Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 12-19-2012, 03:12 PM   #6876
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Originally Posted by sackytar View Post
I was gonna say. If you were putting in a 5 speed just sell car.
Yeah, only problem is its hard to find a list of what stuff we are really going to need parts wise. I found a decent deal on what i think are most if not all of the parts needed mechanically but after that im lost.
Shortpersonbk is offline   Reply With Quote
Old 12-19-2012, 03:13 PM   #6877
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Originally Posted by Shortpersonbk View Post
6 speed
Oh ****, didn't expect that! How come you guys don't want to do the swap? Rob did it in a weekend. Invite a couple of us over and we can knock it all out easily.
Do you guys have all the components, or do you need them to source some pieces? Is it going to just be labor on their part?
Travisty is offline   Reply With Quote
Old 12-19-2012, 03:18 PM   #6878
Shortpersonbk
Member#: 319017
15 Prius
I think <<< we will have all the mechanical parts that we will need if i make the trip on saturday to go get them, its the wiring that is confusing. Switching from a auto-5 or 6 speed seems to require alot of guess work and trouble shooting.
Old 12-19-2012, 03:30 PM   #6879
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
What about clutch ?
sackytar is offline   Reply With Quote
Old 12-19-2012, 03:31 PM   #6880
Shortpersonbk
Member#: 319017
15 Prius
What about clutch ?
like pedal? ..i got the guy to include the pedal box and master cyl he is parting out his car
Old 12-19-2012, 04:55 PM   #6881
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
What about clutch ?
He is throwing in the fly wheel and clutch, not sure on the starter?
Mplvan is offline   Reply With Quote
Old 12-19-2012, 04:57 PM   #6882
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
You can use any starter(doesn't have to be from the 6sp)
acmarcus is offline   Reply With Quote
Old 12-19-2012, 05:00 PM   #6883
White out
Member#: 46277
** LP640
Viper GTS
Swap:
6 spd
front half shafts
driveshaft
clutch/flywheel
shifter assembly
dccd controller
ring & pinion for stock rear diff
Am I missing anything else?
White out is offline   Reply With Quote
Old 12-19-2012, 05:15 PM   #6884
Shortpersonbk
Member#: 319017
15 Prius
Originally Posted by White out View Post
Swap:
6 spd
front half shafts
driveshaft
clutch/flywheel
shifter assembly
dccd controller
i will have
6 speed Transmission
Oem 04 sti clutch/flywheel, maybe 10k.
V7 driveshaft
R190 rear diff, this allow you to use stock rear axles
Late model 04 wrx axles.
braided steel clutch line
master cyl+ pedal box
Old 12-19-2012, 05:18 PM   #6885
sackytar
Member#: 149262
PrimerGrey
You have the auto DS already
Old 12-19-2012, 05:21 PM   #6886
Layvon
Member#: 195711
STi 04/05/06/07
Depending on year trans you need axle seals. See my thread for part numbers.
Layvon is offline   Reply With Quote
Old 12-19-2012, 05:45 PM   #6887
Shortpersonbk
Member#: 319017
15 Prius
^ty will do
and @Sackytar the drive shaft is coming with the trans like everything else i listed so i am just going to bring it with me anyways i guess
Old 12-19-2012, 05:56 PM   #6888
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
i will have
V7 driveshaft
R190? Never heard of that one.
Drivetrain swap, or engine and transmission? I'm calling Grant @Subie Guys in about an hour.
Old 12-19-2012, 05:59 PM   #6889
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
R190... Old school legacy gt I think.
Old 12-19-2012, 06:02 PM   #6890
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
That'd be what Rob has in his car, and that's a r160.
Old 12-19-2012, 06:11 PM   #6891
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
Google says its a Nissan dif?
Old 12-19-2012, 06:20 PM   #6892
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
If that's the case, then you're getting an awesome diff. You'll need his rear subframe to it isn't the same as our r160/180's
Old 12-19-2012, 06:21 PM   #6893
sackytar
Member#: 149262
PrimerGrey
LKQ has some older legacys in their u pull lot in wayland.
Old 12-19-2012, 06:23 PM   #6894
sackytar
Member#: 149262
PrimerGrey
Yeah Need 3.9 R160 LKQ has a couple!
Old 12-19-2012, 06:32 PM   #6895
Shortpersonbk
Member#: 319017
15 Prius
So do I beg for the rear subframe to it or do we find the r160?
Old 12-19-2012, 06:38 PM   #6896
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Beg? Nope, tell him it's included because of all the other stuff you're buying. If he balks at that then you can just find a local r160.
Old 12-19-2012, 06:40 PM   #6897
Shortpersonbk
Member#: 319017
15 Prius
I'm paying 375 for a 255 fuel pump sti pinks and a vf39 I feel like I already am raping him lol..I will do it again anyways
Old 12-19-2012, 06:53 PM   #6898
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
If the turbo is in good shape then that's an awesome deal. E85 would have at around 300whp worth that turbo, but those injectors won't be enough for fueling.
Old 12-19-2012, 09:28 PM   #6899
Layvon
Member#: 195711
STi 04/05/06/07
Lol yeah you're raping him.. i sold my vf39 with 160k on it for 365 i think.
This is a question cause I don't know the answer... do the stock injectors respond well to added base pressure? He could bump up the base fuel pressure and get them to flow a little more with that 255. I think that the 255 will provide enough head room with the added pressure to use the pinks.
Old 12-19-2012, 10:01 PM   #6900
sackytar
Member#: 149262
PrimerGrey
Here's my two cent.
VF 39 on a 2 liter block isn't worth it. Car doesn't breath enough. Takes 8 years to spool. And on E85 you'd be lucky to see 280 atw.
We tried with Ewg and 23 lbs.
I had the 39 on for like two months before I ripped that pos off. It took too long to spool for me! On a 2.5 that's a different story.
I wouldn't do a Vf 39 in a 2 liter. Go for at least an 18G!
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? Scooby do Mid West Subaru Owners Club Forum -- MWSOC 19 05-25-2012 02:09 PM
Good alignment shops in the Grand Rapids/Muskegon areas? Paradenu Mid West Subaru Owners Club Forum -- MWSOC 3 12-08-2006 01:20 PM
Anyone close to Grand Rapids going to the Ojibwe ProRally? penjaja Mid West Subaru Owners Club Forum -- MWSOC 4 08-13-2002 01:55 AM
Grand Rapids metroplanner Mid West Subaru Owners Club Forum -- MWSOC 0 06-15-2001 05:00 AM
Grand Rapids MI Autocross Scooby do General Forum Archive 0 09-27-2000 03:26 PM
