Old 02-03-2009, 12:51 PM   #1
GodWhomIsMike
Member#: 102287
2011 Sportage SX AWD
Signal Red
Question How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI?
How do you install the Footwell Illumination Kit (H201SSC000) into the '09 FXT/WRX/STI? How does it work? Does it sense the car is in Park or the door is open?
Photos:
Instructions from SOA:
http://uploading.com/files/PXM7R0DC/...tions.pdf.html
GodWhomIsMike is offline   Reply With Quote
Old 02-03-2009, 02:13 PM   #2
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
i would imagine it is tied into the door so when you open them they come on
Jncominco2 is offline   Reply With Quote
Old 02-03-2009, 02:15 PM   #3
Phreaker
Member#: 169914
2002 WRB WRX Wagon
Either that or the e-Brake like a in dash DVD player.
Phreaker is offline   Reply With Quote
Old 02-03-2009, 02:34 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
They are on all the time the lights are on.
The driver side bolts injust above the Data Link Connector and on the Forester I believe it double side taped to the foot well under tray on the passenger side. The harness then plugs in line with the mood light in the front console cubby.
Old 02-04-2009, 01:33 PM   #5
GodWhomIsMike
Member#: 102287
Signal Red
I updated the PDF instructions that SOA sent me:
http://www.2shared.com/fadmin/480010...structions.pdf
Old 02-04-2009, 01:34 PM   #6
GodWhomIsMike
Member#: 102287
Signal Red
And uploaded it here as well:
http://uploading.com/files/PXM7R0DC/Impreza Interior Lamp Instructions.pdf.html
Old 02-04-2009, 07:06 PM   #7
NutBucket
Member#: 90804
'11 CR-Z
'05 GGA, '12 Acadia
? Seems like a pretty simple install to me? What's your question regarding the install?
NutBucket is offline   Reply With Quote
Old 02-04-2009, 07:47 PM   #8
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
Would this work in an 08 OBS?
Magic Marker is offline   Reply With Quote
Old 02-04-2009, 09:17 PM   #9
GodWhomIsMike
Member#: 102287
Signal Red
If anyone else knew, but I contacted Subaru, and they sent me the instructions in a pdf file - so I posted them up to share with everyone here.
Old 02-04-2009, 09:18 PM   #10
Snow Drift
Member#: 75071
'11 WRX Ltd Nav 4dr
Lightning Red
My parents 07 Acura MDX has foot well lights in white (to match dials) and they are on when ever lights are on.
Old 02-04-2009, 09:22 PM   #11
NutBucket
Member#: 90804
'11 CR-Z
'05 GGA, '12 Acadia
I've been thinking about doing something like this to the LGT...just low on the priority list
Old 02-04-2009, 09:39 PM   #12
GodWhomIsMike
Member#: 102287
Signal Red
Originally Posted by Philsfan View Post
Today I installed the blue footwell lights in my 09 Forester. I don't have any pictures yet. I installed it myself. If I can do it anybody can. The instructions are not great. The toughest part for me was figuring out that the metal bracket is not used for the passenger side for the Forester. Removing the light from the bracket was tricky but I got it off. I had to bend the bracket to get it out. There is no splicing of wires. The harness that it comes with plugs into the harness for the little cubbie hole light. Running the wire over to the driver's side and then to the passenger's side was not difficult at all. On the driver's side, there is already a hole drilled to mount the light with the supplied hardware. On the passenger side, they give you a template to show where it goes. This is a little tricky. They suggest drilling a hole to run the harness through. I did not do this step. I honestly saw no reason to drill a hole when the harness can be easily tucked around the plastic covering that is beneath the glove box. Besides there were wires back there and I didn't want to risk hitting anything with the drill bit. If you want to drill the hole, I would suggest taking the plastic cover off. It's held on by 3 of those push pin fasteners which are a pain to get off. I tried. I gave up. The passenger side light is mounted with the supplied double sided tape. Because of the location of the lights, it looks to me like the driver side appears to be a little brighter. The driver's side light is more centered in the footwell. The passenger light is off a little to the side. It's not dark yet so I haven't been able to really try it out yet. The part number for the blue light kit is H201SSC000. The red light kit is H201SSC100. The part was $46 from my dealer. By the way they wanted $160 to install it.
After doing this install there's no doubt to me that Subaru could very easily come up with a similar kit for the glove box.
Link: http://www.subaruforester.org/vbulle...44/#post538585
Old 02-04-2009, 09:41 PM   #13
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
I've wanted to do this in the WRX for a while but feared ricer backlash from the Subaru community.....
ScoobyNubieToo! is offline   Reply With Quote
Old 02-04-2009, 09:45 PM   #14
GodWhomIsMike
Member#: 102287
Signal Red
I think this kit works with the 2008/2009 Impreza line and the 2009 Forester line. Check with SOA for compatibility.
The Blue Footwell Lighting is a Subaru part, and the part number is: H201SSC000
They also make Red Footwell Lighting, and that part number is: H201SSC100
Here is the 2009 Subaru Impreza Accessory Guide:
http://www.subaru.net/pdfs/2009wrxaccy.pdf
Old 02-04-2009, 10:25 PM   #15
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
anyone have a pic of what is included in teh kit?
djerickd is offline   Reply With Quote
Old 02-04-2009, 10:47 PM   #16
impre25ive
Member#: 198933
i thought about getting this, but then i realized it only comes on when the ebrake is pulled...
how much time do you honestly spend in a car with the ebrake pulled?
Maybe if it was like mood lighting, which stayed on when you're driving i would buy it.
impre25ive is offline   Reply With Quote
Old 02-04-2009, 11:20 PM   #17
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I'm sure you can wire it up to run all the time..
Old 02-04-2009, 11:46 PM   #18
GodWhomIsMike
Member#: 102287
Signal Red
Are you sure - I think it taps into the line that lights up the cubby
Old 02-05-2009, 01:15 AM   #19
Nacron
Member#: 187115
Chapter/Region: HIIC
2010 Legacy 2.5i
Steel Silver Metalic
It is wired directly off of the light in the cubby so whenever your headlights are on, your footwell will be illuminated. I was thinking about putting the neons I pulled from my totalled focus in there and wiring it up, but this seems like a more elegant solution. $40 ain't bad for the kit.
Nacron is offline   Reply With Quote
Old 02-05-2009, 09:29 AM   #20
Pohenegamook
Member#: 134262
9 조 ☼
Ponik Sinopia
Really? That seems dumb IMO. Light pollution while driving FTL.
I turn down all my interior/cluster light as dim as possible but still readable when driving especially on the highway.
I've got blue footwell CFLs installed, wired to a switched feed from the cig lighter. $12 plus about 45 mins for the install using these:
http://www.allelectronics.com/make-a...NVERTER/1.html
Had to extend one set of the leads but it was cake. The switch is on the center console where the heated seat switches would be.
Pohenegamook is offline   Reply With Quote
Old 02-05-2009, 10:49 AM   #21
exrage
Member#: 77366
2004 WRX Wagon stg.2
Why do people really worry what other people think of how your car looks. i rocked a wing on my mirage for years, took the abuse, but I left it on b/c I liked it. I thought peer pressure stopped making people do/not do things once high school was over...
exrage is offline   Reply With Quote
Old 02-05-2009, 11:10 AM   #22
Micker72
Member#: 132820
2005 Impreza RS
BAG RIDERS
I just bought some random blue leds for my floor and wired them into the dome light so when the door opens they turn on, and when you close it they dim off
Micker72 is offline   Reply With Quote
Old 02-05-2009, 11:24 AM   #23
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
There is a sweet (cheaper) alternative!
Old 02-05-2009, 03:15 PM   #24
dsolis
Member#: 121775
2000 2.5RS
Jizz white
Write up and pics please!! As i plan to do the same in the near future after seeing my ex's 300ZX had that setup stock.
dsolis is offline   Reply With Quote
Old 02-05-2009, 03:17 PM   #25
dsolis
Member#: 121775
2000 2.5RS
Jizz white
This is a bit silly because you need to turn them on by a switch when in reality you would need them to come on as you open and close the doors. I plan to do as above.
How do you install in the left vent RSilverSuby Interior & Exterior Modification 4 08-18-2009 07:15 AM
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 11:32 AM
OT Runners: How do you motivate yourself to run first thing in the morning? doubledribble Off-Topic 39 08-02-2006 03:27 PM
How do you install Dynamat trunk kit? ERaab212 Car Audio, Video & Security 4 09-28-2002 11:50 PM
How do you install a rear strut tower bar in the wagon? Bahumut Technical Forum Archive 2 05-17-2000 02:41 PM
Message Board Statistics All times are GMT -4. The time now is 01:35 PM.
