Old 02-07-2009, 02:47 PM   #1
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
Subaru Banner 03 wrx 18g+meth @ 26psi on feb.14
i am getting my car tuned next sat. by awdtuning and i am.
i have been waiting to put my meth in.
i will post #'s up next week after i get back.
my set-up is
my setup is
mhi 18g with a 14.7psi actuator
aps tmic
aps 65mm cai
aps tgv's deletes
aps turbo inlet
aps 50\50 bov
gt-spec headers wrapped
gt-spec up-pipe[no cat] wrapped
xs-power tbe down pipe wrapped[no cats]
gm bcs
modded wrx injectors flow tested 876cc
255lph walbro
vision fpr
nrg grounding kit
phenolic spacers grimmspeed 8mm
pully crank & alt.
turbo blanket
and all the heat sheilds.
smc methanol kit doing a 50\50 mix
ngk one step colder
suspension
perrin front end links
perrin 25 mm front sway bar
perrin rear end links
perrin 25 mm rear sway bar
whiteline sturt tower bar
axxiss f\r brake pads
215\55r16 tires
tranny is a 4eat still stock i plan do get a valve body & trans cooler soon!!!
jeremywrx15554 is offline   Reply With Quote
Old 02-07-2009, 02:48 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
just curious but why start a thread a week before?
godforbid67 is offline   Reply With Quote
Old 02-07-2009, 02:51 PM   #3
Jett_WRX
Member#: 136483
2007 WRX VF-39'd
05' 600RR 08' Ducati 1098
plan to
not plan do*
jus fyi
Jett_WRX is offline   Reply With Quote
Old 02-07-2009, 02:51 PM   #4
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
i do not know i guess i am just happy.
Old 02-07-2009, 02:55 PM   #5
lev98
Member#: 140529
01 Ferrari 360 spy
You are going to have it tuned to 26psi. That seems high on a stock block.
lev98 is offline   Reply With Quote
Old 02-07-2009, 02:59 PM   #6
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
i plan on 24 to 27 psi on meth.
there are people running 20 to 22 without meth on there cars no promblems
Old 02-07-2009, 03:20 PM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
what are you doing for a MAP sensor?
sidewayz is offline   Reply With Quote
Old 02-07-2009, 03:28 PM   #8
DansSpace
Member#: 157029
'13 Mazdaspeed3
Definitely interested in numbers. I've got an 02 with a 4eat and I'm looking for something around the EVOIII 16g or maybe an 18g, but I'm going to get a torque converter and tranny cooler before I do those forsure.
DansSpace is offline   Reply With Quote
Old 02-07-2009, 03:42 PM   #9
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
my set-up is
my setup is
aps tmic
aps 65mm cai
aps tgv's deletes
aps turbo inlet
aps 50\50 bov
gm bcs
255lph walbro
vision fpr
nrg grounding kit
pully crank & alt.
turbo blanket
ngk one step colder
suspension
215\55r16 tires
Sounds like a good setup. You have to take into consideration some cars take to higher timing and less boost. There is a good chance you'll be able to run your 26psi, but if the car is responding more to timing, turn the boost down, you'll make better, safer power. All depends on what your car likes. What your car wont like is your trans screaming for mercy.
good luck and have fun. Hopefully the trans will hold up, its in the ballpark of 4500 for a built 4eat, and then the 1/4 times drop drasticly!!
STi Mikey is offline   Reply With Quote
Old 02-07-2009, 03:45 PM   #10
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
yeah i will let my tuner decide for sure what i will be running on boost.
that was a ball park on the boost.
i hope to have the trans done in the next 2 months.
i do not really car about 1\4 mile times as long as it is fun for me.
thanks jeremy
Old 02-07-2009, 07:05 PM   #11
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
If you have any mileage on your car at all (75K+) you'll probably start getting blow-bye anything over 24psi.
May or may not, but I'd keep my hopes to 24psi and a bit more timing (longevity wise)
Sounds like a good setup thought!
-Jerod
JSarv is offline   Reply With Quote
Old 02-08-2009, 10:32 AM   #12
BoostUnderPressure03
Member#: 117724
2003 WRX
Subscribed! Very interested to see what your results are! Good luck
BoostUnderPressure03 is offline   Reply With Quote
Old 02-24-2009, 08:43 PM   #13
lmpreza WRX
Member#: 178711
2016 WRX
Red
so, any news about the tune? i'm curious.
lmpreza WRX is offline   Reply With Quote
Old 02-24-2009, 09:22 PM   #14
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
Talking
yes i made 340awhp,300awtq @ 25psi
here is the thread
http://forums.nasioc.com/forums/show....php?t=1700001
