Old 02-06-2009, 10:01 PM   #1
jv01
Member#: 65597
04 sti
Default cold weather tire selection
cold weather aotoxers do you run r comp tires all season long or do you run street tires untill 70* . if not what is the best cold weather street tire. jv ooops delete
jv01 is offline   Reply With Quote
Old 02-07-2009, 10:19 AM   #2
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Tires will heat up unless it is really cold outside. I live in ND, where temps can be cold even in the summer. My V710s heated up fine, but at the expense of some chunking of tread on the shoulders. So it can get pretty expensive if you have to replace expen$ive tires fairly frequently. The old Azenis 615s were pretty good, even in the cold. My street tires now are Dunlop Star Specs and they are really pretty good down to 40* or so (street driving, mind you).
How cold are you talking?? A few years ago I did a little comparo in cold weather with my G-Tech and a set of Nokian NRW and a set of RE 070s (stock tires, but this was a replacement set). It was just under 40* and windy. The Nokians, despite their soft sidewalls and "vague" turn in had far more geip, both sustained and transitional. Once I got some heat on the RE070s, they came aropund and out performed the Nokes.
I guess you have to look at your temps and how long your course will be, as well as your cue times between runs and make a decision....
70* is really quite warm. I would not hesitate to run r-comps down into the 50s.
bcblues is offline   Reply With Quote
Old 02-07-2009, 10:54 AM   #3
jv01
Member#: 65597
04 sti
well bc ive gone to events and the dash said 26* and 40-50s threw the day . one pro driver i talked to said street tires are close to r comps up to 70 and after 90 they actualy grip to much for awd cars.
Old 02-07-2009, 02:42 PM   #4
leecea
Member#: 37359
2003 WRX
Originally Posted by jv01 View Post
...after 90 they actualy grip to much for awd cars.
Too much grip
leecea is offline   Reply With Quote
Old 02-07-2009, 11:03 PM   #5
jv01
Member#: 65597
04 sti
Originally Posted by leecea View Post
Too much grip
well someone well respected said over 90 deg rear wheel drive cars have a advantage over awd with r tires harder to rotate the car . i already have my new wheels and r comps, just wondering if there is a advantage to using a sticky street tire in the early part of the season. end of last season someone on starspec tires got ftd and there were some very well preped cars on r tires . jv
Cold weather autocross - Tire pressure up or down? waktasz Autocross 12 10-27-2009 09:37 AM
Hot weather vs Warm Weather vs Cold Weather - RPM issue. SausageCat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-01-2009 08:51 PM
Summer Tires and cold weather whats the big deal anyway? Dtdunk Tire & Wheel 10 10-11-2003 05:15 PM
Cold Weather AutoX: R-comp vs Street tire Gonz Motorsports 4 10-04-2003 10:09 AM
Perf Tires and Cold Weather kpratte Brakes, Steering & Suspension 1 06-29-2001 09:41 AM
