Old 02-06-2009, 08:00 AM   #1
hano
Member#: 192763
2007 2.5wrx
red
Default Gt4094r pump tune @ 30psi(617whp & 886Nm torque)
Car was tuned @ 30psi with pump fuel on a dynapack dyno, netted (617whp, 804hp on flywheel & 886Nm torque). Made full boost ard 5800rpm(30psi). Power band starts to dip after 7400rpm.Engine was only rev to 7500rpm. Was hoping to extend power band to dip after 7800rpm. Anyone got ideas, advices on tat??? Could'nt contine adding more boost & tuning coz engine coolant was gushing out from the coolant reserve tank during tuning on dyno. Suspect head gasket blown.Car was now up on the hoist, engine out & opened up. Found RHS head gasket blown, engine coolant sipping into cylinder. Luckily all other engine internals are well & intact. Heads was sent to machine shop for resurface. Waiting for them to return from machine shop.
My current mod list : EJ25 block with Darton sleeves, 100mm Arias pistons coated(9.5cr), Pauter conrods, Kelford 282In/276Ex high lift cams(Non Avcs), Kelford heavy duty racing springs & retainers, Mildly port & polish head works, Cometic head gasket with gas rings, ARP 11mm head studs, Jdm 12mm oil pump(shimmed), ACL race main/rod bearings, Moroso oil catch/breather tank, Koyo racing radiator, HKS oil cooler, Stock sti crank, Stock intake manifold, Hondata intake manifold gasket, Custom made throttle body(75mm drive by cable), Custom made turbo intake(4 inch), 2 Sard fuel regulator, 2 high flow fuel filters, 2 Walbro intank fuel pump, 4 Stock sti injectors, 4 PE 800cc injectors, Gates racing timing belt, APS tumbler delete with extra injector holder, APS fuel rails & fuel distribution blocks/lines, APS dr725 FMIC, GT4094r(0.95a/r), HKS wastegate, 3.5 inch custom made downpipe & powervalve, Plasma ignition coil packs, NGK racing spark plugs, MoTec M800 ECU with 5bar map sensor, Innovate air/fuel lamda sensor, Apexi Avcr boost controller, Delfi link, delfi X display,Tomei twin scroll exhaust header, Tein HA suspension & coilovers, ATS tripple plate carbon clutch, Stock 06 jdm sti forester 6spd gearbox(longer gearings), Stock front/rear Brembo brakes, Project MU front/rear brake rotors, Project MU front/rear brake pads. Cussco 8pt undercarridge braces, Cussco front/rear sway bars, Cussco trailing arms/ camber kits, Cussco engine/ gearbox mount.
Future mod list: Over-sized valves, Full-race exhaust manifold, 1.19a/r turbo exhaust housing, 1200cc RC injectors, Jun adjustable cam gear, 50shot of Nitros(maybe), After-market intake manifold(too expensive ), cosworth head(even more expensive).
hano is offline   Reply With Quote
Old 02-06-2009, 08:15 AM   #2
sku81
Member#: 143283
2001 bugeye wrx
white
have a look at your cam timing..
pic's of the engine bay?
Kris
sku81 is offline   Reply With Quote
Old 02-06-2009, 10:12 AM   #3
hano
Member#: 192763
2007 2.5wrx
red
Something asmiss abt cam timing?? Car was dyno at 4th gear.Would doing over-sized valves & changing to a 1.19 a/r ex housing help out in the higher rpm zone?
Maybe my tuner never advance too much ignition timimg due to pump fuel?
Afraid of detonation?
Pics of engine bay coming soon...
Old 02-06-2009, 10:39 AM   #4
4ST-AIR
Member#: 148681
2007 0-60 in $65,000
SOLD!!SOLD!!SOLD!!SOLD!!
30psi on pump WOW. Is that RON98 you use over there?
4ST-AIR is offline   Reply With Quote
Old 02-06-2009, 10:47 AM   #5
fobiawrx
Member#: 91074
04 sti
white
once you get that full race twinscroll manifold or any other real twinscroll manifold you will see that graph shoot to the left by at least 1000 rpms.
fobiawrx is offline   Reply With Quote
Old 02-06-2009, 10:48 AM   #6
BuggeyEYED
Member#: 101691
09 G37x coupe
SOLD - 35r bug/hawkeye
pump with meth? i dont see it listed.. is this possible/safe? well i guess not since you blew a gasket..
BuggeyEYED is offline   Reply With Quote
Old 02-06-2009, 12:19 PM   #7
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
hi hano, i am looking at your dyno charts i can see where your problems are
1) you do not hit 200whp until 4900rpm - this is very late and indicates there is a problem with the design of your exhaust manifold, up pipe and/or turbocharger
2) as soon as you get to full boost (i assume this is at 6200rpm based on your tq curve) the tq starts to drop off FAST. this again indicates you have a problem with your exhaust manifold, up pipe and/or turbocharger
3) changing to the 1.19 a/r will increase your top end a bit, but you will have much more lag
4) i do not recommend changing to larger valves. i recommend using an excellent shape port but with stock size valves and the best valvejob you can find (we use headgames for their radiused valvejobs)
Full-Race Geoff is offline   Reply With Quote
Old 02-06-2009, 12:22 PM   #8
hano
Member#: 192763
2007 2.5wrx
red
Yes, we only have Ron 98 over here. Never use methy injection, althou i had one kit in my garage. Think my exhaust headers is delaying the full-boost.
Old 02-06-2009, 12:37 PM   #9
hano
Member#: 192763
2007 2.5wrx
red
Thanks Geoff for ur advices. Actually, i am quite disappointed in my low-end too. I have been looking at ur exhaust manifold for quite awhile oso. Heard tat its quite costly & take many weeks to manufacture? wonder if its true? No subaru over at my place have yet use ur products, i think? Can let me know the pricing of ur exhaust manifold? Tks!
Old 02-06-2009, 02:16 PM   #10
4ST-AIR
Member#: 148681
He stated PUMP there is nothing that says 30psi pump + METH.
Old 02-06-2009, 03:49 PM   #11
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
doesnt look like itd be very fun to drive.
j255c is offline   Reply With Quote
Old 02-06-2009, 03:55 PM   #12
jays05
Member#: 78165
05 STI 35r + e85
How is 30psi on 98ron fuel with 9.5:1 CR safe????
jays05 is offline   Reply With Quote
Old 02-06-2009, 04:06 PM   #13
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I've always wondered how Buschur does it with pump gas and 600+ whp.
must be 0* of timing.
hello EGT?
phew, it must be hot?
modaddict is offline   Reply With Quote
Old 02-06-2009, 05:42 PM   #14
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Geoff,
Why dont u like using larger valves?? Cosworth run them in there built heads asfaik.
tino is offline   Reply With Quote
Old 02-06-2009, 05:44 PM   #15
tino
Top Scoob 019
Member#: 43630
What size IDA is the tomeii twin scroll headers?? What size IDA is ur upipe??
Old 02-06-2009, 06:36 PM   #16
hano
Member#: 192763
2007 2.5wrx
red
Cr is down to ard 9:1 with use of cometic head gasket. We had quite a numbers of cars doing 26--30psi on the road, over at my area.
Old 02-06-2009, 06:44 PM   #17
hano
Member#: 192763
2007 2.5wrx
red
Never measure the IDA of my tomei twin scroll header before. But its quite restictive if compare to full-race or UR products. Can't get better headers over at my area.
Old 02-06-2009, 07:26 PM   #18
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Did you ever get to drive the car healthy?? That power is rediculous, but was it even fun considering the powerband?
STi Mikey is offline   Reply With Quote
Old 02-09-2009, 02:31 AM   #19
hano
Member#: 192763
2007 2.5wrx
red
Just went to my workshop to measure the IDA of my tomei twin-scroll extractor, only 38mm. Wonder wats the size of Fullrace or UL exhaust header??
Heads back from machine shop. Engine CR now abt 8.8:1
Ordered a set of Jun adjustable cam gear. still waiting for them to arrive.
Old 02-09-2009, 02:48 AM   #20
hano
Member#: 192763
2007 2.5wrx
red
Driving around city isn't much a problem. Just abit laggy if compare with normal stock wrx. I have the 6spd gearbox. Crusing on highway oso beri comfortable, 2200rpm on 6th gear @ 100km/h.
Old 02-09-2009, 03:04 AM   #21
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Maybe I'm a bit biased, having a Tomei header myself, but are you sure? I like Full Race and UR product, but Tomei makes damned good headers.
zeropsi is offline   Reply With Quote
Old 02-09-2009, 04:20 AM   #22
hano
Member#: 192763
2007 2.5wrx
red
Unloaded some pics! Enjoy!
Old 02-09-2009, 04:24 AM   #23
hano
Member#: 192763
2007 2.5wrx
red
More pics !!
Old 02-09-2009, 04:25 AM   #24
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Damn that's laggy!
Pavlo is offline   Reply With Quote
Old 02-09-2009, 04:56 AM   #25
hano
Member#: 192763
2007 2.5wrx
red
Originally Posted by Pavlo View Post
Damn that's laggy!
No, i dont think its too bad! Working on it to try make the spool comes earlier. I seldom drive around city, doesn't need the short burst of power when moving off at traffic lights. Btw, u wouldn't be thinking abt the lag when u rev pass 6K rpm. The tachometer just won't stop til rev limit of 8500rpm. Where got time to mind abt "lag"??
Message Board Statistics All times are GMT -4. The time now is 03:05 AM.
