Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-08-2009, 07:30 PM   #1
kaos200
Member Sales Rating: (74)
Member#: 2692
Lightbulb Koken Hardened 10mm cam gear removal socket!
How many of us have been in this position. You’re removing your engine, tearing it apart to do whatever cool (or necessary) changes to it, and all that is stopping you from getting your heads off your block, is the pesky, retarded, anger-fueling cam gear bolts.
They stand in defiance to the most brutal tools. They are the devil. And therefore, they should be destroyed.
I have taken apart/assembled many Subaru engines, and always dread removing these bastards, especially if it’s the first time the stock engine has been taken apart, I swear Subaru has Godzilla tighten those damn things at the factory. The 10mm hex bolts have called for, and been the cause of multiple tool breakages, bolt removers, welding, and drilling to get them off. Sometimes, if you are lucky, you only get one out of the four that’s a pita (somehow always the last one), and if you ever get them off without issue it’s a miracle and you should go out and buy a lottery ticket. As you can see I’ve stockpiled extra cam gears and bolts just incase (these are just the extras, not counting the 2 sets on my engines!)
There was always the issue of holding the cam gears steady. 2.0 liter cams always had that handy hex on the cam that allowed you to hold it steady with a wrench, no such luck with the 2.5liters. They do have the actual tools for that, or even having an old belt, and clamping it tightly around the gears so they doesn’t move still leaves you with the task of getting the bolt out without bending/breaking a tool!
So, I assembled my tools
C-Clamp, vice grips, old timing belt, 22mm for crank, breaker bar, BIG breaker bar and super cool new 10mm hex
Wrap the old belt around the gears, and clamp down like your sanity depends on it (cus it might).
But my biggest complaint wasn’t from holding the gears steady, its from being unable to break the bolts lose with crappy tools like this little thing.
I would have shown you all the broken ones I’ve had over the years, but luckily Sears takes them back in exchange for new ones…
As you can tell, sub-par tools frustrate me, and there’s nothing worse than being frustrated when working on your car. Luckily I had ran into Marc at Ultimate Tool Co. (ultimatetoolco.com, yes I plugged it!) since I had bought their T70 torx drive for the transmission drains. I thought maybe he could help me from breaking any more of those cruddy 10mm’s I had been using before.
He delivered…. THIS
Its a "Koken" 10mm hardened steel 1/2" drive
So simple, no? Don’t let looks fool you. My curiosity got the best of me, and I quickly walked up to a block (which was being prepped to be removed from the car), took the timing belt covers off, rotated the crank till the pistons were down (just incase!) stuck the shifter in 6th, and cracked each bolt loose with one hand on a small breaker bar and the new tool. No snapped hex!
I called shenanigans, walked over to another block being disassembled (on a stand this time) strapped the cams down with my old timing belt that I keep around solely for this purpose, and proceeded to crack each one loose again! One needed some more push, but she gave in after some fighting. No crazy air tools, no 6foot long jack handle over your 2 foot long breaker bar with you hanging off the end like a monkey whilst the bolt stands in defiance as you break the 10mm bit!
I didn’t realize what a difference having just a nice 10mm would make, but it really is so much nicer to deal with. If it wasn’t I wouldn’t be so happy to write about it!
I’m ordering another, to plan against going crazy just incase I lose mine.
oh yah, another shameless plug, since I'm so glad they sourced this for me!
http://ultimatetoolco.com/Koken10mm.aspx
kaos200 is offline   Reply With Quote
Old 02-08-2009, 07:55 PM   #2
Rodwrx23
Member Sales Rating: (76)
Member#: 170948
[/quote]No crazy air tools, no 6foot long jack handle over your 2 foot long breaker bar with you hanging off the end like a monkey whilst the bolt stands in defiance as you break the 10mm bit!
[/quote]
I literally almost pissed my pants. I had a complete visual of this and laughed my ass off. Nice find.
Rodwrx23 is offline   Reply With Quote
Old 02-10-2009, 01:00 PM   #3
2gnt2wrx
Member Sales Rating: (61)
Member#: 123625
2015 WRX
Galaxy Blue
When we did mine, we just used a 10mm allen wrench with a 2ft cheaterbar. It worked like a charm. And yes Godzilla does work at the subaru factory, I think he was the designer of the GBOD also...
2gnt2wrx is offline   Reply With Quote
Old 02-10-2009, 02:04 PM   #4
kaos200
Member#: 2692
Hah probably.
I've tried all sorts of allens, if it didnt snap, it rounded, if it didn't round, it twisted... Just pathetic. I just don't know why no one offered anything like this (that I could find) for so long.
Old 02-11-2009, 11:26 PM   #5
Ej2.6
Member Sales Rating: (1)
Member#: 201470
i just bought this thing too, only my block is on the ground not in the engine. GOD i was so happy to think i was takin off the head today and instant WALL ruined my rebuild spree.... i hope this thing works.
Ej2.6 is offline   Reply With Quote
Old 03-06-2009, 02:17 AM   #6
ULTIMATETOOLCO
Vendor Sales Rating: (50)
Member#: 165370
2007 WRX
www.ultimatetoolco.com
Originally Posted by kaos200 View Post
Hah probably.
Thanks again!
ULTIMATETOOLCO is offline   Reply With Quote
Old 03-07-2009, 04:28 PM   #7
kaos200
Member#: 2692
Originally Posted by ULTIMATETOOLCO View Post
Thanks again!
nooo thank YOU!
Old 03-12-2009, 12:57 AM   #8
supernick77
Member Sales Rating: (4)
Member#: 145122
1999 99 lgt, 86 brat
black, lt blue
and again. it was on there so tight i thought it was reverse thread. DAMN! that was on there. i tried alot of different ways and then gave up and just jumped on nasioc. god bless nasioc
supernick77 is offline   Reply With Quote
Old 04-12-2009, 02:24 PM   #9
ULTIMATETOOLCO
Member#: 165370
2007 WRX
Bump!
Old 04-28-2009, 07:53 AM   #10
Dan Cech
Member Sales Rating: (2)
Member#: 67154
2007 Audi RS4
Avus
Thanks for the heads-up, I was getting nowhere with the autozone-brand 10mm 3/8 drive!
Ordered up a Koken and hopefully I'll be able to get those damn bolts off without resorting to violence.
Dan Cech is offline   Reply With Quote
Old 04-28-2009, 10:06 AM   #11
sszyma
Member Sales Rating: (6)
Member#: 31399
2007 WRX
2014 Forester 6MT
McMaster also has them :
55105A63
1/2" Square Drive Hex Bit Impact Socket
10mm, 3-1/4" Overall Length, Black Finish
In stock at $12.06 Each
sszyma is offline   Reply With Quote
Old 05-02-2009, 07:03 PM   #12
gregnice123
Member#: 165609
2006 WRX
Aspen white
55105A63
But when you're staring at that unecessarily long McMaster hex bit section twisted and sheared off, the difference in price for a quality socket is more than well worth it. There's a reason that the Koken unit is stubby.
gregnice123 is offline   Reply With Quote
Old 05-03-2009, 07:03 PM   #13
kaos200
Member#: 2692
Agreed, one of the only times shorter/stubby is actually better.
Old 05-04-2009, 08:08 AM   #14
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Threw the Koken on a 30" breaker bar and used the old belt to lock the cams in place...made the job almost too easy
I put the belt around each cam gear in turn, a little different from the pic above:
Old 05-06-2009, 07:42 PM   #15
06rexwagon
Member Sales Rating: (16)
Member#: 114730
2006 WRX Limited Wag
9.8@150
Just ordered one.
06rexwagon is offline   Reply With Quote
Old 05-06-2009, 09:33 PM   #16
fl4tsc
Member Sales Rating: (51)
Member#: 177247
2005 WRX 16G-XT+EWG
1980 Porsche 911SC 3.6L
ordered one sunday night, left cali monday through USPS.... too bad i'm in south carolina. hopefully it gets here before this weekend so i can finally take the motor apart
fl4tsc is offline   Reply With Quote
Old 05-09-2009, 03:08 AM   #17
lennybootzz
Member Sales Rating: (12)
Member#: 190811
04 gt35r built
wrb sti
Can i re use my pulley and crank bolt?
lennybootzz is offline   Reply With Quote
Old 05-30-2009, 09:39 AM   #18
06rexwagon
Member#: 114730
9.8@150
I've removed several pulleys with mixed luck without this tool. On my motor last summer I twisted off 2 3/8 to 1/2 adapters, stripped 2 allens, and broke one bolt. It took me 2 days to get the pulleys off. I just did an 04 STi yesterday that had never been apart and I used this which I ordered about a month ago. It took me all of 3 minutes to get all 4 pulleys off. This has to be the best time saving tool you can have if you work on your own motor.
Old 08-15-2009, 02:38 PM   #19
ULTIMATETOOLCO
Member#: 165370
2007 WRX
Thank you!
We just received our shipment of these. Back in stock and ready to ship!
Old 09-07-2009, 01:52 PM   #20
ULTIMATETOOLCO
Member#: 165370
2007 WRX
To the top!
Old 09-07-2009, 03:07 PM   #21
Evil Imports
Member Sales Rating: (103)
Member#: 14732
+ 13 B8
i bought a full set from Harbor Freight for like $7.99 and have taken off all the gears on 2 different motors with no problem at all, Can't see a reason on spending $28 on this
Evil Imports is offline   Reply With Quote
Old 08-02-2010, 01:00 AM   #22
ULTIMATETOOLCO
Member#: 165370
2007 WRX
Thanks for supporting a NASIOC vendor! To the top!
Cam Gear Removal sureshot007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-15-2008 09:39 AM
Cam gear removal cdigerlando Service & Maintenance 1 03-01-2007 11:02 AM
Cam gear removal tools ST 499207100 and ST 499207400 Brabus Private 'Wanted' Classifieds 1 10-13-2005 05:12 PM
Cam Gear Removal.. lil shoaf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-22-2005 03:17 AM
cam gear removal stiffler Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-06-2005 12:57 AM
