#1 |
Member#: 137902
Vehicle:---- washed away a dream of you |
so here's the deal OT. my car has been going through coolant at a rate of about a gallon a week. i'm quite sure it's not leaking so it think i have a leaky HG. that and my coolant res. has yucky brown gunk in it. would a compression test on the cylinders confirm this, maybe? what about a compression test on the cooling system? do they do that?
i'm willing to attempt this fix myself, i'm a pretty good mechanic so far. oh yeah, this is on my 97 crapalier z24. 2.4L 176K miles..... (insert cav jokes here )ibthisisasubaruforum
#2 |
Member#: 128109
Vehicle:2011 E82 135i Alpine White |
Uninstall the stock coolant gnomes that Chevy installs from the factory. Problem solved.
#3 |
Member#: 8636
BAIC
Vehicle:WRX, OBXT, NA Miata, F250SD, no more SVX :( |
I'm gonna guess that the oil in the coolant, and the missing coolant confirm the leaky head gasket.
Just do the head gaskets. It shouldn't be that hard. It's not like you have to take the motor out of the car on a Cavalier, and there's just one head gasket. |
#4 |
Member#: 4103
Vehicle:2003 WRX Wagon Reddish |
What's your oil look like? Chocolate milk? Yep, you've got a blown headgasket.
#5 |
Member#: 135762
Vehicle:4002 Corrida transparent |
what you need is the quick and easy way to fix, fill and seal that gasket fast, and make it last!
#6 |
Member#: 137902
^^snuggy or shamwow
![]() wait, super putty right ![]() i've tried a couple products. no luck ![]() well, i was afraid of these things...... no sperry, it's a dohc so it's 2 i think? or would it be one where the heads come together? it'll be kind-of a pain cuz i'm gonna need another vehicle for a week while i do it. pretty much have to take the side of the motor off, timing cover, chain, etc.....so i can pull the heads up. still, i'm surprised it made it this long anyway. |
#7 |
Member#: 140413
NWIC
just jbweld the head to the block
#8 | |
Member#: 161038
Vehicle:2002 WRX swapped TS '72 Datsun 240Z |
#9 |
Member#: 137902
haha. i was just thinking with the way the motor looked, but it is one
#10 | |
Member#: 93193
South East
Vehicle:'90 Ishtbox Corolla maroon, as in, I hope not |
Also this on the one head gasket. DOHC doesn't mean two heads necessarily. |
#11 |
Member#: 23114
Vehicle:2005 Cadillac CTS-V Black |
it will compress stuff just fine, you need a leak down test performed.
| Thread Tools | |
| Display Modes | |
| blown turbo, head gasket, or something else? | wrx tekker | Factory 2.0L Turbo Powertrain | 4 | 09-17-2009 06:40 PM |
| Riddle me this - Blown Head Gaskets or Something else | mick_the_ginge | Built Motor Discussion | 107 | 09-22-2008 04:33 AM |
| Leaky head gaskets or not... | DemonScooby | Normally Aspirated Powertrain | 9 | 12-08-2005 12:35 PM |
| Leaky head gaskets or not... | DemonScooby | South West Impreza Club Forum -- SWIC | 8 | 12-07-2005 07:14 PM |
| Leaky head gaskets or not... | DemonScooby | Service & Maintenance | 5 | 12-07-2005 03:50 PM |
