Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-31-2013, 11:10 AM   #7501
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Originally Posted by Travisty View Post
Ported stock exhaust manifolds, hi-flow crossover, and a GrimmSpeed 38mm V-band EWG.
Subian: if it was a 18 or 20g I'd look at it, but 16g is a bit too small for me. Good luck with your sale though man.
It doesn't act like a normal 16g with the 8cm housing and the full port work. This used to be a "HTA68" without the billet compressor wheel.
Subian is offline   Reply With Quote
Old 01-31-2013, 11:43 AM   #7502
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Originally Posted by sackytar View Post
On me a price I think the forester is asking for some power?
Rob, you should DEFINITELY buy his turbo, then buy my header setup with up pipe, and lastly a TiAL EWG. Subian and I got you covered on two of your power-hungry needs.
Travisty is offline   Reply With Quote
Old 01-31-2013, 12:00 PM   #7503
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
It would definitely scream with 22+ psi, it's basically an HTA68 without the billet compressor wheel with a slightly bigger hotside.
Old 01-31-2013, 12:20 PM   #7504
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Lol forester on a turbo that makes 20g power
Shortpersonbk is offline   Reply With Quote
Old 01-31-2013, 08:29 PM   #7505
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Gotta make it fly with the lady.
sackytar is offline   Reply With Quote
Old 02-01-2013, 11:59 AM   #7506
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Keep me posted
Old 02-02-2013, 11:27 AM   #7507
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Anyone else out playing in this beautiful stuff?
Old 02-02-2013, 12:10 PM   #7508
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Im down!
nickerz11 is offline   Reply With Quote
Old 02-02-2013, 12:11 PM   #7509
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
My tires suck but im always down haha
Old 02-02-2013, 01:01 PM   #7510
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
I'm on the far northwest side of GR, you cool with that? PM me your number, my buddy and I are going to be heading out in a while and I'll let you know where we can meet up first.
Old 02-02-2013, 01:40 PM   #7511
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Old 02-02-2013, 02:36 PM   #7512
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Well I got the shaft lol my gf got called into work so I have to drive her 30 miles away to go. Up for anything this evening?
Old 02-02-2013, 06:37 PM   #7513
careercadaver
Member#: 242783
2005 LGT Limited
Satin White Pearl
Selling a lot of NIB parts if anyone has interest!! Id prefer to keep as much of this local as possible!! Lmk! I'm out of Kzoo!
http://forums.nasioc.com/forums/show....php?t=2463201
careercadaver is offline   Reply With Quote
Old 02-02-2013, 09:26 PM   #7514
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Old 02-03-2013, 12:01 AM   #7515
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Was that you guys today???
Old 02-03-2013, 09:26 AM   #7516
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Yezzir. It was a bit sticky, and my constant redline attack on the car led to it overheating again, but it was still fun.
Old 02-03-2013, 11:58 AM   #7517
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Wish i could have gone! Looked fun! Does anyone know aside front the 02 sensors what would cause my car to idle like complete crap?
Old 02-03-2013, 12:05 PM   #7518
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Dirty/faulty MAF, bad vacuum hoses (or one that has popped off), leaking couplers (like turbo-to-intercooler, or intercooler-to-throttle body). Is your car tuned? Do you have access to a Tactrix and a Laptop with RomRaider to pull a MAF tab and a Learning View screenshot?
Old 02-03-2013, 12:12 PM   #7519
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Well the maf is new replaced at subaru. Replaced front 02, we used a system at subieskis on hisb laptop and reset everything after adding the front sensor and ran amazing but 30 miles later check engine came back on and idle went back to horrible.
Old 02-03-2013, 12:13 PM   #7520
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
But no I dont have it or a cable myself unfortunately
Old 02-03-2013, 12:15 PM   #7521
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Did you get that code run?
And is your car tuned?
Replacing your MAF and not scaling your system for that MAF seems like a bad idea. Every MAF sensor should read slightly different, and if you don't scale your ECU for each MAF then I would think that your cars fueling would be screwed up.
Either way, get the code pulled and post up what your findings are. No reason chasing other issues if it's just some stupid sensor somewhere.
Old 02-03-2013, 12:21 PM   #7522
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Gotcha. Yeah I dont know if theres a tune on it which kind of had me curious if thats what it was and subieski is gonna pull the map on it and take a look for me
Old 02-03-2013, 01:26 PM   #7523
SUBIESKI
Member#: 203783
2005 LGT
\He's running the stock map, which is not good when you have a new intake. Your a/f learning was maxed at 14.99 across the board lol
I think i am around tomorrow night we could at least pull the codes if you haven't already. the other thought i has was the iac valve may be sticky or leaking. Is it only idle that its rough?
SUBIESKI is offline   Reply With Quote
Old 02-03-2013, 01:43 PM   #7524
nickerz11
Member#: 328073
2005 Subaru Wrx
wr blue
Yeah its just that
Old 02-03-2013, 01:47 PM   #7525
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Yeah, you need to be scaled. Relatively easy to do, especially since I'm assuming you have stock injectors?
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? Scooby do Mid West Subaru Owners Club Forum -- MWSOC 19 05-25-2012 02:09 PM
Good alignment shops in the Grand Rapids/Muskegon areas? Paradenu Mid West Subaru Owners Club Forum -- MWSOC 3 12-08-2006 01:20 PM
Anyone close to Grand Rapids going to the Ojibwe ProRally? penjaja Mid West Subaru Owners Club Forum -- MWSOC 4 08-13-2002 01:55 AM
Grand Rapids metroplanner Mid West Subaru Owners Club Forum -- MWSOC 0 06-15-2001 05:00 AM
Grand Rapids MI Autocross Scooby do General Forum Archive 0 09-27-2000 03:26 PM
