Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 05-03-2013, 01:13 PM   #8701
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
You can try to work something out with SOA and delta. I have seen people luck out that are close to there end date and SOA will pick up cost for labor or parts which is better then the full cost.
Shortpersonbk is offline   Reply With Quote
Old 05-03-2013, 01:26 PM   #8702
Shortpersonbk
Member#: 319017
15 Prius
You guys have any idea on what could be causing me to loose a ton of spool after i change to a smaller intercooler? Last week car was running fine, some stuff happend with a coolentline rubbing on my sti topmount so i had to switch back to the stock wrx one. I lost alot of torque and power overall according to vd and looking at charts comparing logs boost is coming on really really slow but not that much later overall. Or is this just the hot weather and my head messing with me?
Old 05-03-2013, 01:27 PM   #8703
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Originally Posted by vaderphoto View Post
Only thing I've done is replace the catback exhaust and swapped trucks. Nothing had been done to the engine at all.
Try calling my auto imports. Delta sucks donkey dick.
acmarcus is offline   Reply With Quote
Old 05-03-2013, 01:35 PM   #8704
vaderphoto
Member#: 347657
2010 impreza 2.5i
Obsidian black
Well I will wait and see what they say. The car won't make it to Muskegon I'm sure.
vaderphoto is offline   Reply With Quote
Old 05-03-2013, 01:37 PM   #8705
SVT_2_WRX
Member#: 270699
2005 WRX Wagon
Nice alliteration Aron!
Hey anyone swap out their front speakers? I'm trying to figure out which speaker harness I need...not sure what the polarity is and I don't have a multimeter to check it.
SVT_2_WRX is offline   Reply With Quote
Old 05-03-2013, 02:08 PM   #8706
SUBIESKI
Member#: 203783
2005 LGT
Hot weather will do it, are you sure there are no leaks? that would be my first guess. I forgot to tighten the turbo to y pipe connection once and that killed my boost.
SUBIESKI is offline   Reply With Quote
Old 05-03-2013, 02:11 PM   #8707
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Well I wouldn't think there would be anymore pressure drop with a WRX tmic. However it is smaller and is not able to cool down the air as much. So you easily could see a drop in Power going back to a smaller tmic, especially if you were tuned on the STI tmic.
Perhaps there is a boost leak in the wrx tmic (Y-Pipe)?
kayen is offline   Reply With Quote
Old 05-03-2013, 02:46 PM   #8708
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Boost leak. Time to check all your connection.
Old 05-03-2013, 02:52 PM   #8709
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
Does anyone have a 02-07 STi top mount with y-pipe for sale?
Mplvan is offline   Reply With Quote
Old 05-03-2013, 03:33 PM   #8710
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
If they will cover it under warranty, I wouldn't hesitate to pay $100 to have it towed.
Old 05-03-2013, 03:34 PM   #8711
vaderphoto
Member#: 347657
2010 impreza 2.5i
Obsidian black
Once I know what it is for sure ill call them and see. Thanks for the help.
Old 05-03-2013, 04:18 PM   #8712
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
There's a guy in the Fast Subarus of Michigan Facebook page that has a STi TMIC for sale for 180.
Travisty is offline   Reply With Quote
Old 05-03-2013, 04:28 PM   #8713
Shortpersonbk
Member#: 319017
15 Prius
[/url]
the light green is on the sti topmount
the other two are wrx topmount one of the two other ones have more timing added if i remember right
you can defiantly feel the difference
ill have it tested for super leaks
Old 05-03-2013, 06:15 PM   #8714
vaderphoto
Member#: 347657
2010 impreza 2.5i
Obsidian black
So what happen was I had no oil in my engine, never had any indicator light come on for my oil till last night and that was for a spilt second. They said I need a new block. I just had my oil changed about a month ago. Why the hell would I be burning through my oil that fast? It still covered under warranty but because there was no oil they said I needed to call SOA. and just got off the phone with them. I have to prove all my oil changes that been done since I got the car. Which might be a bit hard too do. otherwise I have to pay 900 for a tare down of the engine. to see if they can find what cause it.
Old 05-03-2013, 09:29 PM   #8715
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Ouch that blows donkey balls. Who does oil changes?
sackytar is offline   Reply With Quote
Old 05-03-2013, 10:10 PM   #8716
White out
Member#: 46277
** LP640
Viper GTS
No way should the engine consume that much oil, unless you drive 5-10k miles a month. . . on a rally course.
White out is offline   Reply With Quote
Old 05-04-2013, 11:12 AM   #8717
Layvon
Member#: 195711
STi 04/05/06/07
Or the guy at shop (or the owner ) forgot to tighten something
Layvon is offline   Reply With Quote
Old 05-04-2013, 11:27 AM   #8718
sackytar
Member#: 149262
PrimerGrey
My vote is drain plug is stripped or not tight.
Old 05-04-2013, 02:10 PM   #8719
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
You would notice 5qts of oil on your garage floor if that were the case.
I feel like I have read some where that Subaru said its normal for the motor to burn up to a qt of oil every 1000 miles. So if that's the case and you haven't checked the oil in 5k miles= no oil.
Old 05-04-2013, 02:15 PM   #8720
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Yeah, Subaru states that in the owners manual. But still, if you were that low on oil, how did you not notice a clatter at startup?
Old 05-04-2013, 02:16 PM   #8721
vaderphoto
Member#: 347657
2010 impreza 2.5i
Obsidian black
I never had one until that night also my oil light never came on either. I've been driving around with windows down too no noises out of the normal.
Old 05-04-2013, 02:19 PM   #8722
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Oil light doesn't come on in our cars for low level, just low pressure, and if I remember correctly, it doesn't trigger until it's in the single-digits for pressure.
When that light goes off, it's already too late.
Old 05-04-2013, 02:25 PM   #8723
vaderphoto
Member#: 347657
2010 impreza 2.5i
Obsidian black
Now that's dumb! Well 4-6k for a new block.
Old 05-04-2013, 02:41 PM   #8724
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Hmm that seems high. Think you can get a new STI block for $1800.
Old 05-04-2013, 04:03 PM   #8725
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
Correct, flatiron sells new short blocks for 1800.
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? Scooby do Mid West Subaru Owners Club Forum -- MWSOC 19 05-25-2012 03:09 PM
Good alignment shops in the Grand Rapids/Muskegon areas? Paradenu Mid West Subaru Owners Club Forum -- MWSOC 3 12-08-2006 02:20 PM
Anyone close to Grand Rapids going to the Ojibwe ProRally? penjaja Mid West Subaru Owners Club Forum -- MWSOC 4 08-13-2002 02:55 AM
Grand Rapids metroplanner Mid West Subaru Owners Club Forum -- MWSOC 0 06-15-2001 06:00 AM
Grand Rapids MI Autocross Scooby do General Forum Archive 0 09-27-2000 04:26 PM
