Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 04-06-2002, 06:01 PM   #1
mid9s
Member#: 7777
2002 impreza WRX
Blaze Yellow
Default how hard is it to put in plugs?
I have not ever looked at it yet? How much time does it take to change out the plugs. Also what kind of change does it make.
mid9s is offline   Reply With Quote
Old 04-06-2002, 07:08 PM   #2
Baluchitherium4
Member#: 6480
00' WS6
Red
Plugs are fairly simple to change, not as easy as an inline engine, but still easy. If you have a simple socket set, you can change them. The only issue is clearance. Be warned though, wear some kind of gloves or prepare for bloody knuckles.
Later,
Dale
Baluchitherium4 is offline   Reply With Quote
Old 04-06-2002, 07:41 PM   #3
Tuning Factory Inc.
Vendor
Member#: 3600
Not too bad. You'll only have to remove the washer fluid resovoir and maybe the intake box if you still have yours (I don't). Trickiest one is the rear driver's side one.
Tuning Factory Inc. is offline   Reply With Quote
Old 04-06-2002, 08:11 PM   #4
phooka
Member#: 8486
2002 Impreza WRX
It helps to have a very short extension (1") to do the pass side.. Yep.. they do make them that short. Other than that, it's a pretty easy thing. Just have to be alittle bit of a contortionist if you are completely inept with your left hand as I am..
dale
phooka is offline   Reply With Quote
Old 04-06-2002, 09:33 PM   #5
scooby
Member#: 13085
i find it easy to put the socket in the sparkplug hole the three inch extension the the socket wrench. Do the reverse once you crack them loose just take the wrench off and spin the spark plug by hand with the extension.
scooby is offline   Reply With Quote
Old 04-07-2002, 01:52 AM   #6
reXer
Member#: 13312
A long long extension with a universal socket is the way to go.
reXer is offline   Reply With Quote
Old 04-07-2002, 10:30 AM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
pulling the plugs out is made easier with a spark plug socket - they have a rubber insert on them so they grip the end of the plug and pull it out for you.
nhluhr is offline   Reply With Quote
Old 04-07-2002, 01:41 PM   #8
phooka
Member#: 8486
2002 Impreza WRX
Yep.. except they get stuck way up there in the head when you are installing the plugs. It helps to have one with an insert, and one without an insert. The one without you use to install the plugs, the one with, you use to remove the plugs.
dale
Old 04-07-2002, 04:33 PM   #9
Egan
Member#: 12670
01 M Coupe,
05 Legacy GT, 05 Titan
What size is the socket for the WRX plugs?
Egan is offline   Reply With Quote
Old 04-07-2002, 07:03 PM   #10
Fubaru
Member#: 6046
'08 Prius
5/8" (IIRC)
Fubaru is offline   Reply With Quote
Old 04-08-2002, 12:10 AM   #11
z0s0
Member#: 7146
2015 Forester XT
dale
I use a spark plug socket with the insert, but use an extension that locks to the socket. It has a little tab that has to be moved to release the socket. Works great.
z0s0 is offline   Reply With Quote
Old 04-08-2002, 12:18 AM   #12
Fubaru
Member#: 6046
'08 Prius
Relocating the battery to the trunk and a fender CAI would make inspecting/changing plugs so much easier. Not that you would do it just for the sake of the plugs
If I weren't pretty much done messing with my WRX (i.e. spending $$$)...
Old 04-08-2002, 11:12 AM   #13
scooby
Member#: 13085
just use a 16mm deep socket to put the spark plug back in that is how its done at subaru.
How hard is it to put pictures on a CD? (rant) Jake1050 Off-Topic 11 12-18-2007 04:06 PM
How hard is it to live in another country for an extended period of time? Absolut Off-Topic 38 11-16-2005 05:56 PM
How hard is it to put a resume together... TheNookie Off-Topic 10 08-18-2005 07:56 PM
I mean, really, how hard is it to write in complete sentences? DrDRum Off-Topic 13 11-11-2004 01:00 PM
How hard is it to screw up a plug install? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-29-2004 06:08 AM
