs fine on the street, but it gave out at the autox. After the event I floored (all the way to the floor) it in 2nd on the way home and it pulled all the way to my 7500rpm rev limit. Hit target boost as well according to my Defi gauge. Had in between 1/4-1/2 tank of gas(according to my fuel gauge). Wish it did that at the autox lol. I assume my throttle stop is there as I haven't touched my carpet or anything by the pedal, but i'll go look. Thanks for everyone's help!
Old 02-02-2009, 09:05 PM   #21
Draken
Member#: 16
1968 Saab
Sonett II V4
quick question: Did you change the fuel pump when you made your most recent mods? And if so, did you use the "fuel intake bag" that came with the new pump, or the stock bag?
I changed the fuel pump out on my '04 STi before making some mods and getting a tune. I used the bag that came with the pump. The car would wash out of fuel at anything less than 1/2 tank. the car would literally turn off instantly, and I would have to cycle the key to get it restarted on course. Before the pump change, I could practically run the car empty. I changed back to the stock bag, on the aftermarket pump, and everything was fine again.
Just a thought.
Chris H.
Draken is offline   Reply With Quote
Old 02-02-2009, 10:25 PM   #22
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Thanks for the suggestion Chris, but I did a fuel pump install a while ago and I reused the stock bag for the reason that you mentioned.
btw the throttle stop is still there. The issue doesn't arise on the street, which is making it quite difficult to diagnose. I would chalk it up to a phantom miss or something but it happened on all runs for all three drivers during 2 different run groups.
Old 02-03-2009, 09:13 AM   #23
neilschelly
Member#: 94902
1988 911 Carrera 3.2
I couldn't really tell where it was cutting out in the videos - sorry. But it did appear that you're descriptions were of times coming off of hard right-handers and puching the gas for a straight. That's where my fuel starvation issues hit me, with anything less than 2/3rds of a tank. What tires are you using? If you're only using street tires, then fuel starve is very likely not the cause at least. I know I never had these problems until I started pulling >1.3G right turns.
-N
neilschelly is offline   Reply With Quote
Old 02-03-2009, 09:22 AM   #24
leecea
Member#: 37359
2003 WRX
He's on big tires according to previous post: 295/35/17 hoosier a6's
leecea is offline   Reply With Quote
Old 02-03-2009, 09:26 AM   #25
neilschelly
Member#: 94902
Sorry, missed that. In that case, hitting over 1.3Gs, I'd expect fuel cuts if you've got so little fuel.
-N
Some power cutting out but engine still runs bobko Electrical & Lighting 10 05-22-2009 11:46 AM
High idle with power power cutting out at high rpms subie9022 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-14-2009 12:21 PM
Power assist cuts out at low RPMs ('05 STi) case Brakes, Steering & Suspension 2 02-22-2008 10:49 AM
STi Power Cutting Out on Turns Void Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 03-14-2004 12:31 AM
Power cut out linus011 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 06-09-2003 01:37 AM
