Old 07-27-2009, 01:45 PM   #126
strife1012
Member#: 136611
2007 spec B
I wish they had a pure white option to make it look similar to the IS 350.
DIY FTW I guess now.
strife1012 is offline   Reply With Quote
Old 07-27-2009, 03:04 PM   #127
Nacron
Member#: 187115
Chapter/Region: HIIC
2010 Legacy 2.5i
Steel Silver Metalic
Originally Posted by trehlo View Post
Along the same lines of what winnis was asking, my factory installed 09 sti red led kit illuminates the shifter pocket when the headlights are on, but the footwell lighting is more of a courtesy light that turns on with an open door and then fades after it is closed.
Is there a way to run them all of the time like the pocket light? Does anyone know why the factory installed kit appears to work differently than the one you buy?
Are you the same guy from IWSTI? Like I said there, look for where the wires are going. Chances are you do not have the subaru kit if it comes on with the courtesty lights because the subaru kit splits the power from the cubby hole light.
Nacron is offline   Reply With Quote
Old 07-27-2009, 03:06 PM   #128
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
Hey guys. I just got my WRX and don't like the blue illumination kit. I really want to change them to red. Does anyone know where I can order just the modules, as all of the wiring is run? Also, if anyone has a red kit and wants to trade I would be open to that, too. Thanks.
TEK112 is offline   Reply With Quote
Old 07-28-2009, 01:09 AM   #129
trehlo
Member#: 16700
Yeah, same guy. No reason why it would be anything but the subaru kit as it came installed new on the car. I can't imagine a dealer would source an aftermarket kit to install when there is an oem one available.
BJMscot mentioned previously in the thread his kit does the same as mine from the factory. I'm in the US though.
trehlo is offline   Reply With Quote
Old 07-28-2009, 05:36 AM   #130
Nacron
Member#: 187115
2010 Legacy 2.5i
They might have gotten it cheaper and added it on and charged you for the subaru kit I know a ford dealer here that puts on wings west kits at 200% markup and sells it as a package. Anything for profit. The best way to find out is to look under the dash and trace where the wires go from the lights. Also, check first if the lights look like the rectangles attached to the yellow/black wires. Those are the subaru accessory LED. Anything else would be aftermarket.
Old 07-28-2009, 01:12 PM   #131
trehlo
Member#: 16700
I crawled under there at lunch and snapped some crappy iphone pics.
The OEM STI kit is different. Not only is it wired differently, but it appears to use 3 of the shifter pocket led's instead of two footwells and one pocket led like you get when you buy it after the fact from subaru.
Here are the pictures.
The OEM LED red casing shown above looks identical, although seemingly longer, to this one shot by Dartholomew
So, now that we have established the factory installed footwell lighting on 09 STI's is wired differently than the kit you buy from the dealer, has anyone ever set the STI footwell led's to run with the headlights?
Old 07-28-2009, 04:03 PM   #132
Nacron
Member#: 187115
2010 Legacy 2.5i
That is strange. The only way would be to cut and wire it to the pocket lights or another source of power when the headlights are on.
Old 07-28-2009, 04:37 PM   #133
trehlo
Member#: 16700
Yeah, I was thinking that same thing, or maybe even just cutting the wires and buying the kit everyone here seems to be installing. My concern though is that the plastic near the led's under the STI dash may be different and the new footwell led's won't have the correct mounting location to install properly.
Old 07-28-2009, 04:39 PM   #134
Nacron
Member#: 187115
2010 Legacy 2.5i
They should be able to accept the accessory kit. Just buy the kit and you can have the OEM lights come on with the doors and the kit come on with the headlights it can be found for $40-60 I'm curious now, wonder if my harness has the plugs for that and I can just buy the LED block from the cubby.
Old 07-28-2009, 07:10 PM   #135
06wrxkiid
Member#: 117112
whatssup everyone just bought some cheap-o led strips over at pepboys (dont judge moneys tight + its only a small project to see how its gunna look... im curious as to how i wire it to make it like the dome light where it would slowly shut off or light up when opening ot locking the door?
i remember reading it somewhere, its located somewhere by the door? if sum1 could show pix or something that be great
btw its an 06 not sure if it matters
06wrxkiid is offline   Reply With Quote
Old 07-28-2009, 09:15 PM   #136
06wrxkiid
Member#: 117112
^ nevermind i went with the mood lighting type of feel and there just on the whole time hooked em up to teh cig lighter n ther awesome only costed me about 25bucks ill post pics soon
Old 07-29-2009, 05:26 AM   #137
Nacron
Member#: 187115
2010 Legacy 2.5i
You don't have to cut the wires, just undo the harness from the LED. I'm searching for the wire in my car, does it come from the harness that goes to the obd port? You could run both as the kit one just double sticks on the backside of the dash cover.
Old 07-29-2009, 11:33 AM   #138
Dartholomew
Member#: 208771
2009 WRX
Weird, I had no idea the STI LEDs were different!
Well, this means if you buy the Subaru kit, you can just install them alongside your existing LED kit, and you can even leave the original harness intact. The new lights will stay on with your shifter pocket light when the headlights are on, and you'll get a little extra brightness on door open/close from the "courtesy lights" of your original kit. Kinda the best of both worlds, and you don't have to change anything.
Dartholomew is offline   Reply With Quote
Old 07-29-2009, 02:58 PM   #139
Nacron
Member#: 187115
2010 Legacy 2.5i
I was curious so I poked around below my dash and found the harness for the LED on the passenger side but it will not turn on the LED under any condion. I had the door open and it wouldn't go on, the headlights on, it wouldn' go on. I'm wondering if they switched the polarity on the harness so that you can't just plug in the LED. I couldn't find the harness on the drivers side. I think it's burried and taped down behind the guages. I was thinking they had just taken out a fuse to disable it but I tried putting fuses in the empty positions and it still doesn't come on.
Also while under there, I found several harness connectors that aren't connected to anything. There's a big connector that looks to go to the ECU but isn't connected. Wonder if that's for keyless entry.
Old 07-29-2009, 03:11 PM   #140
veener79
Member#: 204304
2008 WRX 4D Stage 2
Is there a way to buy the OEM STI kit and would it work in the WRX like it does in the STI?
veener79 is offline   Reply With Quote
Old 08-01-2009, 04:36 PM   #141
trehlo
Member#: 16700
I think that the STI kit is a much more complicated wiring job than the oem kit you buy from Subaru. I'm sure you could buy the parts and install it, the question would be, is it worth the effort just for the courtesy light when the doors are opened. As Nacron pointed out, the STI kit is wired a little funny for some reason.
Old 08-04-2009, 11:29 PM   #142
d_now
Member#: 177424
2002 WRB WRX/STi
'13 WRB STi 5-Door
Default Footwell Illumination
Any ideas if the OEM kit will fit a bugeye?
d_now is offline   Reply With Quote
Old 08-05-2009, 02:07 PM   #143
Gombessa
Member#: 218123
2009 WRX
I think it would be easy to make it fit (just find a spot to attach the modules with the included washers, nuts and bolts, you can drill your own hole if you need), but since you'd probably have to find and tap the harness into the wiring yourself, it's not plug'n'play. If you've done wiring work before, I think it'd be pretty easy though.
Gombessa is offline   Reply With Quote
Old 08-05-2009, 03:24 PM   #144
TEK112
Member#: 218140
Originally Posted by Gombessa View Post
Hi Tek112,
The part number for the red footwell lighting kit is
H201SSC100 and any Subaru dealer should be able to order it for you. You may also want to get the red cubbyhole light from the STi to match the red footwell kit, the part number for that is: 66237SA120.
The replacement is easy since you already have the kit installed (the only slightly tricky part, the wiring harness, is already hooked up). When you get the kit, just look under your footwells for where the light is coming from, remove those parts, and replace them with the ones that come in the kit.
Once you've done that, you should have a complete blue footwell kit sitting around, maybe someone here will want to buy it.
Thank you so much. I forgot about this post and I'm glad someone can get me the info. What is involved with replacing the cubby hole light?
Old 08-05-2009, 03:42 PM   #145
Gombessa
Member#: 218123
2009 WRX
Replacing just the cubbyhole light takes about 30 seconds if not less, no tools needed. Just pop out the light, disconnect it from the harness, connect the new light and pop it back in.
Old 08-06-2009, 03:22 AM   #146
Nacron
Member#: 187115
2010 Legacy 2.5i
If you're getting rid of the yellow cubby light, lemme know
Old 08-06-2009, 08:43 AM   #147
TEK112
Member#: 218140
Sorry, my cubby light is blue.
Old 08-16-2009, 02:28 PM   #148
dsolis
Member#: 121775
2008 STi Hatch
Aspen White | Gold BBS!
Just did my own using door lights from an old Pontiac. Cost? Free... did the wiring myself. Lights dim when i close the doors and shut off when i turn on the car. Installed in both driver and passenger side. Mind the crappy cell pic.
dsolis is offline   Reply With Quote
Old 08-19-2009, 01:14 PM   #149
Mr. TL
Member#: 220464
2009 Impreza 2.5i
Not to beat a dead horse, but I'm hoping this helps a few of you...
I found it MUCH easier to simply remove the glove box to gain access to the passenger side. There was no way i was fitting my hand under to fish that wire through.
Removing the glove box is as simple as removing the support peg (simply pull) and pushing the side tabs of the glove box in so it drops out of place.
Frees up the entire side to find the wires.
Mr. TL is offline   Reply With Quote
Old 08-19-2009, 02:21 PM   #150
TEK112
Member#: 218140
+1
Thanks for the update. I'm sure this will help a lot of people.
How do you install in the left vent RSilverSuby Interior & Exterior Modification 4 08-18-2009 07:15 AM
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 11:32 AM
OT Runners: How do you motivate yourself to run first thing in the morning? doubledribble Off-Topic 39 08-02-2006 03:27 PM
How do you install Dynamat trunk kit? ERaab212 Car Audio, Video & Security 4 09-28-2002 11:50 PM
How do you install a rear strut tower bar in the wagon? Bahumut Technical Forum Archive 2 05-17-2000 02:41 PM
