Old 04-06-2002, 02:38 PM   #1
chaos_nite
Member#: 10637
Default ej22t
if i plan on swapping an ej22t engine from a legacy turbo into a same year or slightly newer impreza (93-96) do i need to swap the transmission as well?
I've searched for a few days but all i find about this swap is mostly concerning sohc heads and comparisons against ej20! thanks
chaos_nite is offline   Reply With Quote
Old 04-06-2002, 05:53 PM   #2
chaos_nite
Member#: 10637
while i'm on the topic of my planned summer project
could someone refresh my memory as to how high the oem turbo on the legacy can boost and what hp/tq numbers i can hope to achieve? any websites and magazine articles on this topic would be helpful too!
thanks!
Old 04-06-2002, 08:32 PM   #3
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
you don't need to change your transmission, but you will need to change the crossmember support for the motor. The EJ22 runs about 6-8psi, I believe(don't quote me), in stock form. This is good for about 160hp.
mrbell is offline   Reply With Quote
Old 04-07-2002, 01:15 AM   #4
XT6Wagon
Member#: 524
04 STi
You don't have to, and its a pain in the rear to do it....
But I would reccomend it as the non-turbo gearbox is far weaker.
XT6Wagon is offline   Reply With Quote
Old 05-16-2002, 10:47 PM   #5
japporeyser
Member#: 18936
1993 Impreza L Sedan
Colgate White
I have a 1993 impreza L...AUTOMATIC FWD...i want to do the same swap...(ej22t)....can i perform the swap w/o swappin the tranny?...is it possible?? please let me know because I want to swap asap..thanks in advance
japporeyser is offline   Reply With Quote
Old 05-17-2002, 03:24 AM   #6
XT6Wagon
Member#: 524
04 STi
Sure, it will work, but the car will be a mess. FWD + Auto tranny + low compression motor = nasty drive.
You might think on buying a complete drivetrain from japan including the stuff to convert to AWD. I got a complete STi V1 setup w the entire driveline for cheap. The only part you might have to get is a fuel tank if Subaru used different ones in the FWD impreza compared to the AWD version.
Old 05-17-2002, 11:52 AM   #7
japporeyser
Member#: 18936
Colgate White
what do you mean a nasty drive?? it will suck?...its possible though right?? but it wont be a good idea to run it like that for a while because AWD conversion is COSTLY...and will take up alot of work...i have been told its possible and it isnt bad at all...please follow up..thanks
Old 05-18-2002, 01:29 AM   #8
hondahunter
Member#: 18699
93 legacy turbo
black
The EJ22T is good for 160 hp, and 181ft/lbs of torque. The max stock boost is 8.7 psi, regulated by a less than adequate electronic boost soleniod.
Don't be fooled by these low output numbers, the 2.2T has a closed deck block with forged crank and rods. The pistons were cast , but coated. It has been reliable up to 300 whp (I wouldn't push it though)
At 15 psi for eight months, a fellow tech is starting to have problems with the 2nd gear synchronizer (what new ).-even the turbo tranny will need work (if you want to fly).
The AWD conversion isn't that bad, as long as you have the tools, lift, etc. The frame is built to accept AWD, but the gas tank will be a problem. You'll need a split tank, to have clearance for the driveline. The fuel level sending unit on split tanks is different, so keep that in mind. Get the complete rear end if possible, brakes, struts, lateral links, everything. This will considerably help install, so what if you have extra parts?!?!?
Also, try to get a 91 SS rear diff. It was the only year that the viscous LSD was stock. The gear ratio is 3.9:1, you MUST use a 3.9:1 tranny for this to work.
Contact me with questions and
HAPPY HUNTING ALL!!!!!!!
-HH
hondahunter is offline   Reply With Quote
Old 05-18-2002, 02:16 AM   #9
japporeyser
Member#: 18936
Colgate White
Default hondahunter...
so its not a good idea to swap the ej22t to a stock AUTO tranny of a 93 L?...as of for now, i am just trying to run it (ej22t) close to stock..maybe a few mods (exhaust, intake, etc)...and maybe try to work on increaing the boost..(not too much tho)..just for a better performance.....if I am just tryin to swap the ej22t to the stock tranny, the tranny should be able to handle 160 or so hps rite?....the tranny will only give up when I hit what certain amount of hps? but as for RIGHT now...i am not looking into going up to that much hps....hitting 250 hps will satisfy me...I am just looking for a daily/fun driving car....let me know..and thanks in advance
jap
Old 05-18-2002, 06:01 AM   #10
XT6Wagon
Member#: 524
04 STi
It will work, but you'll be wanting a AWD conversion before you turn around twice.
Old 05-18-2002, 11:26 AM   #11
japporeyser
Member#: 18936
Colgate White
well..so i can do it rite??...anyways...i am planning on doing a tranny swap....but my main concern is swapping first...so that's why im asking on swapping engine to a stock tranny...OF COURSE AWD will be better...but its costly...something i cant do right now but WILL look forward in doing at a later time...so what problems might i come across by running the AUTO FWD tranny on the ej22t....(until i save enough money to swap to awd)??? thanks guys
Ej251 Longblock, many many parts. EJ22t, Wiseco Pistons, STI Coils hustleshark206 NWIC Private Classifieds 7 06-14-2010 04:55 PM
EJ22t block and Link G4 Xtreme Standalone PnP Ecu akeric AKIC Private Classifieds 23 06-08-2010 05:21 PM
EJ22T is a piece of poop. EJ22T rundown from supermoose perspective supermoose Subaru Conversions 145 11-08-2005 10:24 PM
EJ22T Internal Pics mhj Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-10-2001 04:11 PM
EJ22T Up-Pipe Compatibility? Shik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-18-2001 06:59 PM
