Old 02-07-2009, 03:32 PM   #1
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Default Highest WHP 2.0 of AWDTUNING thus far
Hello all, I just had my 02 WRX tuned by Keith from AWDTuning. This was spraying no meth, my controller is fried. So I ordered a new one then I will be going back for another tune. This graph is done on his street dyno software.
Much thanks to Keith for the tune and Ryan for building my heads.
Made 379awhp 298awtq on 93 octane pump gas peaking 22 psi and held to 20psi at red line.
Mods:
Built 2.0- eagle rods, wiseco pistons, acl race bearings, 05 crank, arp head studs, .040 cometic head gasket
Usdm 07 STI cams
Jdm v8 sti springs plus valve job
Brian Crower titanium valves +1 intake std exhaust
NGK BKR7E 1 step colder plugs
Grimmspeed 38mm external wastegate
Element tuning GT52
3” tbe frankenstein
850cc modified stock injectors
Godspeed FMIC reverse flow
Short ram intake
Gimmick silicone turbo inlet
GM boost selonoid
Walboro 255lph fuel pump
TGV deletes
Ported intake manifold
Ported exhaust housing
Tune by Keith from AWDTuning
Grimmspeed ported and coated exhaust manifold
04 transmission plus exedy oem replacement clutch
autvincereautmori is offline   Reply With Quote
Old 02-07-2009, 03:36 PM   #2
kyo126
Member#: 149485
does the car feel very slow b4 4.5k rpm???
nice hp number
kyo126 is offline   Reply With Quote
Old 02-07-2009, 03:39 PM   #3
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
i like the number's man when did you get the tune.
i will be driving down there next sat for my tune it will be a fun 2 1/2 hr drive.
jeremywrx15554 is offline   Reply With Quote
Old 02-07-2009, 03:58 PM   #4
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
I got tuned on Thursday.. Surprising it does not feel slow at all below 4500. I get 3-5 psi at 3300 or so and it is more then enough to get around town. As soon as it hits full boost it goes insane, red line comes so fast.
When meth sprays properly hopefully we can pull the tq up quite a bit and I am sure we will be well into the 400s horsepower wise.
Old 02-07-2009, 04:15 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
get on a dyno and then get back to us. That dyno software is sketchy at best.
but if it feels good then be happy
sidewayz is offline   Reply With Quote
Old 02-07-2009, 04:22 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
damn the 2.0 just kills the tq that kinda sucks, thatd be in the 400's tq if it was a 2.5
nonetheless great numberes! nice to see some big power 2.0's!!
godforbid67 is offline   Reply With Quote
Old 02-07-2009, 04:33 PM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Numbers look great so far! Can't wait to see it on meth and on some type of different dyno.
zeropsi is offline   Reply With Quote
Old 02-07-2009, 04:35 PM   #8
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
**** that turbo performs so much better on the 2.5l motor. Nice numbers though.
j255c is offline   Reply With Quote
Old 02-07-2009, 05:36 PM   #9
fatcircles
Member#: 142310
Maybe you should do more research before making ignorant statements such as this one
This software is very accurate and has been compared with actual dynos, such as the dyno at Engline Logics (Houston).
Keith tuned a car and got the numbers from his program, the very next day it was put on the dyno because some people believed the numbers were inflated. Needless to say, the numbers were pretty much identical to the dyno, which was a mustang dyno if I remember correctly.
So yea, these numbers are very accurate.
fatcircles is offline   Reply With Quote
Old 02-07-2009, 06:27 PM   #10
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
ok so there is no torque, yes i know i also do not weigh nearly as much as a STI with the 2.5 so i do not need to tow a boat.. also when i get the meth up and working the torque will go up quite a bit.
this set up makes similar number whp to 2.5l on pump gas. my engine can also spin to 7500-8k easily i let off early on this pull.
there is another person that Keith tuned on a 2.5l with the same turbo similar mods minus tgv deletes on 91 octane he put down 331whp then on 100 octane put down 436..
Old 02-07-2009, 07:26 PM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
thats the case for any setup....the displacement just moves the powerband left/right.
Old 02-07-2009, 07:54 PM   #12
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Great numbers man! I bet that thing screams! I'd love to see what it does in the 1/4.
And adds torque!! Not to mention also helps minimize compressor surge and supply a better powerband for larger turbos such as this GT52
Going from an 18G 2.0 (made [email protected]) to a vf43 sti ([email protected]) I can say from experience the 18G made more up top but the low end torque of the 2.5 in my STI is phenomenal. I just wish I had that 18G on my STI
Steve.804 is offline   Reply With Quote
Old 02-07-2009, 09:37 PM   #13
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
What do you rev it out to on the street? Those sti cams seem to be doin a good job uptop
Old 02-07-2009, 09:59 PM   #14
BlueRallyWrx
Member#: 104876
2003 WRX, HEMI Jeep,
DD Honda Accord
Nice numbers! You probably put down around 400 whp once you get your meth going.
BlueRallyWrx is offline   Reply With Quote
Old 02-08-2009, 12:57 AM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
can you explain that?
but the 2L was faster.....1/4 mile wise
having huge low end tq numbers is great...but it usually means the cars dead above 5000rpm
im happy with my 375 tq @ 3800rpm......and 375 whp at 6100rpm
From my experiences 44-52 lb/min turbos are the perfect daily drivers for the 2.5L. Anything bigger and you start to lose out on the powerband you could have past 7k (unless you have the valvetrain and oiling taken care of). Anything smaller and the car feels like it falls on its face at higher rpm.
For the 2L's 36-47 lb/min seem to do well for dd's......going up to a green or gt52 like this car and you end up peaking hp too late. but this guy has cams so it will be usable when he retune's.
Old 02-08-2009, 02:34 AM   #16
Spic-N-Span
Member#: 193927
2006 Squidzbuilt WRX
SRR
Fatcircles is right. Learn something about what you are typing before you stick your foot in your mouth. BTW, I think it was kind of him to refer to your post as ignorant.
Spic-N-Span is offline   Reply With Quote
Old 02-08-2009, 02:35 AM   #17
awdtuning.com
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
This was actually 22psi to redline..but pretty easy going AFR wise(11.2-3). His EGT guage was on the fritz so I didn't want to make the tune very aggressive.
Everything just came together well and the intercooler has done a great job on every turbo we've ran on it - plenty of cfm for any sizable turbo to stretch its legs.
awdtuning.com is offline   Reply With Quote
Old 02-08-2009, 11:37 AM   #18
PolarisSnT
Member#: 85905
2004 WRX
If used properly with a correct log it will prove to be a very nice representation of a power/torque graph.
It looks like 1 of 2 things here. There is a large smoothing factor being applied or the datalog used contains a considerable amount of logged parameters.
For this software to be at its best you need a log of just RPM but to help smooth things out a bit I usually log RPM and Engine load, otherwise the graphs come out way to jagged.
PolarisSnT is offline   Reply With Quote
Old 02-08-2009, 12:01 PM   #19
sidewayz
Member#: 5810
2001 S366 2.5RS
Ignorant? learn the meaning much? How do yo know of my experience with this software? Oh thats right YOU DON'T.. so who's being ignorant?
I have the software. I've used it for years. Its very easy to make it "read" higher and imho its not accurate enough to call it "wheel" horse power. I've made VF34 cars show 400whp. a little tweak here, a little teak there.
Its great to show differences in mods in the SAME car on the SAME day with the SAME weather... waaaaaaaaay too many variables to accurately claim "whp"
no foot insertion here
Old 02-08-2009, 12:48 PM   #20
Spic-N-Span
Member#: 193927
SRR
HHHMMMM...............So you've used the software huh? So the dyno numbers that many of his customers have that prove his software is accurate don't mean anything to you, or did you just decide to omit that part. The software is accurate if the tuner understands these variables. Since Keith obvoiusly understands these variables and his numbers have been backed up many times really you are insulting Keith. That said let me ask you this, you said you know the software but do you know Keith? So now IMHO, since his software has been proven and you tell a customer to "get on a dyno and get back to us" ,again you are just insulting Keith. I don't think you will find much love on this board for insulting AWDTUNING. Your post is ignorant and nothing you can say about me is going to change what you typed. Have a nice day.
Old 02-08-2009, 12:54 PM   #21
grimlin
Member#: 176088
2009 Legacy SpecB
Back on topic now.
Congrats on the power. I know you guys put a lot of work on your set-up. Now, when are you going to the track?
grimlin is offline   Reply With Quote
Old 02-08-2009, 02:17 PM   #22
gleesamo
Member#: 143346
03 wrx 285 whp
white
GREAT NUMBERS!!!! I might just biuld one of my spare 2.0's instead of doin the whole hybrid thing!
gleesamo is offline   Reply With Quote
Old 02-08-2009, 02:21 PM   #23
lev98
Member#: 140529
01 Ferrari 360 spy
Since you are so consumed with dyno numbers you do know they all read different right. A dyno jet will read 400 whp and a mustang will read 330whp for the same car. They too have different variables. So your argument is mute.
lev98 is offline   Reply With Quote
Old 02-08-2009, 02:54 PM   #24
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
is it just me or does the tq seem a little low? Nice numbers though, I wish i had them...
xxxjuhstenxxx is offline   Reply With Quote
Old 02-08-2009, 02:57 PM   #25
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
If this car was put on a dyno, then why not post up those numbers??,....
The software is a great tool, take the numbers with a grain of salt the same way you do all dyno numbers. We all know how much they all vary.
I would like to see some 1/4 mile times personally
Enjoy it anyhow , cause it looks fun !
jmlaser is offline   Reply With Quote
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 04:41 AM
Trying to log with Openport 2.0 and not getting far help please. Deserted1 Engine Management & Tuning 2 01-30-2009 04:33 PM
Audi Announces Version 2.0 of 'Audi A4 Driving Challenge AVANTI R5 Non-Subaru News & Rumors 0 09-30-2008 01:48 PM
My 1016 WHP 2.0 L Evo 8 Dyno Flash Proven Power Bragging 176 03-26-2008 01:47 AM
Favorite part of ABC's coverage thus far TimStevens Motorsports 9 10-01-2001 08:23 AM
