Old 02-07-2009, 01:53 PM   #1
Cobb Tuning
Member#: 4803
Default COBB AccessTUNER Pro Supports Speed Density Tuning!
01/16/12 - Speed Density support has been implemented in AccessTUNER Pro and AccessPORT firmware for 2.5L turbocharged Subaru's. New thread created here - http://forums.nasioc.com/forums/show...7#post36136777
Portland International Auto Show
Portland, OR
February 7, 2009
COBB Tuning is proud to announce the availability of AccessTUNER Pro “Speed Density” support for all Subaru drive-by-wire vehicles equipped with a COBB v2 AccessPORT. The new “Speed Density” implementation instructs the ECU to calculate load by using temperature and manifold absolute pressure (MAP) as opposed to the OEM code that utilizes mass air flow (MAF). This development addresses the growing demand within the Subaru enthusiast community for motorsports grade engine management without sacrificing the drive-ability and sophistication inherent in the OEM ECU.
The most basic function of an engine control unit (ECU) is to measure airflow and its translation to engine load. Precise and consistent load calculations along with feedback from other critical sensors allow the ECU to accurately control ignition timing, variable camshafts, and fuel delivery. The most common way to measure load in modern vehicles is with a mass air flow sensor (MAF). Vehicles with stock engines and mild upgrades can utilize the MAF sensor with excellent overall results. However, in a motor sports application where power levels are extremely high and intake airflow configurations are less standardized, the use of a MAF sensor can be highly limiting.
The enhanced AccessTUNER Pro software now offers multiple ECU control modes to give the professional tuner and AccessPORT user a wider choice of engine modifications and tuning options. The software can program the ECU to run in the traditional pure MAF mode, a pure “Speed Density” mode, or a hybrid of both MAF and “Speed Density” with multiple configurable parameters to control dynamic mode switching.
Surgeline Tuning (www.surgelinetuning.com), a premier COBB tuning and installation facility, has performed rigorous testing of the software and has validated “Speed Density” and hybrid modes on MAP sensor equipped Subaru test vehicles with impressive results. This means that high horsepower projects that would typically require the use of expensive and comparatively unreliable stand-alone ECU's can now benefit from the reliability and consistency of the stock ECU partnered with the increasingly capable Cobb AccessPORT and COBB’s network of experienced professional tuners.
The COBB AccessPORT is the ultimate hand-held ECU reprogramming, managing and monitoring device available and COBB Tuning’s ongoing delivery of innovative features and functionality continues to widen the gap to the competition. No other solution even comes close! Access the Potential!
For information on acquiring the AccessTUNER Pro “Speed Density” software module, please email us at [email protected].
Old 02-07-2009, 09:23 PM   #2
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Glad to see this is finally out. Any plans on posting more info in the Cobb Protuner forum?
robbieshonda is offline   Reply With Quote
Old 02-07-2009, 11:14 PM   #3
Cobb Tuning
Member#: 4803
Look for a complete technical description along with an example dyno tune in Proven Power Bragging section in the near future.
Best regards
Tim
Old 02-08-2009, 12:40 AM   #4
atomicfire
Member#: 136296
2005 STi
Any idea when MAP based staged maps will be available? Or support for ATR?
atomicfire is offline   Reply With Quote
Old 02-08-2009, 12:41 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
now THIS is interesting
Old 02-08-2009, 01:08 PM   #6
Epic Motorsports
Member#: 198925
We havent even had this released for protuner yet. so probably sometime after we are able to play with it.
Epic Motorsports is offline   Reply With Quote
Old 02-08-2009, 07:09 PM   #7
Cobb Tuning
Member#: 4803
Old 02-11-2009, 11:06 AM   #8
kiwee
Member#: 119232
whats the eta for tuners to start using this?
kiwee is offline   Reply With Quote
Old 02-11-2009, 11:43 AM   #9
nme187
Member#: 117763
IIRC there's no real eta yet
nme187 is offline   Reply With Quote
Old 02-12-2009, 03:33 PM   #10
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Okay, my wait to buy an accessport is almost over.... this is huge.
Do you have to pay MORE for the module, or is it a free update?
irascible is offline   Reply With Quote
Old 02-12-2009, 03:41 PM   #11
nme187
Member#: 117763
I believe this is for ProTuners only and STi's for intial release then WRX's....
Old 02-12-2009, 03:54 PM   #12
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
In the first sentence it says all DBW subaru's. May be true for Protuners only though.
Old 02-12-2009, 03:56 PM   #13
nme187
Member#: 117763
^^^ That will be true, but the initial release will be for STi only then WRX. I asked them about it
Old 02-12-2009, 03:57 PM   #14
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
Guys as of now from what I understand this will be a Protune feature only for sometime. Once the Protuner network has worked out all the bugs and has proven this feature you might see it passed down.
But that most likely will not be for quite some time.
Doug
Topspeed
Badazzcr is offline   Reply With Quote
Old 02-12-2009, 04:06 PM   #15
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Back to waiting... the first post seems to be missleading.
Old 05-08-2009, 06:27 AM   #16
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Is this available yet on other years?
alcoolaid is offline   Reply With Quote
Old 05-08-2009, 11:32 AM   #17
nme187
Member#: 117763
Nope, still in it's beta testing phase with some ProTuners. Once that's all dialed in then Cobb is spreading to the other years.
Cheers
Old 05-10-2009, 05:18 PM   #18
alcoolaid
Member#: 134949
'07 SWP STi
Originally Posted by Cobb Tuning View Post
February 7, 2009
Why would they say this in February.... it's now May 10th and it's still not available?
Old 06-10-2009, 01:50 PM   #19
unclemat
Member#: 114530
2005 LGT 6MT wagon
*bump*
unclemat is offline   Reply With Quote
Old 06-10-2009, 02:59 PM   #20
nme187
Member#: 117763
Some ProTuners have this software and still Beta Testing it. It's getting closer
Old 06-17-2009, 06:36 PM   #21
unclemat
Member#: 114530
2005 LGT 6MT wagon
Ok, in meantime, what are the downsides of speed density calibration vs. MAF...?
Old 06-27-2009, 10:31 AM   #22
apexslider
Member#: 168101
15 BRZ Limited
SS
From what I hear, the only down side would be a searching (or hunting) idle; but that's with full speed density. If you go the hybrid route of MAF / MAP then you get the best of both worlds, good idle from the MAF and good power tunability on boost from the MAP.
looking forward to this finally going mainstream
apexslider is offline   Reply With Quote
Old 06-27-2009, 11:40 PM   #23
Remnex
Member#: 83790
Searching and hunting idle should all but be solved via SD. Reason being is that the fueling is strictly based on the air coming into the engine.
Remnex is offline   Reply With Quote
Old 07-22-2009, 10:39 PM   #24
apexslider
Member#: 168101
15 BRZ Limited
SS
any updates on this???
Old 12-25-2009, 08:12 PM   #25
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Little birdy told me some new engineers are now at Cobb and that they are working on 16 bit ECU's. Can you confirm/validate this? If so I'm VERY interested in helping my tuner beta test for the 16 bit ECU if he is up for it I have a built hybrid using the 16 bit ecu and with a GT35R I'm very easily maxing out the MAF. SD would ROCK for my setup
CoolRex is offline   Reply With Quote
Speed Density Tuning with the Accessport on an 08 STI Cobb Tuning Proven Power Bragging 59 06-07-2010 01:22 PM
Accesstuner pro Version 1 ShaneInHisRoom AccessPort 0 04-25-2010 12:26 PM
Cobb AP + GM Maf or Speed density cpunlamd AccessPort 0 02-28-2009 08:19 AM
Speed Density tuning Psipwrd UTEC 61 10-02-2007 04:59 AM
UTEC Speed Density Tuning How-To? Zumble UTEC 2 02-10-2007 03:16 PM
