Old 02-06-2009, 10:00 AM   #1
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
Default My Impreza GT Project - STI Engine Swap, and more ... A LOT OF PICS
Hey GUYS !!
OK, This one , In her first days... was pretty much Standart
few little mods. ( VF29, Apexi AVC-R, Apexi AVCS etc...)
ONE DAY , my gear broke down......
Thats the day i went bananas
Decided to take the building step forward.... !!!
So this is the outcom :
Engine / Internals :
2.0L 16V Quad Cam EJ20 Engine
STi 03 Semi-Close Deck Block.
GT 99 4 Cylinder Heads, Ported and polished
Crower Stage 2 264 Camshafts
Titanium springs and retainers
Light weight Shimless heads.
Stock Head Gasket.
Stock Timing Belt
Silicone Vacuum hoses
Go Fast Bits Pulley
Induction & Cooling
Greddy TD06-20G Rotated Turbo Running 1.7 Bar Boost.
AEM 3" Air Filter
Front Mount ALUMINIUM Intercooler
ZeroSpec Thermostat
Cusco Radiator High Pressure Cap
HKS SSQV Blow Off Valve
AutoBahn Blue Silicone Water/Radiator Cooling Hoses
Fuel System:
4 X 900cc Dutch Werks Injectors
Stock FUEL Rails & Regulator
Bosch 023 In-Tank Fuel Pump
98 Octane + Toluene
Engine Management:
Haltech E11v2 – Launch Control , Anti Lag, Map switch, Data Logging,
Exhaust:
HKS 3" Ti-Limited Exhaust system
GT Spec Exhaust Manifold.
GT Spec Uppipe
Greddy 44mm Type R External Wastegate
Apexi ECV Exhaust Cut-off Valve Silencer !
Drivetrain:
STi VER.5 Gearbox set
Clutch Masters STAGE 4 Clutch
ACT PRO STREET Light Weight Flywheel.
Brakes , Suspension , Wheels & Tires:
Prodrive / Alcon 330mm BIG BRAKE KIT.
StopTech Front & Rear Brake Stainless steel Brake Lines.
TEIN Super Street with EDFC Electronic stiff contorll.
BFGoodRich G-Force T/A KDW2 205/45/17
O.Z Superleggera 17" Silver
Electronics & Interior:
Greddy Profec-B Spec-II Boost Controller.
Greddy FULL AUTO Turbo Timer
Electronic digital INLET Temp gauge.
STRI DSD EGT 52Mm gauge White face GREEN light .
STRI DSD Boost 52Mm gauge White face GREEN light.
STRI DSD Oil Pressure 52Mm gauge White face GREEN light.
AEM WideBand
GSM 2-Way Car Alarm
Panasonic 9803 Head Unit
Hertz 6.5" Component System
Cerwin-Vega VEGA 124 SubWoofer
Hifonics ZEUS 6400 Amplifier
OK !!!!
Pics of the first days :
Broken second gear
turbine13 is offline   Reply With Quote
Old 02-06-2009, 11:58 AM   #2
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
Old Engine OUT
Old 02-06-2009, 02:42 PM   #3
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
OK,
FIRST THING, FIRST !! HEADS !!
GOOD ENGINE, IS BASED ON GOOD HEADS !!!
Porting and Camshafts is needed !!
So...
stripped the GT heads,
This is how they look like before the PORTING work,
INTAKE :
EXHAUST:
After cleanning:
AFTER PORTING - INTAKE :
AFTER PORTING - EXHAUST
CROWER - STAGE 2 CAMSHAFTS !!!! YEAH !!!!
OF COURSE, TITANIUM RETAINERS !!!
SPRINGS !!!
Old 02-06-2009, 02:57 PM   #4
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
So...
lets keep them coming !!
Next thing,
STI 2.0 EJ20 03 Semi-Closed Deck Block with ARP studs !
So now we have GOOD heads, GOOD block,
Time for good Exhaust
First, GT SPEC 4 To 1 Unequal Length ( Keeps The Subaru Noise !!! )
We did some EXHAUST porting remember ?
NEED TO MAKE SOME JOB ON THE HEADERS AS WELL ...
Now... some wrapping...
Old 02-06-2009, 03:00 PM   #5
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
OK, The New UPPIPE !!!! yeah !!!
COMPARED to the STOCK:
HKS 3" CatBack Exhaust System with Ti-Limited Muffler:
HMM.... PROBABLLY will be kinda noisy :wonder: ???
NO PROBLEM GUYS !!!
APEXI ECV - Mechanical Exhaust Silencer !!!
Well..
How is it so far ???
Keep them coming ?
Old 02-06-2009, 03:21 PM   #6
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Looks good are you planning to get rid of the 20G or turn up the boost?
What do you use the car for? Daily Driving, auto-x, track days?
Looks good, keep us updated on your results.
rexworx is offline   Reply With Quote
Old 02-06-2009, 03:26 PM   #7
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
This is my DAILY / TRACK ( RACING ? ) car ...
The GREDDY TD06-20G works great i can tell you,
1.7 BAR is the MAXIMUM effective boost for this TURBO,
Later on i will post some videos of some racing action VS scooby with HKS GT3240,
You will be surprised HAHA
Old 02-07-2009, 01:07 PM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
dude i give you props!!
id be scared to run any modded car in israel..everything is sooooo expensive!
mxpunk is offline   Reply With Quote
Old 02-07-2009, 02:32 PM   #9
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
and illegal - any modifications to the motor or exhaust are illegal...
dude, how are you getting this thing past inspection?
gto7419 is offline   Reply With Quote
Old 02-07-2009, 09:02 PM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
You really need to fix up that wrapping
alcoolaid is offline   Reply With Quote
Old 02-07-2009, 09:54 PM   #11
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
looks like it needs another coat, of a much tighter close wrap
seanathanq83 is offline   Reply With Quote
Old 02-08-2009, 01:53 AM   #12
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
Yes... Israel is a BAD place for modded cars,
But nothing can't beat the LOVE and the NEED for speed
About the coating,
I tried to coat it tight and close but then, i sufferd high temp EGT.
So, this way its much better for me ...
Basiclly, this coating is only for heat protection to the headers arround
Some more photos, let me hear your opinions about the build...
Little bit color for the Intake manifold:
Before:
Fueling Issue:
Had the Walbro 250LPH, little bit gentle for high specs for my opinion,
Moved to the Bosch 023 In-Tank Fuel Pump :
Need to have some modification for the fuel tank holder first,
Old 02-08-2009, 02:27 AM   #13
jamal
Member#: 71875
98 Legacy GT
my wheels fit
very nice looking setup. We've had really good results with the gt-spec headers, and it's nice to see you doing all that headwork. We get so many people who come it and want to do rods and headbolts etc along with their pistons but don't want to touch the heads.
jamal is offline   Reply With Quote
Old 02-08-2009, 02:31 AM   #14
EGY5
Member#: 165206
2006 WRB DPSti
w/ white shoes
awesome set up. more pics!
EGY5 is offline   Reply With Quote
Old 02-08-2009, 09:30 AM   #15
gto7419
Member#: 44256
05 outback xt
I would also fix the wrap on the headers. If you arent going to wrap the entire header, I would probably take it all off...
The high egt is due to the tuning - you should really be tuning the car for the proper egts. You also have very hot intake air temps...
How are you tuning the car?
Old 02-08-2009, 09:57 AM   #16
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
Whats the point of taking the wraping off ?
im trying to keep the headers aorund cooler with this wrapping,
My intake temp on a 23 degree day, on 4th gear at 1.7 BAR is 35 Degrees.
I dont think the high EGT is due tuning issues .
The tuning of my car is with Haltech E11v2 .
With fuel map and ignition for the daily drive with 1.3 Bar with 98 OCTANE.
and little bit more agressive maps with 98 OCTANE + Toluene at 1.7 BAR.
Old 02-08-2009, 10:12 AM   #17
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
uee.... those heads are nice.... muhahahaha BIG PORTs!!!
FuJi K is offline   Reply With Quote
Old 02-08-2009, 10:30 AM   #18
rexspeedmaster
Member#: 123103
2003 WRX
Full 07 STI trans
wrapping the headers like that is going to create alot of temperature variation across the headers which will lead to cracks and other failures. I would wrap them fully or not at all. But its yours so you are allowed to do whatever you want
Great build. MAkes me jealous.
rexspeedmaster is offline   Reply With Quote
Old 02-08-2009, 10:39 AM   #19
fulie
Member#: 142345
2002 WRX 34'd
sweet build, if its his track car maybe he doesnt need to pass inspection?
fulie is offline   Reply With Quote
Old 02-08-2009, 10:46 AM   #20
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
Like gto7419 said, any issue about car racing / mods about cars in Israel is ILLEGAL !
So, we dont have tracks around here ..
only street "track"
And like i said, its my " DAILY " car !!! ( dailey street racing? hmm...)
About inspection, its once a year, so..... i get along when the time is come
Old 02-08-2009, 12:38 PM   #21
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
that boshe intnk looks sweet! Cant wait for turbo pics.
scby rex is offline   Reply With Quote
Old 02-08-2009, 10:24 PM   #22
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
How far are you from Nahariyya? I saw tons of scoobs there when i was visiting, but they were all FWD.
Old 02-08-2009, 10:46 PM   #23
richy_21
Member#: 58670
2005 got muuuuu?
Nice thread! So far so good!!
richy_21 is offline   Reply With Quote
Old 02-09-2009, 02:16 AM   #24
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
Actually, Naharia is very far from where i am,
BUT, all Israel full with Subaru's
But very few are turbocharged and built for POWER
OK !!!
Time for Brakes , Suspension , Wheels , Tires & Drivetrain:
Remember the broken gear ?
So i decided to go with STI ver.5 RA type gearset,
If this will broke as well,
I will go with STI 03 6SPD Gearset ( KILLING GEARBOX !!! )
STOCK susspension is CRAP !
Making my car bounce and move back and forward when i change gears at full throtle
( better not mention the cornering issues ... )
So... Moved to Tein SuperStreet !!! HAHA !
This is how the STOCK susspensio and brake caliper look like:
Old 02-09-2009, 02:45 AM   #25
turbine13
Member#: 154755
1999 Impreza GT
Rally Blue
WITH THE EDFC : ( Electronic Damping Force Controller )
the motors:
So probablly will have nice power, and probablly will control it by the TEIN and tires ( tire pics soon...)
now the car needs to be able to STOP !!!!
So ... Stock Brakes:
Upgraded to Prodrive 330mm BIG BRAKE KIT:
PRODRIVE BRAKES WITH O.Z Superleggera Wheels !! ( need to fit for the BIG brakes )
StopTech Stainless steel brake lines of course !!
06 WRX and Bugeye WRX LOts of Pics scobby06wrx Member's Car Gallery 23 09-26-2007 05:51 PM
FS: 1994 Impreza L AWD 2.5RS Swap and more... Richmond 83Rabbit MAIC Private Classifieds 20 12-28-2006 11:40 PM
FS: Jordan VII's and V's sz11 lots of pics grndc2gsr SCIC Private Classifieds 8 11-30-2006 04:24 AM
FS: Jordan VII's and V's sz11 lots of pics grndc2gsr Non-Subaru Stuff 0 11-27-2006 01:22 PM
new pics after engine swap and more QfactorRS Member's Car Gallery 25 07-29-2003 01:44 PM
