Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 02-03-2009, 09:02 AM   #1
1stockwrx
Member Sales Rating: (7)
Member#: 162365
06 RSX Type S
Default Wtb Left Rear 07 Strut
in need of left rear strut since mine is sagging,giving my car a lousy stance
pm me if you have one,thanks in advance!
1stockwrx is offline   Reply With Quote
Old 02-03-2009, 12:24 PM   #2
wrxSIN
Member Sales Rating: (44)
Member#: 157818
did you do your
kegels today?
are you sure its the strut?
wrxSIN is offline   Reply With Quote
Old 02-03-2009, 12:57 PM   #3
1stockwrx
Member#: 162365
06 RSX Type S
tell you the truth,im not really sure..
they were like that since i had my stock springs on..so im just assuming its the struts.
Old 02-03-2009, 12:59 PM   #4
wrxSIN
Member#: 157818
did you do your
kegels today?
ide get it checked out first before you do all of this. could be something else.
Old 02-03-2009, 01:00 PM   #5
1stockwrx
Member#: 162365
06 RSX Type S
im reaaaaaaaaally reallllllllly in doubt with my suspension alignment specs at the moment..it might be the camber,dont know...
Old 02-03-2009, 01:59 PM   #6
mla163
Member Sales Rating: (9)
Member#: 104922
2013 BRZ
camber is not going to make the car more bouncy. the strut is blown if the spring bounces and keeps bouncing. But I doubt it since your car is new and I assume the struts are too. I'd bet you have the settings on the strut either too high (high frequency bounce, it's bouncing on the strut/top hat) or too low (no damping at all)
what springs are you running and what settings are the shocks at?
mla163 is offline   Reply With Quote
Old 02-03-2009, 02:05 PM   #7
1stockwrx
Member#: 162365
06 RSX Type S
i have tein h techs,bought them new..had them professionaly installed and aligned at a shop
both springs and struts are in good condition,no leaks,excessive rusting or bent IIRC(checked them two weeks ago)
the ride werent bouncy at all
i have stock struts
Old 02-03-2009, 02:10 PM   #8
mla163
Member#: 104922
2013 BRZ
oh i misunderstood. I don't read good.
the strut shouldn't cause any sag - the spring would. what is the measurement at the two rear corners?
Old 02-03-2009, 02:16 PM   #9
1stockwrx
Member#: 162365
06 RSX Type S
im just guessing that left is lower than the right side like half on an inch
Old 02-03-2009, 02:26 PM   #10
mla163
Member#: 104922
2013 BRZ
sounds weird, I'd talk to whoever installed them. And measure the corners to see if it really does sag.
a blown strut would cause the spring to be bouncy, make sure the spring is seated right in the perches
Old 02-03-2009, 02:34 PM   #11
1stockwrx
Member#: 162365
06 RSX Type S
how can i check if theyre installed right?
Old 02-03-2009, 02:51 PM   #12
mla163
Member#: 104922
2013 BRZ
you can jack up the back corner so that you can see better, the bottom end of the spring sits in the perch a certain way. there's a slot where the end of the spring should fit in. if it were rotated a little, it could throw off the height
Old 02-03-2009, 02:55 PM   #13
1stockwrx
Member#: 162365
06 RSX Type S
wow..cool! will check it tonight..thanks a lot sir!
i should be able to "turn" them with my bare hands to make them sit with the said perch,right?
Old 02-03-2009, 03:12 PM   #14
rwdCivic
Member Sales Rating: (50)
Member#: 155986
E92 M3
Jerez
Pm sent
rwdCivic is offline   Reply With Quote
Old 02-03-2009, 03:21 PM   #15
stratguitarist
Member Sales Rating: (11)
Member#: 174960
2006 Lexus IS350
391whp STi sold :(
Your endlinks could be bent as well. I know its a common problem with STi's, I cant see the WRX endlinks being any better. When my rears bent it flipped my sway bar making an uneven stance.
Normal side
Bad side-
stratguitarist is offline   Reply With Quote
Old 02-03-2009, 03:41 PM   #16
mla163
Member#: 104922
2013 BRZ
depends on the drop and you'd have to unhook the swaybar
Old 02-03-2009, 03:44 PM   #17
1stockwrx
Member#: 162365
06 RSX Type S
Normal side
Bad side-
dude,thats exactly how mine are
glad im not the only one
time to sell the subaru!!!
Old 02-03-2009, 03:49 PM   #18
stratguitarist
Member#: 174960
2006 Lexus IS350
391whp STi sold :(
This normally happens if your dropped and go up/down a hill. Mine bent when I was pulling out of my driveway. If they are bent just get some Kartboy endlinks. Easy fix, just obnoxious that it happens, actually the only thing that has ever broke on my STi.
Old 02-03-2009, 05:34 PM   #19
wrxSIN
Member#: 157818
did you do your
kegels today?
bent endlinks are common on STis, but not wrx's. the endlink design is different on both. for example, wrx end links are plastic/rubber and sti endlinks are metal. so they dont bend really, they flex, and i guess they snap as well.
Old 02-04-2009, 08:36 AM   #20
1stockwrx
Member#: 162365
06 RSX Type S
so while changing my exhaust yesterday,i noticed that my left rear is shorter than the right side,
not installed properly?honestly i dont know what to look at/for
Old 02-05-2009, 01:23 PM   #21
Abnormal
Lil Curious
Member Sales Rating: (45)
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Check if the OTHER side is installed correctly... If it's not sitting in the perch right on the other side it would be too high on that side.
Definitely not endlinks, specially if your sway is stock. The stock sway is too thin and the endlinks too flexible to be damaged with your driving style.
Could just be one of those balance things. With coilovers this is something that you can adjust away... with Springs you can add shims under the springs or at the tophats to even it out, but.... Good luck!
PM me what shop installed 'em, or at least what they say, and I'll see what I can do/recommend.
Abnormal is offline   Reply With Quote
Old 02-05-2009, 04:57 PM   #22
rwdCivic
Member#: 155986
E92 M3
Jerez
Van: I still have those 07 struts
WTB Left Rear 04 STi Strut trex616 Private 'Wanted' Classifieds 2 05-01-2009 11:10 PM
WTB Left Rear Strut,Knuckle,Control Arm blackedoutbugeye Private 'Wanted' Classifieds 0 03-30-2009 12:05 PM
WTB Left Rear 04 USDM STi strut BHawk Private 'Wanted' Classifieds 3 08-20-2007 07:44 PM
FS: brand new oem left rear sti strut mount myfastwrx Private 'For Sale' Classifieds 1 03-09-2006 07:48 PM
WTB: Left rear WRX strut top doogdog New England Impreza Club Forum -- NESIC 11 02-16-2005 06:59 PM
