Old 02-05-2009, 11:05 AM   #1
apexslider
Member#: 168101
15 BRZ Limited
SS
Default Recirc on Perrin rotaded kit?
I've got a Perrin rotated kit that will be running a large MAF in the CAI (no blow thru boost tube). With this I need to run my current recirc valve, which means I have to tap into the CAI and weld a bung for the return hose. I'm looking to see if anyone else has done this, and if so are there are any pictures of where you put it. With the Perrin FMIC I imagine space is pretty tight in that area and I'd like to only have it welded once; as in right the first time.
Thanks
apexslider is offline   Reply With Quote
Old 02-05-2009, 11:45 AM   #2
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
wrong forum...but I'll post...I'm actually running a Perrin rotated kit with a cobb big maf intake and I run a atmospheric Tial bov. If your gonna recirculate it, just put the bung in an accessable place downstream of the maf pre turbo...if space is tite, just make it accessable.
Trey
treystoys is offline   Reply With Quote
Old 02-05-2009, 01:58 PM   #3
apexslider
Member#: 168101
15 BRZ Limited
SS
I figured this was the wrong furum, but wasn't sure where to put it... hopefuly the mods will move it to where it belongs. thanks for the feed back though. how is running a atmospheric vent with a maf? do you run into any issues between shifts or coming to a stop? How is part throttle driveability?
WTT: Samco red recirc for Perrin/Samco TB>IC underpowerd Engine/Power/Exhaust 4 02-20-2007 12:51 PM
Perrin Turbo Kits In stock and On sale! Check it out! GNV Motorsports Engine/Power/Exhaust 6 07-17-2006 12:44 PM
Anyone ranning perrin gt35r kit on foz XT ? lazzy8oy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-19-2006 12:02 AM
Intake on Perrin rotated kits machemist Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 04-10-2006 11:08 PM
Anyone having rust problem on Perrin rear swaybar kit? txl146 Brakes, Steering & Suspension 0 04-22-2005 07:08 PM
