Old 11-09-2012, 08:24 AM   #26
J3FF.BROWN
Member#: 300708
2004 impreza wrx
THANK YOU VERY MUCH. It was that obvious of a fix haha I was getting frustrated after a long day at work. I'm going to retry this again today. Thankssss
J3FF.BROWN is offline   Reply With Quote
Old 11-10-2012, 06:20 AM   #27
J3FF.BROWN
Member#: 300708
2004 impreza wrx
today after 6 hours of pain and suffering i finally switched out all my studs using your method! thanks again. now i just have to wait for the studs to settle in good. i have already had them loosen up on me twice
Old 11-10-2012, 11:35 AM   #28
68Cadillac
Member#: 95901
Glad it worked out for you.
Originally Posted by 68Cadillac View Post
23. Even after step 15 the studs will not be fully seated. Torque your lugs down to 70 ft.lbs for every 2 miles driven. NO REALLY! These studs will need to be re-torqued several times until they're fully seated on the hub. Three times if you're lucky. Five times if you want to be certain.
I bolded step 23 for a reason. Enjoy your fancy studs.
68Cadillac is offline   Reply With Quote
Old 11-10-2012, 12:46 PM   #29
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I would recommend not using your lug nuts to pull the studs through. Use either a M12x1.25 Class 10.9 nut, or other lug nuts. Wouldnt want to damage a lug nut and have t buy another set.
Old 12-30-2012, 12:59 PM   #30
shabakababa
Member#: 328558
2004 impreza wrx
Great write up and worked exactly how you said. The diameter of the abs sensor plug was 17.7 and the head of the arp stud is 18.6 so wasn’t much to shave off. fit right through the abs hole and was installed in no time! level of Difficulty 6 and time wasted including grinding 2 hours.
shabakababa is offline   Reply With Quote
Old 06-26-2013, 12:55 AM   #31
manys
Member#: 265277
1999 Outback
Legacy
UPDATE: for future generations
50mm(2 inch) studs
and maybe even little longer ones don't require grinding.
You need to take off the parking brake assembly and there is enough space to slide them in from the back(not trough the abs sensor hole)
Takes much less time than grinding and it's overall safer/better method.
Look for Ichiba studs. Dirt cheap and proven quality. They have few different sizes too.
manys is offline   Reply With Quote
Old 07-11-2013, 11:29 PM   #32
piripi
Member#: 178410
2006 WRX Wagon
CGM
Can you fit 10mm spacer with the 2 inch studs?
piripi is offline   Reply With Quote
Old 07-12-2013, 01:34 AM   #33
manys
Member#: 265277
1999 Outback
Legacy
Im running 12mm spacers with 2 inch studs.
You can very safely run 15mm with those
Old 03-16-2015, 08:29 PM   #34
bmxr
Member#: 403980
2015 WRX Base
Great how-to! I have a question and a comment (not for the OP):
Why use NISMO studs that cost twice what ARP cost?
Google "Ichiba studs quality"
I was going to skip better quality studs, but now I want to tackle it!
bmxr is offline   Reply With Quote
Old 05-04-2015, 10:22 PM   #35
bmxr
Member#: 403980
2015 WRX Base
Just a PSA for 2015 owners... This does not work with the new car. ABS sensor is totally different. I guess I should have taken some pics, but I forgot. I did not remove the parking brake assemble so maybe there is an option there, but I don't think so. YMMV.
Old 12-03-2015, 04:49 PM   #36
scoobydo2.0
Member#: 261290
68Cadillac, I just found this write up and will be using this to do my install this weekend, thanks for posting this!!
scoobydo2.0 is offline   Reply With Quote
Old 12-03-2015, 06:17 PM   #37
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
On 2015s you have bolt in hub/bearing packages so just remove the hub from the car.
Old 12-05-2015, 06:12 PM   #38
bmxr
Member#: 403980
2015 WRX Base
Isn't that a big job?
Old 12-05-2015, 06:36 PM   #39
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Not at all. Remove the caliper and rotor. Remove the axle nut. Unbolt the hub.
Old 12-16-2015, 10:49 PM   #40
bmxr
Member#: 403980
2015 WRX Base
I thought pressing in a new bearing was necessary upon reassembly when you do that?
Old 12-16-2015, 11:46 PM   #41
jamal
Member#: 71875
98 Legacy GT
my wheels fit
No pressing required for bearings on the newer cars. Hub+bearing are together and come out as one piece. Not sure if the parking brake stuff is in the way and also needs to come off though.
Also on the older bearings be very careful hammering out the stock lugs. I broke a tone ring once doing that.
jamal is offline   Reply With Quote
Old 12-17-2015, 10:54 PM   #42
bmxr
Member#: 403980
2015 WRX Base
Cool, thanks!
Old 12-20-2015, 03:04 PM   #43
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Parking brake does not have to be touched to remove the rear hubs on a car with bolt in bearings. Depending on the tools you have, pulling the axle out of the hub first may make it easier for you to access the bolts holding in the hub, though.
06 STI + ARP Wheel Stud Install Token-Negro Tire & Wheel 2 10-19-2008 02:17 PM
Help: hydraulic stand press anyone? ARP Wheel Stud Install deviantek North West Impreza Club Forum -- NWIC 4 06-21-2008 05:48 PM
Help: hydraulic stand press anyone? ARP Wheel Stud Install deviantek NWIC Private Classifieds 1 06-20-2008 09:56 PM
ARP Wheel Stud Install mattminer Brakes, Steering & Suspension 2 05-11-2008 01:11 PM
ARP longer wheel studs- installation? alltracin Brakes, Steering & Suspension 27 03-20-2008 02:05 PM
