Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 02-07-2009, 08:37 PM   #1
Mechie3
Member#: 120152
Default Engine rebuild, parts to reuse, general questions
I'm rebuilding my old engine (spun bearing) and want to know if I can reuse the oil pump and the oil cooler. I vaguely remember someone saying that if you spun a bearing the flakes tend to collect in the pump/cooler (don't remember if it's both or one or the other) and are impossible to fully clean out.
Is it safe to reuse my pump/cooler (30K miles on both) or should I just buy new ones?
Also, how do I prime the oil pump/the entire engine before starting it the first time? Do I pour some oil in through the head breather lines to make sure they're coated? What about turning the engine upside down during assembly? Will this affect pump priming (ie, drain it if it has been primed)?
Thanks.
Mechie3 is offline   Reply With Quote
Old 02-07-2009, 09:22 PM   #2
joeschmoe714
Member#: 71374
2005 impreza wrx
aspen white
as far as i know you always replace the pump.
im not so sure about the cooler though.
joeschmoe714 is offline   Reply With Quote
Old 02-07-2009, 10:52 PM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I would buy a new pump and cooler as well as a new pan.
As far as priming the pump, before starting I just pull the fuel pump relay and crank the motor over a couple of times for about 10 seconds each.
LiquidForce is offline   Reply With Quote
Old 02-07-2009, 10:53 PM   #4
benw
Member#: 103320
2005 wingless
aspen white
changing the cooler is recommended as there are many small galleries inside the unit that readily accumulate metal chips and shavings from nuked bearings. you fire up the new engine and all that junk washes over your bearings and scores them.
benw is offline   Reply With Quote
Old 02-07-2009, 11:33 PM   #5
Mechie3
Member#: 120152
I don't need to fill the pump itself with oil first? What about the heads and such? Should I "prime" those as well so the engine isn't turning over without any oil at all having gotten there?
Old 02-08-2009, 12:02 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
For my PERSONAL use only, I just tear down the oil pump and inspect. I have one that has 100xxx miles on it, and been on 7 motors... (not that those 7 motors lasted very long unto themselves), BUT I have never had a oil issue.
The big thing is too just inspect the pump and make sure its withen spec.
However, as a 10mm oil pump is something like $175, it may not matter to you.
Old 02-08-2009, 05:47 AM   #7
Ej2.6
Member#: 201470
what kinda cooler should one replace it with when rebuilding a new engine? and i too am curious aout priming the engine.
Ej2.6 is offline   Reply With Quote
Old 02-08-2009, 06:52 AM   #8
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
you might be able to tear down and flush to rebuild. Worth a shot for sure.
Fongers is offline   Reply With Quote
Old 02-08-2009, 01:25 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
the oil pump is fully capable of being disassembled to clean and check for debris. Like what was said, check it for being in spec. If nothing is wrong, then it's ok to use.
As for priming the oil pump, you can use smear some assembly lube in the gears, I've read that someone used a little vasoline. To prime the engine, take out spark plugs(don't want compression if no oil on bearings) and disconnect injectors/fuel pump relay and crank about 10 seconds for about 6 times.
As long as you're in there, port match the oil pump to the block.
yarrgh is online now   Reply With Quote
Old 02-08-2009, 03:49 PM   #10
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
^^^^agreed.
The oil light should turn off after priming it too. This means there is 15psi of oil pressure in the system. It may not be 15, maybe 10 or so, but either way it means that you have built pressure in the system.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 02-08-2009, 03:57 PM   #11
Fongers
Member#: 118239
2002 Built Wagon
Just pull the ignition fuse, that will kill fuel and spark and crank till the light goes out. I even do his for each oil change...
Old 02-08-2009, 08:06 PM   #12
Mechie3
Member#: 120152
Thanks. I just wasn't sure if the system would self prime using the starter cranking method if the gears in the pump weren't already filled with something.
Engine Rebuild Parts *** COSWORTH / TOMEI / MAHLE / WISECO / OEM and many more RavSpec Engine/Power/Exhaust 56 07-28-2010 10:05 AM
txic, any good reputable shops to purchase engine rebuild parts from? Damon Texas Impreza Club Forum -- TXIC 3 10-27-2009 07:26 PM
engine rebuild (what to do while im in there) ibanez24_7 Normally Aspirated Powertrain 16 08-06-2009 03:41 PM
WRX Engine rebuild...Where to go? Udonboy Southern California Impreza Club Forum -- SCIC 50 02-22-2006 11:20 PM
legacy engine rebuilding parts sites? stant093@ Legacy Forum 5 07-11-2003 03:01 PM
