Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 02-05-2009, 07:44 PM   #1
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Default Cold - Wont start and pump not cycling
It is about -20c outside. I tried to start my car at the end of my work day and let off the key after about 1 second (kinda automatically released the key because I thought the car was started).
Then I noticed it was not started and tried again, but it would rev forever (at pretty good speed) without starting. I then noticed that my fuel pump was not starting when turning the key.
I do believe the ecu should cycle the pump at each and every OFF-ON transition of the key switch because I remember in the past switching the key more than once and I could always hear the pump.
Maybe there is water frozen in the pump?
I never changed the plugs and the car is 105k miles and it is probably more than due. I recently stalled when releasing the clutch too fast in a hill and the car was hard to restart and the engine would bug a lot while trying to rev.
I poured fuel anti freeze just in case it helps. Going back there in a few minutes to try again.
Let me know if you have any idea about the pump not cycling and the motor turning forever without starting (battery is good).
frederik is offline   Reply With Quote
Old 02-06-2009, 07:53 AM   #2
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Pump not cycling this morning either. Did not try to start the car anyway cause its -25c this morning. Going to try again this afternoon when it's "hotter".
You think a frozen line or something could cause the pump to not be able to turn ?
Car Wont Start... Fuel Pump Not Priming... Any Ideas? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-09-2011 03:35 PM
Fuel Pump not coming on... SikSilvrSuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-17-2010 06:27 PM
Clattering on cold start ... and then not? Scrotus Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-28-2009 01:28 PM
Flowrate, Line pressure and Pump duty cycle discussion... Richard L Water/Methanol Injection, Nitrous & Intercooler Cooling 102 08-11-2006 11:02 AM
fuel pump will not prime, car wont start had to get towed! GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 17 03-24-2004 11:07 AM
