Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-03-2009, 01:01 AM   #1
Nutz
Member#: 115762
'04 Wagon
Default 18g 2.0liter on e85 tuned by Tim Bailey (Surgeline Tuning)
Just got tuned today at surgeline. Couldn't be happier. Here's my dyno plot. Final numbers where 304whp/278wtq @19psi pump. 322whp/301wtq@21 psi E85
Mods:
18g
Big TMiC
810cc injectors
K&N Typhoon
Turbo inlet
Catless turboback (helix DP, Greddy Evo exhaust)
Nutz is offline   Reply With Quote
Old 02-03-2009, 01:26 AM   #2
bignickbugeye
Member#: 168707
2003 boobiez
yup.
nice. looks like you hit full boost a wee bit before me. probly due to your tmic. what brand turbo is it?
bignickbugeye is offline   Reply With Quote
Old 02-03-2009, 01:36 AM   #3
Nutz
Member#: 115762
'04 Wagon
It's a blouch td05 18g 8cm
Old 02-03-2009, 09:57 AM   #4
wrxhard
Member#: 108091
why so conservative with the boost on the e85 tune? Running out of injector?
wrxhard is offline   Reply With Quote
Old 02-03-2009, 02:41 PM   #5
Pink sOck12
Member#: 175988
07 STi
CGM
sweet #'s
Pink sOck12 is offline   Reply With Quote
Old 02-03-2009, 03:11 PM   #6
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
It was at about 90% on the injectors, so it could be pushed a little bit more, but above 90% injector control isn't great, so you end up running it richer to keep things safe. Of course the WRX cams with the greater amount of overlap don't help out as much up top.
Oh, and of course we would like to not have the stock 5 speed transmission turned into bits.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 02-03-2009, 03:25 PM   #7
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Do you guys like tuning on e85 over the midwest's 94 pump?
Rasmusson14 is offline   Reply With Quote
Old 02-03-2009, 04:07 PM   #8
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
Nice! Numbers look almost Identical to mine!! Hows the 8cm hotside for spool? I can't really make out the afr's, he have it close to 12's under boost? Whats it tuned on?
-Jerod
JSarv is offline   Reply With Quote
Old 02-03-2009, 04:54 PM   #9
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Sweet man! I really loved this turbo when I had my 02 bugeye. I made very similar numbers with a similar mod list (310awhp 285awtq @ 20psi).
And Jerod if you're considering this turbo get the 8cm^2 housing. It's going to make more power up top, more torque in general, give you more headroom if you decide to up the boost and cost you like 300rpm in spool. Something to keep in mind; Evo's use a 10cm^2 housing stock with the same 2.0 displacement.
Steve.804 is offline   Reply With Quote
Old 02-03-2009, 05:11 PM   #10
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
-Jerod
E85 is awesome stuff if you can get it.. Much higher octane then 94, if you have the fuel pump and injector to do it.
This was an Accessport tune btw. I'll get a dyno graph with the AFRs plotted on the right axis for you.
Jeff
Old 02-03-2009, 05:18 PM   #11
focusfuri75
Member#: 142011
nice numbers
Tim Bailey FTW
focusfuri75 is offline   Reply With Quote
Old 02-03-2009, 06:47 PM   #12
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
arent the gains usually much more on e85 vs 91?
AWDWRXLOVER is offline   Reply With Quote
Old 02-03-2009, 07:14 PM   #13
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
You certainly could run the 18G harder, make more torque especially with E85, but you have the delima of running the injectors at close to 100%, and if the tank gets a mixture of E85 with a few gallons of 92 (which I would think happens in a street car), you want a little margin.
Most of all, you can get more, but you can also break more. Remember this is an EJ205 (not the strongest rods), and more importantly a 5 speed.
This was E85 compared to Oregon 92, which is much better then Ca91, that is for sure. It is all about the boost my friend.
Jeff
Old 02-03-2009, 10:07 PM   #14
Nutz
Member#: 115762
'04 Wagon
Thanks for fielding all the questions for me Jeff. Sure wish i had the funds to buy your block and get some heads for it. Actually I could swing the block and heads, but install would kill me. And then i'd want a 6speed, etc. etc.
Jsarv I'm at full boost by about 3700 or so
Old 02-03-2009, 10:30 PM   #15
JSarv
Member#: 163445
l33t *******
Nice, I see 18.5psi at 3700 as well... I have a larger compressor housing with the 7cm2 turbine housing.
I can hold 22psi till redline, but I'm out of injectors and maxed my maf out at the same time..
E85 ftw!!
-Jerod
Old 02-03-2009, 11:21 PM   #16
SubyWill
Member#: 166830
2003 WRX
nice numbers!
i'm thinking of getting either a 16g or a 18g, i haven't decided yet
SubyWill is offline   Reply With Quote
Old 02-04-2009, 12:11 AM   #17
Cobb Tuning
Member#: 4803
Jeff Sponaugle
Exactly Jeff.
I could have made more torque with more boost but 300 ft pounds is asking for an older 5 speed to explode on the dyno.
I'll post a data log when i get back to my laptop.
Regards
Tim
Old 02-04-2009, 12:19 AM   #18
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Lucky you, wish I could get Tim to come back east to tune me again.
Nicely done as always
jmlaser is offline   Reply With Quote
Old 02-04-2009, 12:44 AM   #19
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
Th why he hits boost quickly!!!! Blouch FTW!
turb04 is offline   Reply With Quote
Old 02-04-2009, 09:31 AM   #20
Rasmusson14
Member#: 77658
No joke! Are you ever coming back to Indy or Buschur again? I know for a fact that we have a good amount of Toledo guys looking for tunes. I know of at least three just off the top of my head.
Old 02-04-2009, 12:23 PM   #21
JSarv
Member#: 163445
l33t *******
Originally Posted by Surgeline Tuning View Post
Exactly Jeff.
Regards
Tim
I'm at or just above 300 tq and so far so good... But to be honest, I haven't got on it in first gear yet. lol I'm to scared... Just 2nd - 5th..
Looks good Tim!
How bout that log!
-Jerod
Old 02-04-2009, 02:27 PM   #22
sidewayz
Member#: 5810
2001 S366 2.5RS
Hmm.. I hit 335whp and 308tq on 93 @22psi on an 18g. I wonder what I'd be hitting with E85
sidewayz is offline   Reply With Quote
Old 02-04-2009, 07:54 PM   #23
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Nice powerband looks fun...
TDagen is offline   Reply With Quote
Old 02-05-2009, 01:03 AM   #24
Nutz
Member#: 115762
'04 Wagon
On what dyno?
Old 02-05-2009, 10:07 PM   #25
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
Hey NUTZ i looked for u at the battleground meet last weekend but u weren't there !! i wanted to see it soo bad because iv ben talking to tim about that same build , i want a ride in it lol
20wrx05 is offline   Reply With Quote
05 STi ATP3071 Tuned by Tim Bailey socalLGT Proven Power Bragging 38 05-25-2009 09:01 AM
Thanks To Tim Bailey @ Surgeline Tuning momsaysimspecial North West Impreza Club Forum -- NWIC 3 01-05-2008 03:46 AM
2007 STi Limited tuned by Tim Bailey JiveMasterT Proven Power Bragging 18 07-24-2007 03:28 AM
06 STI Tuned by Tim Bailey of PDXTUNING 289hp 329 trq jdmmuscle Proven Power Bragging 11 04-07-2007 01:51 PM
Anyone interested in a group tune by Tim Bailey from PDX? BiggSean Southern California Impreza Club Forum -- SCIC 122 01-08-2007 06:06 PM
