Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 05-29-2009, 11:40 PM   #101
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
Darth, thanks for the pics. Especially with the passenger side mounting point. I did my kit in ~ 20 mins. Not hard at all. I have small hands so it was fairly easy for me to push the harness through the cubby hole with one hand and reach for it by the steering wheel/ glove compartment with the other hand.
I have the blue kit and it definitely brightens up the floor. With my kit, the glow seems very even throughout. Not distracting and you can't really see it from the outside unless you are looking. It's an easy accessory to hook up. I would recommend it.
Magic Marker is offline   Reply With Quote
Old 06-02-2009, 03:49 PM   #102
Dartholomew
Member#: 208771
2009 WRX
Yeah, it's super-easy if you can reach in behind the steering wheel and glove-box, and you really don't need to get the Subaru kit either, as long as you're happy with the color/intensity of the LEDs and get (or make) a working wiring harness.
It's a fun mod, and if done right it's unobtrusive and not too gaudy
Now I just have to replace the rest of my lights with LEDs!
Dartholomew is offline   Reply With Quote
Old 06-23-2009, 02:27 AM   #103
Tomato_88
Member#: 204277
2008 Impreza 2.5i
Dark Gray Metallic
I just got mine installed. It looks awesome. Only took about 25 min to do.
Tomato_88 is offline   Reply With Quote
Old 06-23-2009, 09:15 PM   #104
misterandre
Member#: 215006
I have a 09 outback sport. Would this lighting kit work? I've found the hub "area" where you are showing. However mine has no light there! Just a silicone/rubber stopper plugging the hole?
misterandre is offline   Reply With Quote
Old 07-02-2009, 01:28 PM   #105
volcomgnu
Member#: 211969
Just did this install last night and it took about 25 minutes. The toughest part was routing the wire through the cubby hole to the passenger side without taking apart the dash. I basically routed it through the far right hole in the cubby, pulled it out, the put it through a straight shot next to the glove box. I was then able to open the glove box and feel the wire and pull it through.
The lights are relatively dim, but I'd imagine with some tint reducing the light pollution, it'd look a bit brighter.
Overall, a fun and quick little upgrade.
volcomgnu is offline   Reply With Quote
Old 07-04-2009, 11:52 AM   #106
patricksmith04
Member#: 116816
2011 WRX
I'm looking @ a WRX with this already installed. I am not a fan of it.
Is it easy to disable? Are they run by a switch? Or when you turn on your lights? Or when the doors open?
Thanks!
patricksmith04 is offline   Reply With Quote
Old 07-05-2009, 01:46 AM   #107
Magic Marker
Member#: 181568
Thanks!
No switch. If you don't like it, pull the cubby light out and just disconnect it. A whole 10 second job.
Old 07-06-2009, 05:47 AM   #108
Nacron
Member#: 187115
Chapter/Region: HIIC
2010 Legacy 2.5i
Steel Silver Metalic
Thanks!
I'll take it off your hands if you can uninstall it
Nacron is offline   Reply With Quote
Old 07-06-2009, 02:55 PM   #109
T WRX rawr
Member#: 215168
2006 WRX stage 2 OS
If you wanted to do this with a 2006 WRX, what would you need besides the LED's themselves? What sort of wiring would be required to have it turn on with your lowbeams? Any way that you could also have an ON/OFF switch for it, say, in the extra console switch spots?
T WRX rawr is offline   Reply With Quote
Old 07-07-2009, 11:51 PM   #110
misterandre
Member#: 215006
Can aynone help with this issue above?
Old 07-08-2009, 04:02 AM   #111
Dartholomew
Member#: 208771
2009 WRX
Just my guess - I don't think the '06 has a cubby hole light, so you'd need to to extend the wiring from each LED to whatever 12v source you want to draw power from (e.g., another light that turns on with the lowbeams). An on-off switch sounds pretty trivial, but again it's a matter of wiring.
Old 07-08-2009, 09:46 AM   #112
Magic Marker
Member#: 181568
The OBS should have the light. I'm thinking when you are thinking light, you are looking for a bulb. The stopper you are describing is probably the condom over the LED that helps disperse the light. Pull out the stopper and you'll see wires connected to it.
If I can install the kit on my 08 OBS, I am 99.99% sure you can do it on an 09 OBS. Good luck, it's really easy.
Old 07-08-2009, 09:30 PM   #113
misterandre
Member#: 215006
Thanks for the help!
Old 07-11-2009, 11:50 AM   #114
BJMscot
Member#: 216810
the UK STI comes with mood lights in the footwell which dim when you close the door. The ceter console light only comes on with the headlights
BJMscot is offline   Reply With Quote
Old 07-13-2009, 11:52 PM   #115
civsix
Member#: 216316
2008 Impreza 2.5i
NBP
just installed today in 2008 2.5i. took about 12 mins
civsix is offline   Reply With Quote
Old 07-14-2009, 12:46 AM   #116
Dartholomew
Member#: 208771
2009 WRX
Nice! The blue glow really works well with the gray interior.
In generally, the black WRX footwell background absorbs the light, and it's only really visible if you have lighter color shoes/pants that reflect it. I think the effect is much nicer in your 2.5i!
Old 07-14-2009, 01:22 AM   #117
Kurikaze
Member#: 174252
2014 BRZ
i got mine installed, it took about 15 min and it was easy in my 08 wrx
Kurikaze is offline   Reply With Quote
Old 07-14-2009, 02:09 PM   #118
Magic Marker
Member#: 181568
Yeah you def get more of a distinct glow. I have the same beige interior, but the black all weather mats suck up a lot of the light.
Old 07-23-2009, 04:36 PM   #119
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
I have the illumination factory in blue. I think I would prefer red...how can I change out the bulbs and where do I get them from.
TEK112 is offline   Reply With Quote
Old 07-23-2009, 06:17 PM   #120
Magic Marker
Member#: 181568
You just can't change the bulbs for the foot portion. You'll have to get the red kit. Someone correct me if I'm wrong.
Old 07-23-2009, 08:27 PM   #121
Nacron
Member#: 187115
2010 Legacy 2.5i
They're not bulbs, they're LED so they can't be just changed out. You need to buy the red kit, and then send me the blue kit
Old 07-24-2009, 01:05 PM   #122
Gombessa
Member#: 218123
2009 WRX
Hi Tek112,
The part number for the red footwell lighting kit is
H201SSC100 and any Subaru dealer should be able to order it for you. You may also want to get the red cubbyhole light from the STi to match the red footwell kit, the part number for that is: 66237SA120.
The replacement is easy since you already have the kit installed (the only slightly tricky part, the wiring harness, is already hooked up). When you get the kit, just look under your footwells for where the light is coming from, remove those parts, and replace them with the ones that come in the kit.
Once you've done that, you should have a complete blue footwell kit sitting around, maybe someone here will want to buy it.
Gombessa is offline   Reply With Quote
Old 07-25-2009, 08:15 AM   #123
winnis
Member#: 216057
Default In-line switch
I just bought an Impreza. It already has the illumination kit installed. Anyone know how I would put an in-line switch, so that I can shut it off when I wish?
winnis is offline   Reply With Quote
Old 07-27-2009, 11:56 AM   #124
trehlo
Member#: 16700
Along the same lines of what winnis was asking, my factory installed 09 sti red led kit illuminates the shifter pocket when the headlights are on, but the footwell lighting is more of a courtesy light that turns on with an open door and then fades after it is closed.
Is there a way to run them all of the time like the pocket light? Does anyone know why the factory installed kit appears to work differently than the one you buy?
trehlo is online now   Reply With Quote
Old 07-27-2009, 02:21 PM   #125
Gombessa
Member#: 218123
2009 WRX
My uninformed guess is that this is a dealer-installed option, and since it's not very common, they simply wired the harness up "wrong." If you can trace the wire from either side of the footwell, you should be able to see where it plugs into, and move it to the cubbyhole connector instead.
How do you install in the left vent RSilverSuby Interior & Exterior Modification 4 08-18-2009 08:15 AM
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 12:32 PM
OT Runners: How do you motivate yourself to run first thing in the morning? doubledribble Off-Topic 39 08-02-2006 04:27 PM
How do you install Dynamat trunk kit? ERaab212 Car Audio, Video & Security 4 09-29-2002 12:50 AM
How do you install a rear strut tower bar in the wagon? Bahumut Technical Forum Archive 2 05-17-2000 03:41 PM
