Old 02-08-2009, 02:55 PM   #1
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Default 08 STi stock springs on 09 WRX - pics
Mods, feel free to combine this with any other threads on this subject. I can't find the one I was thinking about!
Anyhow, got some lightly-used 08 STI stock springs from Dan at MachV (thanks for the great deal Dan!). I only installed the fronts, since other posts have shown that the rears on the 08 STi and 09 WRX are both the same height and the same rate, so why bother.
After and hour of easy work (damn these cars are easy to work on) they are on, so here are some pics and measurements:
before:
FR ground to fender: 27"
FR hub center to fender: 15 3/8"
FL ground to fender: 27 1/8"
FL hub center to fender: 15 1/2"
after (driven aroud for 20 mins)
FR ground to fender: 26 1/2"
FR hub center to fender: 14 7/8"
FL ground to fender: 26 5/8"
FL hub center to fender: 15"
So as we can see, it was an exact 1/2" drop (the springs off the car are also about 1/2" shorter than te stock 09s). Also set the max negative camber available using the stock eccentric bolts (which is not much). Alignment tomorrow.
Ride and handling are unchanged so far as I can tell after 20 minutes in the windy forest roads nearby. Intentionally tried to bottom them out but only did it once on a heavy off-camber downhill 90* turn, and it was light. There were a few big dips and speedbumps too and didn't have any bottoming issues.
All in all a good "looks" mod that slightly reduces center of gravity and doesn't negatively affect ride or suspension performance to any noticeable degree IMO.
Pics:
Spring comparison:
before and after front height (flat ground)
full-side shots (on a very slight slope)
irish44j is offline   Reply With Quote
Old 02-08-2009, 05:18 PM   #2
BIGSKYWRX
Member#: 7958
09 GH B+
nice- 10-12mm drop, still well within factory spec even
lmk how much camber you can eek out up front (*hint- make sure they fully loosen that bottom strut bolt before they start messing w/ the eccentric bolt-alignment techs are notorious for not doing that)- someone emailed me they got -1.4 w/ theirs- I thought that was pretty decent
Old 02-08-2009, 05:45 PM   #3
irish44j
Member#: 191290
09 OPB SM WRXsedan
I have an old longacre camber gauge that was reading somewhere in the neighborhood of -0.9 to -1.1 with the eccentric bolts set to "max" camber setting (the side nick mark vertical to the strut and the "11" pointed toward the strut, about 90* from the stock setting). By the arrangement of the suspension, I suspect actual max camber is with the bolt about 10* off the vertical/horizontal mark axis, but didn't want to play around too much with it since I have only marginally effective measuring equipment here!
I did in in the driveway though, so can't say exactly.
Old 02-10-2009, 11:23 AM   #4
BIGSKYWRX
Member#: 7958
09 GH B+
did you get it on a rack yet?
Old 02-10-2009, 12:32 PM   #5
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
I thought you weren't modding it??
Looks VERY good tho!
96accord is offline   Reply With Quote
Old 02-10-2009, 07:58 PM   #6
irish44j
Member#: 191290
09 OPB SM WRXsedan
I lied. Shoulda known better than to say something so silly.
went by a local tire place that has free alignment check this afternoon, but they had 2 cars ahead of me and I didn't feel like waiting. Will try again later in the week.
Old 02-10-2009, 08:17 PM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
sounds good- have them wrangle as much neg camber as they can muster!
08 STi OEM Springs on WRX Epic_Beck Newbies & FAQs 1 07-15-2009 03:53 PM
Will 08 STi srpings work on 09 WRX? S2kVer02 Brakes, Steering & Suspension 4 12-17-2008 02:50 PM
08 STi springs on 09 WRX ? Brack Brakes, Steering & Suspension 0 12-12-2008 11:34 PM
2006 WRX STI Stock Springs on Ebay casionerd Suspension/Brakes/Handling 0 03-11-2008 11:37 AM
Swift STi Specific springs on a WRX stock struts? PinnacleChronos Brakes, Steering & Suspension 4 06-10-2006 06:12 AM
