Old 02-05-2009, 09:24 PM   #1
Blue2002WRX
Member#: 189988
2002 WRX - Sold
WR Blue
Default Front differential fluid question?
Sorry for this question but I am confused. I had my car serviced at the local Subaru dealership today and asked them to change the oil, transmission fluid, and rear differential fluid. I've had the car for about 5 months and have no idea when the previous owner changed the transmission and rear diff fluids so I thought it was a good idea. On the receipt it says they changed the front and rear differential fluids. By front differential did they mean the transmission? I have no idea and just wanted to ask for verification. Any responses are appreciated, thanks.
Blue2002WRX is offline   Reply With Quote
Old 02-05-2009, 09:43 PM   #2
JawKnee
Member#: 16105
04 WRX Wagon |
05 S2000 | 08 G35S Sedan
4EAT/Automatic?
JawKnee is offline   Reply With Quote
Old 02-05-2009, 09:46 PM   #3
Blue2002WRX
Member#: 189988
2002 WRX - Sold
WR Blue
5-speed. Sorry I forgot to include that
Old 02-05-2009, 09:50 PM   #4
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Front diff fluid change and transmission fluid change are the same thing on the manual. The 4eat has a separate front diff fluid change.
chazly413 is offline   Reply With Quote
Old 02-05-2009, 09:52 PM   #5
wheatpaste
Member#: 170747
2004 WRX Wagon
The front diff, center diff, and transmission all sit in the same box, in the same fluid.
I'm assuming they just changed the transmission fluid and the rear diff fluid. That's pretty much all you can do.
wheatpaste is offline   Reply With Quote
Old 02-05-2009, 09:52 PM   #6
wheatpaste
Member#: 170747
2004 WRX Wagon
Bah. Beat me to it.
Old 03-23-2009, 09:04 PM   #7
Boost2525
Member#: 164168
Sorry to resurrect a dead thread but I couldn't resist when I saw this. I just got into an argument with my local dealership this afternoon about this. (I'm doing my 30k myself but was curious how much money I was saving)
"I assume you're going to want both differentials and the transmission flushed".
"Yes... but the FD and MT share the same fluid... so quote it again without the extra charge for the front diff."
"No. You need both differentials flushed at 30k."
"Understood. The front differential is co-located with the transmission."
(repeat 10x)
Boost2525 is offline   Reply With Quote
Old 03-23-2009, 09:07 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
(repeat 10x)
that dealer is tryin to pack sand up your ass
Old 03-23-2009, 09:16 PM   #9
kx02wr
Member#: 59112
02 wrx
lol yea def don't go back to that stealership do it yourself it's really easy.
kx02wr is offline   Reply With Quote
Old 06-29-2009, 02:20 PM   #10
isler45
Member#: 213721
Hi guys, looking to change the fluids in my 2006 impreza 2.5i (automatic).
Which fluids do I need for the front and rear diff?
And should I change the tranny fluid? Im confused by this, in my service manual it just says to inspect it every 30k, never says replace.
I had the 30k mile service done at the dealership. Don't want to get ripped off again. Thanks
isler45 is offline   Reply With Quote
Old 06-29-2009, 02:26 PM   #11
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Inspect the fluid most likely means check it and replace if necessary.
For the front and rear diffs you just need any normal differential/MT trans oil. I use Valvoline Syn or Mobil 1 75w90 in my rear diff.
Scooby921 is offline   Reply With Quote
Old 02-23-2013, 04:10 PM   #12
Mocheen
Member#: 348045
I'm assuming its all years? i have a 2008 WRX plan on changing it soon
Mocheen is offline   Reply With Quote
Old 02-23-2013, 09:17 PM   #13
point78
Member#: 344329
2008 Wrx, 6mt
Excellent use of the search! Yup, Trans and rear diff. Think 5qts will do it all ( I just got. '08 also, probably been looking up all the same stuff).
point78 is offline   Reply With Quote
Old 02-23-2013, 09:28 PM   #14
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Nothing major has changed in the drivetrain setup in the WRX since it came to the US in '02. Sure they've changed the limited slip, beefed up the tranny, etc., but the basic layout is all the same. Front and center diffs are still in the tranny casing sharing the same fluid, rear diff is separate.
Old 02-24-2013, 08:49 PM   #15
subie bro
Member#: 327229
2005 Wrx
just curious how much did they charge you =0
subie bro is offline   Reply With Quote
4EAT front differential Fluid info Valium Transmission (AT/MT) & Driveline 3 05-19-2009 02:11 PM
Question regarding first differential fluid change Bret_T Service & Maintenance 22 07-25-2007 02:59 PM
Poured ATF Fluid in Front Differential..HELP DH21187 Service & Maintenance 5 09-24-2005 10:28 PM
Poured ATF Fluid in Front Differential..HELP DH21187 Transmission (AT/MT) & Driveline 6 09-24-2005 09:30 PM
changing front differential fluid Jejunum Normally Aspirated Powertrain 0 03-05-2004 11:19 PM
